Dale
Mentor
- 36,480
- 15,228
Thanks for making that effort here. Interestingly, in all of the conversations I have had with people about defining "reality" this is only the second time that someone has actually proposed a definition, so I do appreciate having a relatively productive discussion.GregAshmore said:I've taken a couple of days to think about this. Two thoughts:
1. The fact that I have not provided a clear positive definition of reality--"Reality is..."--is a consequence of my conception of reality. I start with the notion that our knowledge is limited, that there is more to the physical universe than we have been able to measure. Given that assumption, a comprehensive definition of physical reality is probably out of reach, because one cannot define positively what one does not know. The best I can do (at this point) is a tautology: Reality is what is. I'm not happy with that; I doubt that you are.
I am glad that you are not happy with that definition. The big problem scientifically is that there is no clear experiment that can be used to determine "what is", particularly in the context of how you want to use the term "reality". So your definition would be a philosophical definition rather than a scientific definition. That is fine but doesn't belong on this forum. The only definition I can come up with for "reality" is religious so it doesn't belong here either which is why I avoid the term on this forum so carefully.
Sure, but that is the nature of science and inductive reasoning. We make an experiment and then we generalize the results into a theory that predicts the outcome of experiments we have not yet performed. A theory that was simply a catalog of experimental results and made no predictions would be a pretty useless theory.GregAshmore said:2. The scientific community has a tendency to blur--or at times ignore--the line between aspects of a theory which are backed up by direct measurement and those which are inferred from those measurements. In other words, scientists tend to treat their theories as completely "real", forgetting that our knowledge of reality is limited.
It certainly is possible that if we did the Hafele-Keating experiment in airplanes painted neon pink instead of white that we would get a different result. Should we therefore hesitate to make statements about time dilation on neon pink aircraft? Well, we have a theory that accurately describes the result obtained on white aircraft (and all other results obtained to date) and according to that theory the color of the paint for the aircraft will not change the result. So we have good reason to believe that we know the result for neon-pink aircraft even though it has not been tested.
