Test your knowledge of inertial forces
In summary, the conversation revolves around the concept of inertial forces and their role in the system described. One participant suggests that the forces exerted by the masses on the bar are not truly inertial forces, but rather interaction forces that obey Newton's 3rd law. Another participant agrees, stating that these forces come from internal stresses in the bar and are not directly related to the masses' inertia. However, it is acknowledged that these forces may be equal to the inertial forces on the masses in certain situations. Overall, there is a disagreement on the terminology used but a general consensus that gravity does not affect the small-amplitude oscillations of the system.
  • #71
D H said:
You are talking about a tetherball physics problem. That is not the correct setup for this problem.
The cone would be a meaningless complication were this the correct setup; you might as well just have a vertical pole.
That's my point, it is a tetherball problem only if the angular velocity is above the limit discussed earlier, and it appears to be in this case (though the constraints have emerged somewhat fitfully). That is inconsistent with the description that the cone is providing the angular velocity. So that's the claim I'm making-- the problem is internally inconsistent.
But more to the point, the numbers could easily be fixed up to reduce the normal force to zero and be only at the boundary of the tetherball problem. But in any real experiment where the cone is providing the velocity (I presumed by static friction, because otherwise you'd need no string), there would need to be some normal force to get that friction. So the angular velocity could never really reach the limit, only very close to it, especially once air resistance is thrown in. We're not disagreeing, the problem does not succeed as any kind of "trap" for anyone who understands inertia and forces.
  • #72
It is the tetherball problem. It just wasn't well specified.
  • #73
Oh dear J'adoube.
How very embarrassing
:blushing:
I took this problem at face value and simply posted the values provided. Normally I would have reworked the problem completely with different values.
It seems there is an arithmetic error in the book
More in a moment, but I do not want to detract from the very important point of mechanics the authors made, since their analysis appears to be correct.
Following the problem statement I posted the length of the string as 2m and the mass of the particle as 2kg.
I agree with the author's analysis and have worked through the equations to their solution.
I can only obtain their solution equations for R and T if the length of the string (L) is 1 metre and the mass is 1 kilogram.
  • #74
What "important point of mechanics" are you talking about? It looks like a perfectly routine first-year problem to me, I see no profound messages here. Certainly nothing revealing about inertia-- you'll note that the critical angular velocity where the normal force goes to zero doesn't even depend on the mass of the object.
  • #75
pardon?
  • #76
In Studiot's favor, this underlying message is a very important one, one that when ignored has resulted in loss of life, mission failure, and all other sorts of mayhem. It is one part of the hot button topic in the modeling and simulation world for the last five to ten years. That hot button topic is "simulation verification, validation, and accreditation" (google that exact phrase). A big part of this is "verification, validation, and accreditation of simulation models" (you can google that exact phrase, also).
Suppose that you have been assigned to develop a simulation of a Rube Goldberg device. Being a good lazy software engineer, you do not want to develop from scratch a physical model of each one of the components in this Rube Goldberg contraption. Suppose one part of this contraption involves a tethered ball on a rotating cone, and suppose that your corporate suite of physical models contains a very nice model of such a device. So you just plug this existing model into your simulation without checking to see if that model truly is applicable to the problem at hand.
Now if you had just read the fine documentation on this model you would have come across the assumptions and limitations section that clearly stated that this model is suitable for small rotation rates only. The authors of that package did not test whether the normal force was directed inward because such a situation could never arise in the original application of the model. With no way to validate that test, they intentionally elected not put the test into their model.
Suppose the cone in your tethered ball on a cone in your Rube Goldberg device can spin up to a high rotation rate. Your simulation does not cover this case so your sim does not show the damage that ensues when the cone spins out of control. Who is at fault? Well, you are, or whoever accredited this model for use in this new simulation. That freebie model should never have been used as-is.
  • #77
Studiot said:
pardon?
Which part of that did you not understand?
  • #78
Even so, the simple analysis yields a normal force of zero, or negative, in the inappropriate situations. That's something the user should notice if they are serious about what they are doing. In other words, it doesn't require some deep appreciation for the mysteries of inertia, it just requires that someone has a clue, an interest in actually mastering their own craft rather than just faking their way through. The lesson is true, we all must constantly ask ourselves "does this make sense" at every stage of a calculation-- but that goes almost without saying for anyone who has done calculations and wants them to mean something.
  • #79
Although, if the ball is attached to the cone, as was stated, then a negative force is appropriate and makes sense.
  • #80
Exactly. So one must always know what one is doing, but the forces come out what they would need to. It's much like with computer programming-- don't blame the computer when it does what it is asked to do, the user has to make sure they are posing the problem they think they are posing, so the "does this make sense" test must be applied often. (By the way, the problem is more interesting if the mass is hung from a string. It's hard to tell, the language used is very vague, but it looks like there is supposed to be a string, despite the use of the term "attached"-- it is attached by a string? If it hangs from a string, but comes to equilibrium against the surface of the cone via friction and the rate of the cone's rotation, then it is only "attached" to the side of the cone for the slower rotation-- for rotation past the critical limit, the mass will begin a very chaotic stick-slip kind of motion that would be very difficult to analyze.) Anyway, the problem was supposed to show us how to separate "real" forces from "inertial" ones, and that I would say is a complete red herring here, because no one needs to invoke inertial forces at all, though they may certainly choose to use that language for the ma term if they are clear about it. All the same, massless objects never have inertial forces, so the whole idea that there would be inertial forces on the massless string (which is where this all started) is clearly wrong.
  • #81
While it might be simple to see the problem in this simple case, seeing the problem in a complex system is, well, complex. Seeing the problem that will lead to loss of life, mission failure, or some other catastrophe ahead of time is getting harder and harder ss systems become ever more complex. Failing to see the problem led to the crash of the initial flight of the Ariane 5, the loss of the Mars Climate Orbiter, the crash of the Mars Polar Lander, the failure of the DART (Demonstration of Autonomous Rendezvous Technology) mission, the loss of Milstar-2 F1, two Shuttle flights, and others, and that is just in the aerospace field.
