Benjies
- 54
- 28
- TL;DR Summary
- I've been struggling to wrap my brain around blade angle with relation to ducted airbreathing engines, as we attempt to avoid the speed of sound at all points across the blades.
Hello! My background in propulsion is extremely lackluster with airbreathing engines, so any help is appreciated with the following questions. I understand blade pitch is highly variable for turbofans which operate near the speed of sound, to avoid any localities on the blades reaching the speed of sound. I suppose my confusion is with how blade angle relates to thrust. I have multiple questions, please feel free to bite off a specific question, or answer all of my questions holistically if a key concept is being missed:
1. I believe turboprop engines vary blade pitch based on Mach number. At starting conditions, do turboprops minimize blade angle relative to the shaft to maximize the centripetal acceleration of flow? (e.g., on the flight line, for liftoff, are blade angles at close to zero degrees with respect to the shaft).
2. Turbofans vary blade angle such that the blade angle is maximized near the blade tips (so that the acceleration imparted to air at the blade tips is minimized to avoid the speed of sound). Somewhat related to question 1, does increasing the blade pitch decrease thrust in general? I picture a blade at zero angle of attack relative to the shaft imparting extremely high changes in pressure (which would then expand and give great thrust), whereas a blade that is highly pitched (such as the end of a turbofan blade) imparts very little work to air that flows around it, thus it contributes very little to thrust.
I see a dichotomy: Avoiding the speed of sound seems to pidgeon-hole us into designing engines which are limited in performance. Ironically turbofans obviously have terrific specific impulses and efficiencies. Maybe I'm babbling. But the general rule of thumb seems to be "work the air as hard as you can until you hit the speed of sound on the blades- then, chill out and increase your blade pitch"
Thanks all and have a good weekend (after tomorrow).
