The relativistic Doppler effect
The discussion centers on the relativistic Doppler effect and its application to determining the source frequency of light from a receding galaxy. The observed frequency was calculated, and an attempt was made to "un-shift" it to find the source frequency, resulting in a wavelength of 94 nm. However, using the Rydberg equation led to nonsensical values for the energy level. Participants suggest calculating in electron volts (eV) and emphasize the importance of understanding the energy ratio of the photon as generated versus observed. The conversation highlights the need for careful calculations to resolve discrepancies in the results.
help I have 12 hours
An electron in a hydrogen atom drops from an excited state n=n’ to the n=1 level and emits a photon in a distant galaxy. When the photon reaches earth, its final energy is observed to be 2.117 eV. If the galaxy is receding at 0.95c, what was the excited state of the electron? Hint: Look at section 1.14 on the Doppler effect in your book.
E=hc
B=V/c
Fobs=(((1-(B/C))/(1+(B/C)))^(1/2)
I found the observed frequency from the energy. Then I used the receding Doppler shift formula to find, the source frequency but after that when i tried to use the Rydberg equation I got a value for the energy level less than one. and I'm pretty sure my work is right, any help is greatly appreciated, thank you.
The light you are seeing has already been Doppler shifted to lower energy. You need to "un-shift" it to find the original energy!
Yes, I have done this. I found the f(obs) = (5.1189*10^14)hz
and then I "un-shifted" to find the f(source)=(3.19675*10^15)hz
which gave me lambda=94nm for the source light, but when I use the Rydberg equation from there I get a nonsense answer. Sorry, but can someone check if the problem has an answer that works?
1/(94*10^-9)=(1.096*10^7)((1/(n^2))-1) n=non-sensical
The observed frequency will be less than the emitted frequency because the galaxy is receding.
Why not do the calculation in ##eV##? The ground state of hydrogen is ##-13.6eV## and the nth state has energy ##-\frac{13.6}{n^2}eV##.
And, yes, I do get a whole number answer (without converting to photon frequency or wavelength).
So far, so good.
Now, sticking to frequency, what is the ratio of energies of the photon as generated and as seen on Earth?
What is the energy of the photon as generated?
Solve for n.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
