Lnewqban
- 2,335
I fully understand that.haruspex said:That diagram is not a FBD. If you want to mix forces and accelerations in one diagram you need to discriminate them.
That diagram is not a FBD one, it is simply a way to quickly visualize the net acceleration (g-a) that the CM is experimenting at the initial instant of lift.
The three minutes allowed time is not enough for calculations, just for a quick reasoning, it seems.
The reason behind that crude visualization, which intentionally leaves the rotational acceleration out, is to conclude that the additional upward force causing acceleration a is making the object "lighter".
At the same time, ...
... At the same time, the pivot point can't receive the full magnitude of that additional force because the CM is moving up at the same time the rotation is happening.haruspex said:But this does not lead to ##N=\frac 12m(a+g)##. The stick is not only rising at an increasing rate but also rotating at such, so there must be a net torque (anticlockwise in the diagram). Hence ##F>N##.
I don't understand that.haruspex said:##a## is an acceleration, but what is ##g## here? Nothing is accelerating at g.
Isn't the CM always potentially accelerating at g?
If considering the length/height 3/1 proportion shown in the diagram, what the correct answer should be, according to your reasoning?
