Specific Heat Capacity of a metal bar placed into water
The discussion focuses on calculating the specific heat capacity (shc) of a metal bar placed in water. The thermal energy gained by the water is calculated as 11035.2 J, using the equation Eth = mCΔT. Participants express uncertainty about how this energy relates to the cooling of the metal. The conversation emphasizes the need to establish an equation for the metal's temperature change and to define its specific heat as an unknown variable. The goal is to accurately determine the metal's specific heat based on the provided data.
lxhull
A thermos bottle contains 0.150 kg of water at 4.1 °C. When 9.00 x 10^-2 kg of a metal, initially at 96.2 °C, is put into the water, the temperature of the water rises to 21.7 °C. Calculate the specific heat of the metal
C= Eth/mT
Previously solved thermal energy gained by water as
Eth= 0.15(4180)(17.6) = 11035.2 J
Not sure if its relevant
It is. How does it relate to the cooling of the metal?
That's the problem, I don't know. It seems like it can't be part of the equation for the metal's shc because it used the waters shc, so I can't figure it out.
Just write the corresponding equation for the metal's change in temperature. Create an unknown for the metal's s.h.
lxhull said:
Homework Statement:: A thermos bottle contains 0.150 kg of water at 4.1 °C. When 9.00 x 10^-2 kg of a metal, initially at 96.2 °C, is put into the water, the temperature of the water rises to 21.7 °C. Calculate the specific heat of the metal
Relevant Equations:: C= Eth/mT
Corrrct so far.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
