- #36
Andrew Mason
- 7,780
- 475
1 m = ct where c = speed of light in a vacuum and t = (1/299792458) seconds. Since a second is defined as 9,192,631,770 periods of the radiation (one period = T) emitted by caesium-133 in the transition between the two hyperfine levels of the atom's ground state, with the atom at Earth sea-level and at rest (ie. at 0K), the definition of 1 m is not time, but is really a distance:Orodruin said:This is wrong. The meter is defined as 1/299792458 s (which happens to be a very suitable unit for measuring the spatial size of many things), you never measure the speed of light.
1 m = cT(9,192,631,770/299,792,458) = 30.66331898849837 times the wavelength of this radiation from the caesium-133 atom.
One could argue that by making the geometry pretty you are obscuring the physics. Every inertial observer has his own coordinate system where time and space are distinct physical quantities. Time is measured by clocks and distance is measured by the separation of the end points of sticks. The distinction between time and space is always maintained for each inertial observer.We never said it is wrong, it is just obscuring the geometry. By introducing and using ct everywhere you are essentially doing the same, you are just calling your time variable with a longer and more cumbersome name. And of course you can pick any units you like, just as you can chose to measure one spatial direction in feet and the other in light years. It just obstructs the symmetry and make the coordinate transformations awkward.
It is just that they are not absolute: different inertial observers will disagree on time and space measurements between events because they disagree on simultanaeity of events.
##m = E/c^2## means that ##m \propto E##. By setting units for c = 1 that still does not make m and E the same physical phenomena. That fact that mass or inertia can be converted into energy does not make them equal. Otherwise there would be no meaning to the "conversion".This is again a confusion. Mass and energy are very similar concepts, with mass simply being a measure of an objects rest energy. In relativity, it is very easy to see that the rest energy is also the inertia of the object in its rest frame.
?? This again is confusing. There is the concept of inertia and the concept of rest mass. Rest mass is constant for all observers. Inertia, or the ratio of ##\vec{F}/\vec{a}## is another concept of "mass", although it is generally frowned upon now because of the confusion with 'rest mass'.There is no other concept of mass in SR, the inertia of a moving object is a quantity that depends on the direction of acceleration
AM
