The body slides off an inclined plane
Adeopapposaurus
The body slides off an inclined plane with an inclination angle of α = 60°. After t = 2s, the body speed is v = 14.7 m/s. Find the friction coefficient f. The initial velocity of the body is 0 m/s and the gravity acceleration g = 10 m/s^2 .
F = f * N
F = fmg*cos(α)
ma = mg * sinα - fmg * cosα
a = g (sinα-f * cosα)
v = g*t(sinα - f * cosα)
14.7 = 10 * 2 (sin60 - f * cos60)
f = 0.26
Can someone please check if my solution is correct? I'd really appreciate that.
Looks right.
Likes Adeopapposaurus
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
