Theory behind investigating factors affecting inductance
The investigation focuses on how the number of turns on a coil, the core material, and the configuration of cores in series or parallel affect inductance in a DC circuit. The researcher measures voltage across the inductor to calculate current and subsequently inductance using the formula L = -ε ÷ (dI/dt). There is a question regarding whether the self-induced emf (ε) equals the supply voltage. Additionally, assistance is sought in deriving equations for the effects of core material and circuit configurations on inductance. Clarification is also needed on the meaning of dI/dt in the context of a DC circuit.
JohnayG
Hello,
I am currently doing an investigation to study the factors affecting inductance. The three variables i am using are the number of turns on the coil, the material of the core of the coil and putting 2 cores in series/parallel to see how this affects the inductance in a d.c circuit.
now i have done experiments for each whereby i measured V across inductor to allow me to work out I and therefore see the affect on L in L= -ε ÷(dI/dt)
i just have a couple of questions though. first of all, am i right in saying that my value for ε (self-induced emf) will the same as the supply voltage?
also, i am requesting some help with my theory work deriving the equation for each variable. i have done the theory for changing number of turns by showing how it affects the magnetic flux produced. but I am having problems with the other 2 variables i.e. changing the core/parallel & series circuits; where/what equation with should i start?
Any help hugely appreciated.
Thanks for your time.
You don't say what kind of physics/engineering background you have. Have you seen the equations for series and parallel inductance, including mutual inductance? For iron-cored solenoids?
One immediate question: what is dI/dt in your equation, given that you are using DC?
  • · Replies 21 ·
