The Peripatetic Albert, Round 3
  • Thread starter OneEye
In summary, the conversation discusses the concept of Special Relativity and how it can be applied to explain the curious observation of being able to change the orientation of the entire Earth simply by turning the steering wheel of a car. The conversation also touches on the idea of acceleration and its relevance to the principle of relativity, and how it can be mitigated by the principles of mass and force. It is also mentioned that General Relativity must be used to evaluate questions of acceleration.
  • #36
ostren said:
Well, you might know it's you who is accelerating, or you might equally presume you have encountered a gravitational field; but in either case, you will not be able to make the unequivocal determination that you are "truly in motion". That last was the only conclusion that I was countering.
That seems like a contradiction in terms - if you are accelerating, you must be moving. Can you give me an example of where you might be accelerating and not be moving?
  • #37
Well, there is of course the obvious case of you being in deep intergalactic space and you feel a tug of acceleration, but it could just as readily be DEceleration that you are feeling... which leaves you stopped. But that doesn't answer the challenge well enough. The truth is that no object can categorically be deemed to be in absolute motion; only relative motion makes sense, for absolute motion implies an absolute preferred frame of reference, which has been shown to be pure myth. The relativistic explanation holds: any tug of acceleration felt could just as easily be a passing gravitational field, for no astute study of the behavior of light can betray otherwise.
  • #38
But, when I feel the tug of acceleration, I can now say I know I am moving. I am either speeding up or slowing down, but I am moving.
  • #39
Are you? I think not. With respect to what reference are you moving? Unanswerable! The only answer is the relativistic one: there's no such thing as unequivocal motion. This is verified by light's behavior.
  • #40
Wrong. If you feel acceleration that you know you caused (by hitting your engine fire button or turning your steering wheel), you can measure that acceleration and use it to calculate a change in velocity based on the assumption that you were at rest prior to the acceleration. Arbitary rest frame? Certainly, but that's Relativity!
  • #41
Devil advocate :
Someone fastidious could say : how do you know this is not also due to a gravitational wave ? Not solely due to your engine ? Imagine you have been fooled all your life by a deamon sending the right gravitational wave at the right instant you turn the engine, so that you never noticed anything wrong in the calculations of fuel consumption...
  • #42
geometer said, "If one system is accelerating, even uniformly, with respect to another system it is no longer an inertial system, and you should be able to detect acclerations and thereby determine who is really moving."
The word "really" in the above citation is all that I was countering. There's never much dispute about relative motion. :rolleyes:
  • #43
humanino said:
Devil advocate :
If the demon's acceleration is in the same direction as the engine, you just go faster, but if you burn the engine, you consume fuel. If the demon's acceleration is exactly equal to, but opposite that of the engine, you don't accelerate so the question is moot (but you still burn the fuel).
But, looking at the bigger picture, who cares what causes the acceleration? In fact, the whole point behind general relativity is that you can't differentiate between the accleration caused by a gravitational field and that created by any other mechanism.
If you are accelerating with respect to any other system you are no longer an inertial system and therefore you can in principle determine that you are moving.
  • #44
geometer said:
..If you are accelerating with respect to any other system you are no longer an inertial system and therefore you can in principle determine that you are moving.
Moving with respect to what? You don't have to be a non-inertial system to determine that you are moving relative to another frame. So the felt tug of acceleration provides no qualitative enhancement to one's assumptions.
  • #45
Haven't you ever heard of inertial navigation? A submarine keeps an accurate fix on its position by measuring acceleration alone. All that is needed is a starting point. For a submarine, the starting point is provided by GPS right before the sub surfaces, but it doesn't need to be. In open water maneuvering, it can simply be "where I was 5 minutes ago relative to where I am now." On the spaceship, you can throw an obect overboard right before you start accelerating to mark your position, but you don't need to - and even if you do throw an obect out, you don't ever need to look at it to come back to it later - you don't have to have a physical marker for your position to use it as a reference point.
Also, when doing collision avoidance, maneuvering, doing dead reckoning, etc. ships use a "where I started from" reference frame that isn't necessarily fixed to a position on earth. Its simply not necessary.
  • #46
I read all of the last post and am unimpressed. Acceleration is not an unequivocal guarantee of motion, and certainly not absolute motion (ie. "through space") because there's no such thing. The topic is relativity, and how one navigates through a body of water is hardly on point.
So you toss something out of a spacecraft and then accelerate away and return to find your "landmark". NO WAY is that any indication that you actually and unequivocally moved "through space". It's a moot point. Maybe you and the landmark were already in motion, and the engine thrust merely decelerated your craft to a standstill while the landmark continued on its merry way by momentum. But it's all made academic by Relativity anyway, because there's no such thing as unequivocal motion "through space", because "space" is not a medium -- space is the absence of any medium.
  • #47
Russ-waters' argument does not really need any medium : as long as the gravitational field around is uniform, that would do.
  • #48
Nor do I say anything about "absolute motion." I agree there is no such thing. So what is the problem? It almost seems like you are saying that since motion is absolute, motion doesn't exist. But that's a contradiction. It does exist, and it is relative.
You moved relative to your arbitrary landmark. No one is saying anything here about the implications for absolute motion - because there are none. All motion is relative - relative to whatever you choose. If I choose an arbitrary landmark, choose to call it "stationary" and then observe my distance to it to be increasing, then I am moving.
  • #49
russ_watters said:
Nor do I say anything about "absolute motion." ... No one is saying anything here about the implications for absolute motion..
Please have a look at my post #42, this thread, wherein that is answered. YOU may not have been trying to assert anything about absolute motion, but in geometer's original post, there was that clear implication.
You may need to review more of the thread to get a handle on this: one can discern relative motion without dispute, but I refuted geometer's claim that acceleration leads one to conclude "who is really in motion".
  • #50
This quote:
This does not imply anything about absolute motion. "who is really moving" is talking about which of two objects is moving with respect to the other, not whether either is "moving" absolutely. I think you misunderstood.
Ie, if a spaceship tosses a marker over the side, then fires its engines, you can't say its the marker that's "really moving" (with respect to the spaceship) because its the spaceship, not the marker, that's undergoing acceleration.
You can't even say both were moving and the ship decelerated and is now stopped because you then need a 3rd reference point from which to declare the ship moving at the beginning.
  • #51
russ_watters said:
... I think you misunderstood. ...you can't say its the marker that's "really moving" (with respect to the spaceship) because its the spaceship, not the marker, that's undergoing acceleration..
I misunderstood nothing. When geometer said, "If one system is accelerating, even uniformly, with respect to another system it is no longer an inertial system, and you should be able to detect acclerations and thereby determine who is really moving." But acceleration does nothing to differentiate "who is really moving". There's no such determination. There's no preferred frame! If one pilot fires his thrusters and thence feels a G-force, that's no indication what*so*ever as to which of two arbitrary frames "is really moving". They are each moving relative to one another and acceleration cannot qualify that any better.
  • #52
I beg to differ ostren. You did misunderstand. Russ is right on. My point is that given two inertial coordinate systems, there is nothing you can do to tell which is moving relative to the other. However, as soon as one coordinate system experiences an acceleration, from whatever source, now you can tell who is moving with respect to whom. Accleration does differentiate which of two systems is moving with respect the other.
  • #53
humanino said:
You can locally make acceleration disappear by changing the referential. Only locally. The free-fall observer not noticing the Earth gravitational field has a limited spave around him, otherwise he would notice the spherical shape.
Jumping back a few posts, I'd like to make a comment on this post also. Acceleration is actually a tensor of order 1. One of the main properties of tensors is that if they are non-zero in any coordinate system, they are non-zero in all coordinate systems. So, you can't make acceleration disappear by changing the reference frame.
  • #54
ostren, if what you are saying were correct, there would be no possible resolution to Einstein's "twins paradox." You could accelerate a spaceship away from earth, claim Earth is the one accelerating while the spaceship is stationary, have the spaceship turn around and come back to earth, and calculate that the clock on Earth should have less elapsed time than the clock on the spaceship. But then you'd compare the clocks and find that its the clock on the spaceship that has less elapsed time.
And again, nothing in any of this has anything to do with absolute motion. You keep bringing it up, but it isn't what geometer meant and nothing I said implies it exists. Again, answering the question "who is really moving?" does not require an absolute frame of reference.
  • #55
I have carefully read geometer's post #52 as well as Russ Watters' post #54 and I beg to differ with both. To geometer's claim that
..as soon as one coordinate system experiences an acceleration, from whatever source, now you can tell who is moving with respect to whom. Accleration does differentiate which of two systems is moving with respect the other.
I say you are way wrong and I stand by my post #51 unaltered. And your latter sentence above makes no sense: because each is obviously moving with respect to the other -- it's not lop-sided.
And to Russ's claim that
I have to ask what in tarnation you mean by the qualifier "really"?? Ah! some motion is "real" and other motion "imaginary".. is that your contention?
As for violating the twin paradox, Russ, you've got it all wrong. The turnaround twin's acceleration doesn't mean that time dilation is his alone because he is the one who is 'really' moving. Ooh, there's that funny word again.
No, the twin paradox can be resolved even assuming that the astronaut twin is STOCK STILL in space the entire time! For example, at my website, Addendum IV.
  • #56
ostren said:
I have carefully read geometer's post #52 as well as Russ Watters' post #54 and I beg to differ with both. To geometer's claim that I say you are way wrong and I stand by my post #51 unaltered. And your latter sentence above makes no sense: because each is obviously moving with respect to the other -- it's not lop-sided.
If you put an accelerometer on the spaceship and another on Earth you will find that it is "lop-sided" as the spaceship records acceleration and the Earth does not.
  • #57
kawikdx225: This is about "who is really moving", a phrase employed by geometer and echoed by russ_watters. This is not about who is really experiencing a G-force.
  • #58
ostren said:
And to Russ's claim that I have to ask what in tarnation you mean by the qualifier "really"?? Ah! some motion is "real" and other motion "imaginary".. is that your contention?
I don't mean to speak for you Russ, but what I meant by "really" refers back to the post that started this thread. In that post, OneEye commented that it was equally valid to say his turning of his car's steering wheel caused the Earth to turn as it was to say it caused his car to turn. He cited the equivalence prinicple from special relativity for this statement.
My comment was that by his turning of the steering wheel, he had introduced an acceleration into the picture, so the frame centered on and moving with his car was no longer an inertial frame and that the special relativity equivalence principle didn't apply any more. Further, since he felt the acceleration, it was possible for him to determine that it was actually he that was moving with respect to a frame stationary on the earth, and it was not the Earth that was moving with respect to a frame centered on his car.
  • #59
Thank you for the compromise, geometer, but I was only partly right, I think. The car's brakes or gas pedal would produce acceleration that can NOT be differentiated from gravitation by means of the local study of light. But any rotational motion, any spinning, that component I do believe is confirmed by light's behavior to be unambiguous.
  • #60
I think we still have a basic disagreement here ostren. Given a similar situation: If I am in my brand new Ferrari (hey, if we're going to pretend...) traveling down the freeway in a perfectly unaccelerated condition there is no way for me to tell whether I am moving with respect to the Earth outside my window or whether the Earth is moving and I am stationary. However, as soon as I step on the gas to pass Granny in her 57 Chevy I have introduced an acceleration into the picture and I can determine who is stationary with respect to whom.
It doesn't matter that I can't tell if the acceleration is due to gravity or to my pushing on the gas pedal; all accelerations produce equivalent effects. But, it does destroy my inertial status and enable me to differentiate the frame moving with me from any other inertial frame.
  • #61
geometer said:
... as soon as I step on the gas .. I have introduced an acceleration into the picture and I can determine who is stationary with respect to whom.
.. it does destroy my inertial status and enable me to differentiate the frame moving with me from any other inertial frame.
Differentiate Ok, but NOT deduce anything of stationary (your word) versus moving. Please use scenarios in deep intergalactic space to make your point, and you'll see that it doesn't play, this "stationary" discernment of which you speak -- or that "really in motion" discernment of which you earlier spoke.
  • #62
geometer says, " However, as soon as I step on the gas to pass Granny in her 57 Chevy I have introduced an acceleration into the picture and I can determine who is stationary with respect to whom."
Nothing could be further from the truth. Einstein would certainly concur. You see, the very definition of acceleration requires that if A is accelerating with respect to B, then B is accelerating with respect to A. Acceleration is, of course, the second time derivative of displacement, which is necessarily relative.
But, the asymmetry that lurks around this issue can be distrurbing. Not so ,with the car. The force that actually accelerates the 57 Chevy is equally and oppositely accelerating the Earth -- no way to tell who is on a special frame.
But, what about , say, a train and a car. In an observer's frame the train is in uniform motion, and the car accelerates. Clearly the car exerts no discernable force on the train. So if the car accelerates with repect to the train, where does the force come from to accelerate the train relative to the car? In fact such a force is frame dependent, much like a Corioulis(sp?) force. It's derived by using the coordinate transformation that brings the car to rest. When applied to the motion of the train, the time derivative of momentum brings in extra terms, some times called fictitious forces, which mimic the force necessary to give the train the proper acceleration in the rest frame of the car. Space invents the necessary force in order to keep the notion of motion strictly relative.
In other words, the very structure of space-time of physics completely precludes anything but pure, relative motion.
Regards,
Reilly Atkinson
  • #63
OK. Scenario 1. Consider two spaceships in deep space alongside each other, close enough that they can see each other. Initially, they are stationary with respect to each other. We note that "stationary with respect to each other" means that with respect to a third observer, they could be not moving with respect to each other or they could be moving with the same velocity with respect to each other. In this case, observers in the spaceships will not be able to tell if any motion is occurring.
Now, let's assume one of the spaceships experiences an acceleration, say from a programmed rocket firing. Now, an observer in that spaceship could detect that acceleration and from that information deduce that he/she is now in motion with respect to the other space ship.
Scenario 2. Now we assume only one spaceship in deep space. We further assume this spaceship represents an inertial frame. Under these conditions, an observer in that spaceship will not be able to tell if she/he is in motion or is stationary with respect to any other frame of reference. Now, assume that this spaceship experiences an acceleration. Again, the observer in the spaceship will be able to detect the acceleration and can deduce that he/she is in motion with respect to some other inertial frame. The spaceship might be speeding up, slowing down or turning, I'm not sure the observer aboard that ship could tell which, but she/he can tell some kind of motion is occurring.
Note that the key to these scenarios is that an observer in an isolated lab can detect accelerations. I find support for this statement in "Concepts of Modern Physics, Fourth Edition," by Arthur Beiser, where he states "The general theory of relativity, developed by Einstein a decade later, treats problems that involve frames of reference accelerated with respect to one another. An observer in an isolated lab can detect accelerations."
The fact that you can uambiguously determine, in non-inertial conditions, the state of motion of one frame with respect to another does not imply the existence of a preferred frame. The laws of physics are the same in any frame you care to examine. (the Strong Equivalence Principle).
  • #64
:confused: If I fire my engine and I start to feel an acceleration, and I check an accelerometer on the marker I just dropped off my ship and see that it is not accelerating, I most certainly can deduce several things:
-There is no gravity field affecting these results (I consider it unreasonable to assume a gravity field coincidentally appeared at the instant I fired my rocket).
-I am accelerating, the marker is not.
-I am moving with respect to the marker, not the other way around.
Certainly, there are a lot of calculations that work fine assuming either to be accelerating (calculating the distance, for example), but not every one makes sense that way.
How many times do I have to say this before you accept it? All motion is relative. The words "real" and "imaginary" have nothing to do with anything.
Heck, I'm not even saying that you can't consider either stationary in your calculations, if you want to be pedantic. But it makes for much more complicated calculations since you now have to add forces that didn't exist before: to consider the marker to be moving and the spaceship stationary, you need add arbitrary forces to both. You need to add a force that cancels the force of the rocket while accelerating the marker: for example, a planet materializing out of nowhere at the exact instant the rocket started firing. Of course, if you do that, you have just added a 3rd reference frame with which to define the rocket as stationary...
Is your explanation the same as Einstein's?
Minor nitpick, reilly - the force is equal and opposite, the acceleration is not. f=ma, and the Earth is a lot more "m" than that '57 chevy. Its good to bring us back to that example though: in the rocket example, the force of the engine acts on the rocket alone and a gravitational pull would act on the rocket and marker proportionally. In the car example, you have only one force and it violates f=ma to say that its the Earth that is accelerated due to that force alone.
  • #65
Let me try my point another way:
If you have 2 objects and the distance between them is changing, you can reasonably say that either is "moving."
If the rate of that change in disance is changing, you can reasonably say that either is "accelerating"
If a force is measured between the two objects, it is now unreasonable to choose one of them arbitrarily and say it is accelerating and the other is not.
In the car example, a force exists and is measurable that cannot cause the measured acceleration of the earth.
  • #66
Un less the space between them is expanding...
  • #67
You say there is no way to tell who is on a special frame. If this is true I could do a physics experiment in the accelerating car and on the Earth and the results would be identical. This is not true.
Lets try another thought experiment.
Two cars are sitting at a red light.
Granny in her 57 Chevy and some punk kid in a hotrod.
Each car has a passenger that is tossing a quarter in the air then catching it.
When the light turns green the kid in the hodrod hits the throttle but granny fell asleep.
The passenger in granny's car notices no change in his physics experiment (tossing and catching the quarter) but the passenger in the hotrod must now make a correction to catch his quarter.
  • #68
Any such deduction is nonsequitor. Perhaps the deducer doesn't understand relativity. If he is now in motion with respect to the other ship, then the other ship is equally in motion with respect to his own. Per relativity, it is proper to attribute the G-force (of acceleration) to an unusual passing gravitational field. That may sound whacky, but it makes computations easier. You cannot ascribe relative motion to be lop-sided. The motion between the two ships is relative and utterly mutual.
No he cannot determine unequivocal motion because there is no unequivocal 'background' frame with respect to which he could say he is moving. Sorry, but that's the essence of relativty.
You started all this bickering by using the phrase, "can determine who is really moving", which doesn't fly because there's no viable definition of the word "really" in that phrase.
You saw the post by Reilly Atkinson, and he seconds my opinion. He is obviously more credentialed than I am.
  • #69
The way I see it, the existence of a force between the objects isn't really the issue - the issue is the application of Newton's laws.. One is perfectly free to adopt any coordinate system one wants - but one should not expect Newton's laws to work in such an arbitrary coordinate system. Measuring a force or forces between the objects isn't the big issue here, IMO, the big issue is applying the formula f=ma.
As others have pointed out, an observer can tell whether or not f=ma "works" for them just by doing local experiments, this can be done without thinking about the forces between the two bodies.
  • #70
Are you calling me a punk kid? :biggrin:
