Tangential speed problem with a hard drive disk
To find the tangential speed of a point on a hard drive disk rotating at 7200 rpm, first convert the diameter from inches to meters, which gives a radius of 0.0889 m. The angular velocity should be calculated in radians per second by multiplying the rpm by 2π and dividing by 60. The correct formula for tangential speed is then applied using the radius and the angular velocity. The initial calculation resulted in an incorrect speed of 9601.2 m/s, while the correct answer is 17 m/s, highlighting the importance of unit conversion and proper application of formulas. Accurate calculations are essential for solving physics problems effectively.
Spartan301
A computer hard drive disk with a diameter of 3.5 inches rotates at 7200 rpm. The “read head” is positioned exactly halfway from the axis of rotation to the outer edge of the disk. What is the tangential speed in m/s of a point on the disk under the read head?
Objective: Find tangential velocity on disk.
Battle plan:
Convert inches to meters
Find the distance to the axis
Find the angular velocity by dividing the angular displacement by the time.
Convert from an angular speed in rad/s to a tangential speed in m/s by multiplying the angular speed by the radius of rotation.
Outcome:
0.0889m/4 = 0.022225 m
7200r/min x 60 = 432000 r/s
432000 r/s x 0.022225 m = 9601.2 m/s :(
The key says the answer is 17 m/s.
I would so appreciate any help on this problem. Thanks!
-Tom
Battle plan:
Outcome:
-Tom
Hi Tom,
Your "battle plan" is just fine. The only problem is that you should divide by 60. (The units of minutes are in the denominator.) Also, on the last line, there is a factor of 2\pi need to put the angular speed in radians/s.
Thank you!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
