The motion of a skateboarder along and above a ramp
The discussion revolves around the motion of a skateboarder on a ramp, focusing on calculating velocities and understanding energy conservation. The skateboarder starts with a speed of 7.2 m/s and experiences a deceleration of -6.1 m/s² before reaching a height of 1.2 m at event E2. There is confusion regarding the maximum height reached (E3) at a speed of 4.1 m/s and whether mechanical energy is conserved up to that point. The lack of an angle complicates the use of projectile motion formulas, leading to a suggestion to utilize energy equations instead. Clarification on the skateboarder's direction at maximum height and the need for a diagram are also highlighted.
StrugglingStudent123
A skateboarder starts at the bottom of a ramp (E1) with a speed of 7.2 m/s. She rolls up the ramp, slowing down with an acceleration of -6.1 m/s², and finally leaves the end of the ramp (E2), which is 1.2 m above the ground. She travels through the air, reaching a maximum height (E3—this is made as an event for practice purposes) with a speed of 4.1 m/s at a height of 1.7 m. She lands on the top of the next ramp (E4), which has a height of 1.0 m. She then rolls down that ramp, speeding up with an acceleration of 6.5 m/s² till the end of the ramp, which is 2.5 m long (E5).
I need help with this one question: what is the velocity at event 2
the big 5 equation, uniform motion and projectile motion
I have tried to use the projectile motion to find Vx and Vy, however since the angle isn't given, I don't think this problem can be solved with only motion formulas (I did solve it with energy formulas).
Welcome to PF. The problem statement is confusing to me, especially this part:
Is there a diagram that goes with this problem? You can upload it using the "Attach files" link below the Edit window. And if that is her "speed" at her maximum height, which direction is she traveling at that point?
Also, for your Relevant Equations, are there any Energy equations that you think might be pretty handy? :wink:
StrugglingStudent123 said:
Homework Statement: A skateboarder starts at the bottom of a ramp (E1) with a speed of 7.2 m/s. She rolls up the ramp, slowing down with an acceleration of -6.1 m/s², and finally leaves the end of the ramp (E2), which is 1.2 m above the ground. She travels through the air, reaching a maximum height (E3—this is made as an event for practice purposes) with a speed of 4.1 m/s at a height of 1.7 m. She lands on the top of the next ramp (E4), which has a height of 1.0 m. She then rolls down that ramp, speeding up with an acceleration of 6.5 m/s² till the end of the ramp, which is 2.5 m long (E5).
Relevant Equations: the big 5 equation, uniform motion and projectile motion
It is unclear whether mechanical energy is conserved up to E2. If it is, the state at E3 is overspecified. (Indeed, based on the other information the height should be 1.78m.)
I suggest working backwards from the E3 information.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
