Speed of electron flow through a conductor
In summary, the speed of electron flow through a conductor, such as copper, is not equivalent to the speed of light (c). While the electromagnetic field generated by a current can approach c, the actual drift speed of electrons is much slower and can vary depending on different factors. Additionally, the energy carried by the flowing charges is not directly related to their kinetic energy due to the small mass and slow speed of individual electrons.
rootone
3,395
946
Is the speed of electron flow through a conductor such as copper equivalent to 'c'?
I've heard of this being implied several times, but is it a fact?
I know it can't be exactly the same as 'c' because we are not talking of energy propagating though a vacuum.
I'm not an expert but I know the speed of electrons in a conductor like copper is measured in cm/s.
It's the electromagnetic field that propagates with such a speed: in fact when we turn on the light the sensation is that there isn't delay in trasmission of current.
This fact is similar to open a tap or faucet on a pipe; a pressure wave propagates through and water, which has a smaller speed, goes out because the pipe is already full of water.
Thanks both.
So 'c' is not actually a relevant factor at all, although the electromagnetic field generated by a current does travel at a speed approaching c.
(whereas the actual drift speed of electrons themselves is nowhere near c and can vary depending on various parameters).
Furthermore, there is another mistaken idea that the energy carried is something to do with the Kinetic Energy of the flowing charges. A moment's thought should put that to bed when you consider the mass of a single electron (1/ (many thousands) of each atom) and a mean speed of a few mm/s and then think of the energy transferred by the charges in a circuit.
Related to Speed of electron flow through a conductor
1. What is the speed of electron flow through a conductor?
The speed of electron flow through a conductor is on average about 0.001% the speed of light, or approximately 2.2 million meters per second. However, this speed can vary depending on the material and conditions of the conductor.
2. How does the speed of electron flow relate to the current in a conductor?
The speed of electron flow and the current in a conductor are not directly related. The current is the rate of flow of charge, while the speed of electron flow is the actual speed at which individual electrons move through the conductor. They are both affected by factors such as resistance and voltage.
3. Does the speed of electron flow change in different types of conductors?
Yes, the speed of electron flow can vary depending on the type of conductor. For example, in a metal conductor, such as copper, electrons can move more freely and thus have a higher speed compared to a non-metal conductor, such as rubber, where electrons are more tightly bound to atoms and have a slower speed.
4. Can the speed of electron flow be faster than the speed of light?
No, the speed of electron flow through a conductor is limited by the speed of light. According to Einstein's theory of relativity, nothing can travel faster than the speed of light in a vacuum, including electrons.
5. How does temperature affect the speed of electron flow through a conductor?
Temperature can affect the speed of electron flow through a conductor by increasing or decreasing the resistance of the material. At lower temperatures, the resistance is lower, allowing electrons to move more freely and thus have a higher speed. On the other hand, at higher temperatures, the resistance increases, slowing down the speed of electron flow.
  • Electromagnetism
  • Electromagnetism
12K
