Surface current of superconducting sphere in magnetic field
The discussion focuses on the behavior of surface currents in a superconducting sphere placed in a magnetic field, emphasizing the continuity of magnetic field components. It highlights that the magnetic field inside a superconductor is zero, leading to a surface current confined to the sphere's surface. The derived equation shows the relationship between the surface current density and the external magnetic field, resulting in a specific expression for the current. An additional note suggests that a factor of 1/3 may be relevant due to the spherical geometry. The conversation concludes with equations relating magnetization and magnetic fields in the context of the discussed model.
Jan05
Suppose a sphere of superconductiong material is placed in a uniform magnetic field ##\mathbf{B} = B \, \hat{\mathbf{z}}##. What is the induced surface current distribution?
##\mathbf{B}_{above} - \mathbf{B}_{below} = \mu_0 (\mathbf{K} \times \hat{\mathbf{n}} )##
My idea was to use the continuity of parallel components of the magnetic field and the spherical coordinate system. Because the magnetic field in a superconducting material is 0 and the current is completely confined to the surface, there only is a ##\mathbf{B}_{above}## component. The equation then reduces to ##\mathbf{K} \times \hat{\mathbf{r}} = B / \mu_0 \, \hat{\mathbf{z}} ##. Then evaluating components and using ##\hat{\mathbf{z}} = \cos \theta \, \hat{\mathbf{r}} - \sin \theta \,\hat{\boldsymbol{\theta}}## we obtain ##K_\varphi \, \hat{\boldsymbol{\theta}} = B / \mu_0 \sin \theta \, \hat{\boldsymbol{\theta}}##. So ##\mathbf{K} = B / \mu_0 \sin \theta \, \hat{\boldsymbol{\varphi}}##.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
