- #281
PeterDonis
Mentor
- 46,647
- 23,201
Q-reeus said:Agreed that if we define LET such as to always make identical predictions to SR, it is nonsensical to argue one over the other. As both make strict use of the Lorentz transformation that seems settled.
Ok, good, we have agreement that far.
Q-reeus said:But the crux of my argument is the very existence of the phenomenon of vacuum breakdown implies a situation specific breakdown of LT's which is a dilemma for both.
And the crux of *my* argument is that this is incorrect. The phenomenon of vacuum breakdown can be described entirely by Lorentz-invariant quantities. Specifically: the EM field that causes the breakdown is described by the EM field tensor, which is a covariant geometric object; the breakdown threshold E field vector is described by contracting that tensor with the 4-velocity of the field source, which is also a covariant geometric object. The phenomenon is perfectly consistent with Lorentz invariance.
Q-reeus said:'Pumping energy in' = application of an Ecrit for some minimum duration - by whatever means.
"Minimum duration" implies a frame has been specified. What frame? Obviously the rest frame of the source. If you rephrase this in properly covariant terms, it will read: "the EM field tensor has a particular form in the rest frame of the source, for a minimum interval of the source's proper time." And this is expressed, as above, by contracting the EM field tensor with the 4-velocity of the source.
Q-reeus said:You keep saying breakdown is defined in the apparatus/source rest frame. But on what basis other than sheer assertion?
On the basis that the breakdown is determined by contracting the EM field tensor with the source's 4-velocity. IIRC this was described in the paper you linked to, but not in precisely those terms, so the point may not have been clear from the paper.
Q-reeus said:In what way can the vacuum 'know' that a field of given strength E is owing to a source that is moving or static wrt any given lab frame (apart from B field which is not germane to vacuum breakdown issue)?
Because it's not anything associated with the "vacuum" that determines the breakdown; it's the contraction of the EM field tensor and the source's 4-velocity, both of which are perfectly well defined in terms of actual physical objects that can be observed.
Q-reeus said:If you can't see any issue by now then I guess it's quits from me. No point bashing ones head against a brick wall.
I see the "issue" perfectly well, and I've described in more detail above why it's not actually an issue.
