Specific Heat Capacity of metal in water
To find the final temperature of the unknown metal, copper container, and water, the specific heat capacities of each material must be considered. The specific heat of the unknown metal is 3.6 J/g°C, while water has a specific heat of 4.2 J/g°C, and copper has 0.4 J/g°C. The initial temperatures of the metal, container, and water are provided, allowing for the application of the energy balance equation E=Cm(t1-t2). Clarification on the units for the specific heat is necessary for accurate calculations. The information provided is sufficient to solve the problem.
jendrix
An unknown metal with C=3.6 Mass=150g Temp=160c is added to copper container(85g) filled with water(105g) both with an initial temp of 20c
I have to find the final temp of water,container and metal
none given but I assume it will be E=Cm(t1-t2)
I'm just going over it at the moment and wanted to know if that is enough information to work out the answer.The wording of the question is a bit vague and I'm not sure if I should be using information from the question that came before.
Thanks
Thanks
You'll be needing the specific heats of water and copper.
[EDIT:] Also, what are the units associated with the C of the unknown metal?
Sorry must have missed these off
Unknown =3.6
Water =4.2
Copper =0.4
Unknown =3.6
Water =4.2
Copper =0.4
You should indicates the units associated with those numbers. Otherwise how is one to know if they are cal/gram/K, J/kg/K, J/mol/K, kJ/kg/K,...
Sorry it's j/g-1/c-1
Just to confirm, is all the info I've listed enough to solve the problem?
Thanks
Thanks
Yes.
9K
  • · Replies 16 ·
