Specific Heat Capacity of water in a kettle
The discussion revolves around calculating the specific heat capacity of water using a kettle's heating data. The user correctly calculated the energy supplied but struggled with the formula for specific heat capacity, confusing the temperature change with time. The correct formula requires using the temperature change (96 K) rather than time (322 seconds) in the denominator. Additionally, the mass should be converted to grams for the correct units of J/g K. The user acknowledged the mistake and expressed relief at the clarification.
Dave Jones
mass, m, of water in kettle
1.5 kg
power rating, P, of kettle
2.1 kW
time interval, t, for heating
322 seconds
starting temperature
4 °C = 277 K
finishing temperature
100 °C = 373 K
temperature change, ΔT
96 K
electrical energy supplied, E = P × t
(2.1x10^3)(322) = 6.8x10^5 J
calculate the specific heat capacity: c = q/(m)(delta t)
Why do i keep getting the wrong answer?
q = 6.8 x 10^5
m = 1.5kg
t = 322
Thus c = 6.8 x 10^5/1.5*322 = 1407.8674948240165631469979296066252587991718426501035
But I am sure that's wrong, it's not supposed to be the exact figure, as this was a rough experiment done at home. It's way off, where am i going wrong? thanks
1.5 kg
2.1 kW
322 seconds
4 °C = 277 K
100 °C = 373 K
96 K
c = q/(m)(delta t)
q = 6.8 x 10^5
m = 1.5kg
t = 322
A couple of things. The answer should have units of J g^-1 K^-1 (i.e. J/g K)
You took Joules and devided by mass (kg) and time (sec). Your answer has units of J/kg s -- not right.
You want to take the heat (which you have) divide by the mass in g and divide by the change in T.
Dave Jones said:
Thus c = 6.8 x 10^5/1.5*322 = 1407.8...
Largely your problem is calculator operator error. You've divided by 1.5 then multiplied by 322 when the 322 should be in the denominator. Parentheses can help manage the order of operations.
Oh..But i thought you always take the mass in SI which is kg?
Ok thanks
This still isn't making sense to me:
Right so the equation for specific heat is:
c = q/(m*delta t) right?
So if we are using 6.8 x 10^ 5 as q, and 1500grams for mass, and change in t is 322 seconds, that would give us:
c = (6.8 x 10^5)/((1500)(322))
But that gives me an answer of like 1.4 J/kg s
Right. Clearly incorrect. Hint: What are the units of the 322 value you've used?
The symbol t does not always refer to time (322 sec). Sometimes it refers to temperature difference (96 C). Which do you think it refers to in this context?
Chet
Seconds, aren't i supposed to be using that? This is confusing lol.
I always get told you're supposed to use SI units, and for mass that's kg and time s :(
Chet
Oh wow I am stupid haha. I can't believe I've just done that.
Been a long day...lol.
  • · Replies 16 ·
  • · Replies 17 ·
