The Equivalence Principle as a Starting point of GR
In summary, the conversation discusses the concepts of relativity, the equivalence principle, and the implications of the equivalence principle on our understanding of gravity. It explains that in classical physics, gravity is seen as a force acting on massive objects, but in general relativity, it is understood as a manifestation of spacetime curvature. The equivalence principle, which states that the local effects of gravity are the same as those of being in an accelerating reference frame, is a fundamental difference between gravity and other interactions. It also allows us to separate the effects of gravity into "removable" and "non-removable" components. The conversation also touches on the ideas of unifying the four fundamental forces and the search for a theory of quantum gravity.
  • #36
epovo said:
Do you mean that each inertial frame may have its spatial coordinates rotated in its own way, giving different coordinate values but the same magnitude to the observed acceleration vector?
If I understand your point, it is that rotating a coordinate system 90 degrees to the right would mean that an "eastward" coordinate acceleration becomes a "northward" coordinate acceleration -- different coordinate values but the same magnitude.
No, that is not what @PeterDonis has in mind. Peter's point applies to "boosts" of a coordinate system.
Consider, for instance a "rest" coordinate system where an object with a 1 gee proper acceleration has a 9.8 meter/sec^2 coordinate acceleration. Now boost to a coordinate system where the object is moving at c minus 1 meter per second. The object still has a proper acceleration of one gee. Wait for one coordinate second and look at the velocity again. It cannot be as much as c. The coordinate acceleration in this frame is sure to be less than 1 meters/second^2 (actually, a lot less).
Likes epovo and haushofer
  • #37
I understand now. I never thought of that! Thank you
Likes jbriggs444
  • #38
fog37 said:
Thanks PeterDonis. I am processing.
So gravity is a force in Newtonian physics but according to GR, which is the best theory we have about gravity, it is not a force anymore (but originates from the curvature of spacetime). I know physicists are trying to unify the four forces of nature (weak nuclear force, strong nuclear force, gravity, electromagnetic force) with the weak nuclear and electromagnetic one already being unified...But what happens with gravity now since it is not a force anymore and is explained/tied to this geometrical framework?
Thanks for any insight.
I thought this question was a very insightful observation. Gravity is a manifestation of mass in the same way that electromagnetism is a manifestation of electric charge and the strong force a manifestation of color charge. So even though it is not a force, it is the result of a fundamental property of nature.
  • #39
The boost you are talking about should be basically a change of inertial system from the "rest" coordinate system. Which are the corresponding transformations for the coordinate acceleration of the object ?
  • #40
The relativistic velocity addition rule.
  • #41
Using that does it result the coordinate acceleration of the 1 gee proper acceleration object is different in the two system of reference ?
  • #42
Yes.
  • #43
The flaw in this argument is that in GR the source of gravity is not only mass but any kind of energy, momentum and stress. Also in electromagnetism it's not only electric charge but also electric current distributions (on a fundamental level also the magnetic moments of particles due to spin).
  • #44
I think it's
$$ a = g ( 1 - v^2/c^2) ^ {3/2} $$
  • #45
epovo said:
I think it's
This is true in one dimension, when the acceleration is parallel to the velocity.
If we let ##\alpha## be the magnitude of the proper acceleration, ##\vec{v}## be the coordinate velocity, ##\vec{a}## be the coordinate acceleration, ##\gamma = 1/\sqrt{1-v^2/c^2}## be the gamma factor, and let ##a = ||\vec{a}||##, we can state:
In the parallel case ##\alpha = \gamma^3 \, a##
In the perpend caase ##\alpha = \gamma^2\,a##
In the general case we can write:
$$\alpha^2 = \gamma^4 \, (\vec{a}\cdot \vec{a}) + \frac{\gamma^6}{c^2}\,(\vec{v}\cdot \vec{a})^2$$
see [link]
I've added a "missing" factor of c^2, the original assumed c=1
In one spatial dimension, ##\vec{a}## and ##\vec{v}## are parallel, so we can write ##\vec{v} = v \, \vec{x}## and ##\vec{a} = a \, \vec{x}## . Thus we have ##\vec{a} \cdot \vec{a} = a^2 (\vec{x} \cdot \vec{x}) = a^2## and ##\vec{v} \cdot \vec{a} = v \, a##, and the above simplifies to
$$\alpha^2 = \frac{a^2}{(1-v^2/c^2)^3}$$
which implies ##\alpha = \gamma^3 \,a##
When ##\vec{a} \cdot \vec{v}=0##, i.e. the acceleration is perpendicular to the velocity, we have instead
$$\alpha^2 = \frac{a^2}{(1-v^2/c^2)^2}$$
which implies ##\alpha = \gamma^2 \, a##
Likes epovo, vanhees71 and Ibix
