Tension and acceleration of a sled?
To determine the minimum rope tension required to move a sled with a mass of 336 kg, the static friction coefficient is 0.579. The discussion suggests starting by calculating the force needed to overcome static friction using the formula Ff,s = μs * Fg. After finding this force, it can be divided between two ropes pulling at an angle of 25° from each other, with each rope making a 30.1° angle with the horizontal. The approach involves treating the problem in two parts: first finding the force at angle θ, then distributing that force between the two ropes. Understanding these steps is crucial for solving the problem effectively.
TheNeezoMan
A heavy sled is being pulled by two people as shown in the figure. The coefficient of static friction between the sled and the ground is μs = 0.579, and the kinetic friction coefficient is μk = 0.435. The combined mass of the sled and its load is m = 336 kg. The ropes are separated by an angle φ = 25°, and they make an angle θ = 30.1° with the horizontal. Assuming both ropes pull equally hard, what is the minimum rope tension required to get the sled moving?
T-mg=ma (I think...)
So, say person 1 exerts tension T1 and person 2 T2, so T1=T2=T ...So they both exert a force of 2T.
I am not even sure if this diagram is right?
I also think wemust must find Ff,s = μs * Fg
I don't know where to go from here or I if this is where I should even be
[/B]
I think you'll want to start by seeing what single force applied at angle θ = 30.1° will get the sled moving. After that you can deal with how to divide that force between two ropes with the given angular spread.
Likes TheNeezoMan
If I am going to divide an angle wouldn't it be φ = 25°?
Dealing with φ will come later. Treat this as two separate problems: 1) Find the force required to move the sled if the force is applied to the sled at angle θ; 2) Take the force from (1) and split it between two ropes separated by angle φ.
Likes TheNeezoMan
