Speed of light for different observers
In summary, the conversation discusses the concept of the speed of light being constant for all observers, regardless of their relative velocity. A thought experiment is proposed involving a truck moving with a light source and two detectors, which leads to a discussion on the relativity of simultaneity and the impossibility of measuring the one-way speed of light. The conversation also touches on Einstein's Special Relativity and the importance of considering spacetime diagrams when analyzing such scenarios.
  • #71
ghwellsjr said:
It is not possible to determine or measure the one-way speed of a light pulse or a photon. We can only measure the round-trip time it takes for a light pulse to start from a source, traverse to a mirror, reflect off the mirror and traverse back to the source. This is experimental evidence for the universal constant value of the speed of light.
In Einstein's Special Relativity, a Frame of Reference is defined in which the two halves of the trajectory of the aforementioned experiment are assigned equal times. This is Einstein's second postulate. Read his 1905 paper.
I think that the GPS-system is very much based upon knowing the one-way speed of light... By knowing where the satellites were when they send their signals and the one-way speed of light your gps can tell you where your are... I am not really a GPS-expert though...
ghwellsjr said:
If you want simultaneity to be universal, then you need to promote the Lorentz Ether Theory in which there is a preferred reference frame, although no one knows where it is.[...]
You have two choices: you can claim that there exists an absolute ether rest state in which the speed of light is exclusively constant in all directions and for which times, distances, and simultaneities are absolute, or you can claim that all rest states are equally valid and define times, distances and simultaneities relatively according to the definition of anyone of those rest states.
I am guessing that the GPS-system is actually treating the frame of the centre of the Earth as a preferred frame... Even though the Earth moves by 30 km per second around the sun, this is not something that have to be accounted for by the GPS-recievers... If you assume that the velocity of light is the same in all directions with respect to the centre of the Earth but not with respect to any other inertial frame you get the correct results... Both for atomic clocks and the GPS-system, treating the centre of the Earth as a preferred frame, seem to give the correct results, in agreement with observations.
  • #72
It is very much based on assuming the one-way speed of light, just as gwellsjr explained. After setting the clocks according, one simply measures what one first assumed. :wink:
I am guessing that the GPS-system is actually treating the frame of the centre of the Earth as a preferred frame... [..]
It treats the ECI frame as an inertial frame (which is not exactly true, but good enough), as defined in classical physics and SR: in any inertial frame the laws of physics are supposed to work. Thus GPS should also work on Mars, using the centre of Mars frame. Note that also corrections are used for gravitational potential.Harald
  • #73
Harald
Ok I've had enough of this overly strong claim. What about slow clock transport rather than light based clock synchronization? That this comes out the same as light synchronization is a strong physical statement (that uniquely specifies only LET theories that are completely indistinguishable from SR can be true; they must effect all possible physical laws the same way as a spacetime symmetr).
Anyway, by normal standards of logic, slow clock transport is independent of any signal speed, and combined with distance measurement based on e.g. rulers, allows measurement of one way lightspeed.
  • #74
I think that in any theory with a one-way speed of light not equal to c that the net time dilation effect would not asymptotically approach 0 as v approached 0. Whether that has some deep significance I am less sure.
  • #75
Sorry, I don't see the problem here.
First, this discussion relates to the fact that according to SR, for any inertial frame that we may choose, we "assume that the clocks can be adjusted in such a way that the propagation velocity of every light ray in vacuum - measured by means of these clocks - becomes everywhere equal to a universal constant c, provided that the coordinate system is not accelerated".
And slow clock transport doesn't affect that assumption: it doesn't in any way indicate anything "true" or "absolute" about the clock synchronization that we happened to choose. As you certainly know, we can pick any inertial reference frame wrt which we define the speed of light to be equal in both directions; that includes frames in which all our "slowly moving" clocks are moving very fast in one direction, and in which the (closing) speed of light relatively to us is very different in different directions. Harald
  • #76
DaleSpam said:
If you have a detector which detects the frequency of the photon then you will measure a Doppler shift. Personally, I think you need to focus on classical physics and not even worry about quantum effects for now. Once your grasp on classical physics is firm then learning QM is feasible.
Well, that's why I asked for your help about the photon frequency.
I know how the Doppler shift works and depends either on the moving source or the moving observer. For Doppler shift of the light we need few successive waves.
It appears that it is not the same for a photon.
I really need to do some reading :)
DaleSpam said:
It is given that it goes from the source at the time of emission to the detector at the time of detection. That distance is not equal to the length of the truck in any frame where the truck is moving, as explained and derived.
Before you pursue this line of discussion any further, spend a little effort of your own. Sit down and take a close look at each step of my brief derivation. Either the derivation is right or it is wrong. If it is right then you have no choice but to acknowledge that the distance traveled by the light is not equal to the length of the truck in any frame where the truck is moving. If it is wrong, then point out the specific error, and post the correct derivation which supports your claim quantitatively.
I promise to read and come with new question or acceptance.
Just one question to give me direction; if we put light source in a middle of a moving truck and detectors on both sides, the path of the light in both directions will be different, right?
Would that mean:
1) both detectors will measure different frequency
or
2) light travels different distance and that distance is traveled:
a) for the same time
b) for different time
3)does both lengths together give the full length of the truck?
[EDIT] the last question is some how incorrect to me...
Thank You, DaleSpam :)
  • #77
You [Harrylin] said:
"It is very much based on assuming the one-way speed of light, just as gwellsjr explained. After setting the clocks according, one simply measures what one first assumed. "
I disagree. SR can be derived from several different sets of assumptions, then confirmed with measurements. One can derive SR making no assumptions at all about the speed of light, let alone constant one way speed. And though hard in practice, in principle one can measure the one way speed of light without implicitly assuming it.
  • #78
Yes.
sisoev said:
Would that mean:
No.
Different time. Remember, light travels at c, so the fact that the distances are different implies that the times are different also.
I don't think so, but I would have to do the math to be sure.
  • #79
PAllen said:
Harald
You don't have to use light to synchronize two remotely located clocks, you can use the slow transport of anything as long as it travels at the same constant speed in both directions. We know that moving a clock from one location and back results in a loss of time compared to the clock that remained stationary so you would have to have three clocks, two that remained stationary and one that made a round trip. Then you could adjust the remote clock according to one-half the loss of time to synchronize the two stationary clocks. This would also require communication from the local clock to the remote clock. It would take a very long time to do this. Why not just use light signals?
But as I say, you could do this with fast moving clocks or fast moving missiles, anything to establish the same time for light or anything to travel both halves of the round-trip in the same time, whatever that time may be.
This will allow you to then establish a Frame of Reference, just like Einstein proposed, but the time on the remote clocks are relative to the definition of that one Frame of Reference. Another set of clocks moving with respect to the first set will have a different definition of time for a second Frame of Reference and they are both just as valid as the other even though they will now disagree on the other one's definition of the one-way speed of light.
This issue is no different than other null experiments to establish a preferred reference frame or to establish an absolute ether rest state. Every inertial state appears the same as any other (they all look like an absolute ether rest state) but they disagree with each other about the definition of the time it takes for light to travel from one point to another where those two points are comoving in relation to the inertial state.
  • #80
Perhaps my reply to Agerhell (he didn't respond yet) wasn't clear enough? But that should not be read on its own, for my reply refers to the explanation that gwellsjr gave in post #23 and the discussion of GPS by Agerhell. "It" refers to GPS, not SR. See my further clarification in post #75 and also gwellsjr's elaboration in post #79.
Summarized in a single soundbite: relativity of simultaneity implies relativity of closing speed.Harald
  • #81
What am I supposed to respond to?
Well if you assume wrong, your GPS will basically tell you that you are at a location that you are not at. Is that the kind of measuring you are referring to? Or are you one of them standing on-a-train-bouncing-light-at-mirrors-looking-at-the-trainstations-clock-kind-of-people?
Well maybe, but if you for an earthbound location imagine that the speed of light at your location is c in relation to some other inertial reference frame than that of the centre of the earth, your up for problems...
  • #82
Agerhell said:
[..] Well if you assume wrong, your GPS will basically tell you that you are at a location that you are not at. [..]
No, if you choose another inertial frame the calculations will only become much more complex for GPS, so that GPS may take too much time to compute your correct location. It's similar to choosing the centre-of-mass frame in particle physics, it's mere convenience.
  • #83
No, if you assume that the speed of light on Earth is c in relation to some other inertial reference frame, for instance that of the sun, you will get the wrong answer. Imagine that you are positioned such that you can see one gps sattelite in a position that is directly in front of the Earth in its orbit around the sun and one satellite directy behind the Earth in its orbit around the sun. Now if you assume that the signal from the satellites travels with a velocity of c in relation to the centre of the Earth you will be able to correctly position a surface in between of the satellites where you must be positioned (you need three satellites to know where on that surface you are). If you instead suppose the velocity of light is c in relation to the sun you will position that surface incorrectly because the Earth is traveling at roughly 30 km per second around the sun. You will think that you are closer to the satellite that is positioned behind the Earth in its orbit around the sun and at a greater distance from the satellite that is in front of the Earth in its orbits than you really are.
I can not really understand how you can think otherwise.
  • #84
The paradox that you sketch is just a misunderstanding of Einstein's train example: a different standard inertial reference system uses a different synchronization of clocks, thus making the speed of light isotropically c in that frame. So it's very simple: if the ECI frame would be preferred for the laws of physics as opposed to the solar frame, then relativity theory would be wrong.
PS: note also that the speed of light "on earth" is not c in GPS calculations; instead the speed of light is made c wrt to the ECI frame, in which the surface of the Earth is rotating. GPS corrects for the speed of the surface of the Earth.Harald
  • #85
You are saying that the GPS-system would work equally well if we assumed the velocity of light to be c with respect to the sun and somehow did something with the clocks onboard all of the gps-satellites so that you would still get the right position at all times no matter where on Earth you are positioned? You are going to have to refer me to some proof of that before I believe you...
I have not been claiming anything ells than that to get the correct result from the GPS system you have to assume that the velocity of light on Earth is c with respect to the centre of the earth. That is also what the ECI frame is based upon, so I do not know who you are arguing with right now...
If you have signals from three satellites you basically know your position at a certain time. The fact that the Earth is rotating is not much of a problem.
  • #86
Do you think that if we do the round trip for the light, we will get the length?
  • #87
Both lengths together gives:
[tex]\frac{L}{1-v^2/c^2}[/tex]
The round trip gives twice that.
  • #88
PAllen said:
Before this thread veers completely into new directions, I thought I would put some numbers and clarifications of the OP experiment. Refer to the picture in the OP.
We have a truck moving fast. At the moment its front passes a light, it flashes. The back of the truck receives the signal at some time and place. A ground observer, B, is standing where the back of the truck passes as it receives the signal. The question was how do they both measure the speed of light to be the same?
We need to add a lot of specificity. Assume some time in the past, we collected identical tape measures and clocks. Now we describe how B and A (a truck traveling scientist) set up to do their measurements.
B) B places a clock where the signal will be received as the back of the truck passes; rolls out tape measure to where the emitter is (carrying a clock) and places clock next to emitter. Assistant stands at this clock to record when the emitter flashes. Scientist walks back to reception point, to await the truck's arrival (where he will record the reception event on his clock).
A) Scientist enters truck with tape measure and two clocks, and waits in back of truck as it gets up to speed. Then leaves one clock at back of truck, carries other to front as he measures the truck. An assistant waits at the front to record emission time according this clock at front of truck. Scientist walks to back of truck to record reception time.
Ok, now for some numbers. All units are light seconds, speed of light is 1 (light second / second), and we imagine we have all the time in the world to walk back and forth many light seconds.
A measures his truck length as 100, the speed of the ground going by as .6 (c). For him, the light took 100 seconds to reach the back and lightspeed is 1.
Now it gets interesting. If everything has been properly set up so that events happen as described at the beginning, then B will measure the distance between emitter and reception point as 50. This is a combination of seeing the truck as length 80, and the fact that the truck will travel 30 between emission and reception. B will measure the time between emission and absorption as 50, getting c for the speed of light. The discrepancy between B's 50 seconds and A's 100 is a combination B seeing A's clock running only 80% as fast as his, but also seeing a large discrepancy between the front and back clocks on the truck. According to B, A's front clock is set 60 seconds ahead of the back clock. So the 100 seconds measured by A is 'really' only 40 of A's seconds. Then since A's clock is only running 80% the rate of B's, this 40 of A's seconds correspond to 50 of B's.
Thank You, for the thorugh explanation, Palen.
However, you got one thing wrong;
the flash is ON the truck
and one thing not taken in consideration;
what if the graphics represent the contracted length of the truck
We should see it contracted from our point anyway.
  • #89
The flash being on the truck makes no difference whatsoever. (What matters is the 'event' of light emission. The motion of the source only matters for doppler effects, which were not part of the original scenario, and completely irrelevant to it).
If the graphics represent the contractel length, the just multiply most numbers by 5/4 (e.g. you don't multipl .6c by 5/4).
In a nushell, both these observations are completely irrelevant to the physics of the scenario.
  • #90
As you probably noticed from the OP, I'm not physicist or mathematician, but I got the same result with a simple graphics.
So, why do we get this result?
Don't you think that it has something to do with not placing the emission point where it belongs, at the source point?
In general, both blue and red shifted lights are "old" lights; the source is either closer or further away from us.
With "old" light we cannot measure distance to the source unless we use its frequency in our calculation. Correct?
Not putting the emission at the place of the source is not in any favour for the length contraction, because I could easily set the experiment with the contracted length of the truck and we would still have different length of the light for A and B.
  • #91
Aren't you sure that we will not enter in an endless need for contraction, PAllen
  • #92
Nope. Actually, don't change any numbers. You gave no dimensions in the OP. I supplied some. If you want to 'start' from the ground observer, use my ground observer numbers. If you want to start from the truck observer, use my truck observer numbers.
In short, the content of your comment is exactly empty.
  • #93
It makes a BIG difference indeed.
It is in direct connection with your measuring tape.
See my comment to DaleSpam (few comments up)
Hope that it will add some volume to my comment :biggrin:
  • #94
sisoev said:
In your previous comment you said:It makes a BIG difference indeed.
Not at all. The motion of the source has nothing to do with the speed of light from the source for any observer. It only affects color of light.
In fact we can have two sources, one on the ground, one on the truck, that both go off the moment the truck passes ground signal. Nothing about my analysis would change. The light from both sources would travel identically for both observers. The only difference between the signals would be color.
Think about this. It is an experimental fact. Until you can accept facts, you must live in fantasyland.
  • #95
You didn't read my comment to DaleSpam, did you?
Why do you use measuring tape? - to measure the truck, right.
But if the light is shifted it won't represent the length of the truck.
As I said, it is "old" light.
To make you picture it out, imagine that you see light from a moving away source - you'll see it red and closer to you than it really is.
But I'm sure you know that. You just cannot connect it with my experiment.
  • #96
The emission point is at the source point, at the time of emission. It just does not follow where the source point moves to later.
The frequency is unrelated to the distance.
In my equations L is the length of the truck in the frame where it is moving with speed v. It is not the rest length.
  • #97
Sorry, you cannot accept reality.
I used measuring tape for an obvious reason. If we are going measure the speed of light, we cannot define distance using light, or light speed will be c by definition. So you need to measure distance some other way.
By virtue of using an independent measure of distance, all of your statements above are simply false.
  • #98
It depends on the setting.
A wrong word order can change the meaning.
The right way to say it for a stationary observer is: The source point is the emission point.
Then if we have to measure the path of the light for the stationary observer, we measure it from the source.
You are the expert here, but if frequency changes because of the changed distance, I thing that it is tightly connected with the distance.
  • #99
Lets cool of a little, PAllen :)
It will help both of us to see the other point more clearly.
  • #100
sisoev said:
e.You are the expert here, but if frequency changes because of the changed distance, I thing that it is tightly connected with the distance....
Frequency doesn't change because of changed distance (1 mile, a billion miles, in either special relativity or pre-relativity physics). Doppler shift, both in pre-relativity physics and special relativity is determined only by relative velocity and angle of source and target (not distance). The only difference is the exact formula used. For 'ordinary' relative speeds they agree.
  • #101
By now you should know that I understand the Doppler shift, DaleSpam.
OK, the next wave arrives later or sooner because of the velocity, not because of the changed by the velocity distance :biggrin:
  • #102
I don't see the distinction you are trying to make here. But I think you mean "stationary source".
Change in distance is speed. The frequency depends on speed, not distance. They are orthogonal.
  • #103
DaleSpam didn't you write in one of your previous posts that from the truck Frame of Reference the light traveled the whole length of the truck and from the ground Frame of Reference it only traveled from initial emission? I believe that is what sisoev is also trying to say and you guys are just going back and forth talking about the same thing. It doesn't matter if the light does 2 or 200 cycles inside the truck, at the end of the day it's still going to traverse the whole length of the truck ACCORDING to the detector inside that FoR.
And yes you can't measure the speed of light with light itself, but what you can measure, and again that is what sisoev has been trying to say the whole time is that there is a difference in the length traversed.
The only thing which has a chance of explaining this "problem" is of course the time dilation as ghwellsjr suggested (or Pallen, too lazy to scroll back) and of course how can sisoev argue against something that explains a problem with itself? That's why in Psychology for instance no one is able to disprove Froyd's theory, because it explains everything, and it has an answer for everything by using itself as that answer.
P.S. By the way, i asked how is time dilation proven? Is it only with the whole clocks running slowly? And in "proven" i mean hard data. Could someone answer that question please?
  • #104
Right, stationary source.
And I'm tired of this loop
We set an experiment to compare the paths of the light for A and B.
Then you say that according to C the path is the same, creating the paradox where the light travels distance shorter than the truck.
So, for A the source is the place of the emission and from there we measure the path of the light.
OK, but I'm sure that in the context it was quite clear what I mean.
  • #105
Muons wouldn't reach the ground from the upper atmosphere without time dilation. Muon accelerators wouldn't work based on slow muon half life without time dilation. Flying accurate clocks in airplanes shows time dilation.
