Stirring Coffee Effectively
  • Thread starter Thread starter Hornbein
The discussion revolves around the effectiveness of stirring coffee, particularly in relation to sugar dissolution and the resulting taste. Participants explore various methods of stirring, the physics involved, and personal preferences regarding coffee preparation and consumption.
  • Some participants suggest that stirring coffee vertically may be more effective than swirling it horizontally to achieve better sugar distribution.
  • There is a debate about whether the problem of sugar settling at the bottom is similar to stirring paint, with some participants retracting their earlier opinions on this comparison.
  • Some argue that sugar in coffee may not fully dissolve, leading to a suspension rather than a solution, and this could explain the sugar settling issue.
  • Participants express differing opinions on the taste of coffee, with some stating that sugar is necessary to make it palatable, while others believe high-quality coffee does not require sugar.
  • There are discussions about the optimal temperature for tasting coffee and how it affects flavor perception, with some noting that flavor improves as coffee cools.
  • Some participants question the plausibility of sugar settling in a real-world scenario and whether adequate stirring can prevent this.
  • There are personal anecdotes shared about preferences for hot versus cold beverages, with some participants expressing a strong dislike for hot liquids.
Participants do not reach a consensus on the effectiveness of different stirring methods or the necessity of sugar in coffee. Multiple competing views remain regarding the physics of stirring and personal taste preferences.
Participants acknowledge that the discussion involves subjective experiences and preferences, which may not align with scientific principles. The effectiveness of stirring and the dissolution of sugar may depend on various factors, including stirring time and temperature.
Hornbein
I noticed that the stirring of coffee was ineffective. There's always a layer of too-sugared liquid near the bottom. So...stir it vertically instead of swirling the coffee horizontally.
There is a whole discussion in coffee media if one should swirl or stir (but is mostly related to getting an homogeneous espresso and is it not about sugar).
Maybe, you need a semicircular plate, attached to a rod that is on the axis of the circle. Push it down, rotate the stick and lift it up to generate an efficient vertical circulation.
See?! Another contender for the geeky trophy! :woot:
Is the coffee problem different to stirring paint in an open can ?
Hmm. No. Admittedly not. I retract my opnion.
And technically it is a physics problem.
Altough even if the problem is technically a valid STEM problem I’m sure you’ll agree it can get out if hand!
Still my geeky trophy is just a joke
Incomplete premise.
Even if you stir the coffee until it is completely homogenous, it will still end up with sugar on the bottom. The sugar does not always completely dissolve, so it settles on the bottom over time.
Sugar in liquid is more typically a suspension, rather than a solution.
Why do you put sugar in your coffee!
Because coffee is objectively disgusting-tasting (caffeine-rush-notwithstanding), and it is simply a matter of how much sugar and milk one need to put in it to make it tolerable.
In a cafe, James Bond is always asked if he would like his coffee stirred or shaken.
That is difficult to believe.
Because it is an inferior coffee. Adding and dissolving sugar in the brewed coffee just makes this brew sweeter in an often/sometimes ineffective attempt to cover the poorer flavor. But this is at least in part my opinion.
That kind of understanding may change once you learn to roast high quality coffees yourself and to brew it. NO sugar needed.
Why?
To get all the sugar dissolved in a liquid requires a sufficient stirring time as well as making sure you don't oversaturate it (in which case it may never fully dissolve) - neither of which are guaranteed in a real-world scenario.
Hornbein
For those who brew good coffee and add no sugar, stirring is almost entirely unnecessary.
I never drink hot liquids.
OK, once a year, in Cuba, I have a Spanish Coffee.
I do drink iced coffee occasionally, but it's so sweet and milky it might as well be a milkshake.
But even high quality coffees are still at the far end of my scale of tasty.
I think it may be a genetic thing - like Brussel's Sprouts and coriander.
DaveC426913 said:
Why?
A coffee drinker typically will not oversaturate his coffee with sugar. As we were taught, sugar is a compound (or two compounds) soluble in water, or close enough, hot brewed coffee. Must we try to dissolve one teaspoon of sugar (sucrose which we can buy from a grocery store in bags) into one cup of water with mixing for two or three minutes until clear, and cover this and watch for undissolved settled material over some few number of hours?
Borek, do you have something to say about this?
OK it could be genetic. In case you know somebody locally to you who buys and roasts green unroasted beans at home and brews and drinks what he roasts, check for yourself about how the brewed coffee tastes and smells.
Depends on what criteria you want to satisfy.
Hornbein's verdict is that the last sips are more sugary. So in a real world scenario - yes - it is entirely plausible that a true solution is not achieved in a realistic timeframe.
I am still hoping Borek will tell us what we want to know and understand.
Something I very clearly notice is that HOT coffee (what I brew , at least) has less flavor and the flavor level and quality improves as it cools. When I am half way through, flavor becomes richer, and sweeter. I really do not believe this observation supports what Hornbein said how you explain it about it. I believe that the brew's resting and temperature drop affects how we find it.
I should also add, I never add any sweetener to the coffee I drink.
edit: Rewording for compositional reliability
Ginger tea is best served hot.
Something I very clearly notice is that HOT coffee (what I brew , at least) has less flavor and the flavor level and quality improves as it cools. When I am half way through, flavor becomes richer, and sweeter. I really do not believe this observation supports what Hornbein said about it. I believe that the brew's resting and temperature drop affects how we find it.
Definitely true. It has been found* that, objectively, the best temperature for tasting things is luke warm. (But that does not mean it is subjectively the most enjoyable).
Regardless, the two phenomena - optimum temp and adequate stirring are not mutally exclusive factors.
I'm not sure I get your stance. Are you asserting that - in a real word scenario, such as the OP's - it is implausible that sugar may settle to the bottom of a coffee cup? You won't be convinced unless that is proven to your satisfaction ?
*citation needed
Yes. And I don't drink ginger tea. Because it is hot.
As I type this, I am out in my Dave Cave smoking a stogie. The temp is below zero (Celsius). I have three heaters pointing directly at me, so it's warm enough for me. And I am still drinking an iced beverage. In a double-walled thermos so it doesn't warm up.
The only time I am ever caught drinking a hot liquid is if I am out in the snow for hours at some winter event, and then I will partake of the occasional hot chocky.
Also, I'm not fond of soup for the same reasons.
Gazpacho? Tarator?
  • Agree
Water can take up to about twice its volume in dissolves sugar to saturation. Syrups are quite much just about saturated sugar in water.
Honey may develop crystals as the sugars come out of solution, but that is most likely some other chemistry as the water has not evaporated from the jar.
Surface area is important. A cube of sugar presents less surface area to the water than a powdered form. From the sugar cube surface, there is a gradient of concentration of dissolved sugar molecules to far away fresh water. Stirring will bring fresh water to the sugar cube surface enhancing the rate of dissolving, but a gradient nevertheless still exists.
A few stirs of the coffee will not be enough to dissolve all of the sugar cubes, which will then settle to the bottom of the vessel, where upon the gradient of dissolution is from bottom to top, leaving the bottom more sweeter than the top.
If you stir in sufficient sugar, to saturate hot coffee, then you must expect to initially add more solid sugar than is needed, or it will not achieve saturation while stirring.
As the coffee then cools, and the Ksp falls, sugar will continuously precipitate out of solution, adding to the initial excess of solid sugar.
I feel sorry for those unfortunate people, who add sugar to make their poor quality coffee drinkable. Visitors to Australia are often surprised by, and comment on, the higher quality of the coffee available. I guess that partially explains why tourists, when they first arrive here, are in the habit of adding sugar to their coffee. It also suggests that Australia competes on taste and smell, while the rest of the world is competing on profit margin. I have never attended a "Star-bucks", but it seems like an excellent name, for selling shares to US investors.
If you must for some reason sweeten your coffee with sugar then either make simple syrup like bartenders do (much harder to dissolve sugar in a cold drink) or warm up the crème/milk and dissolve it there first
Or if you use a French press like any one with self respect does, dissolve it in the hot water before pouring on the grounds
  • · Replies 27 ·
  • · Replies 22 ·
