Thermal Deformation: Find Change in Cable Length at -15°C
The discussion focuses on calculating the change in length of two cables (brass and high-density polyethylene) when the temperature drops from 21°C to -15°C. The user applied the thermal expansion formula, using a coefficient of thermal expansion for copper, but there was a discrepancy in the value of α, initially stated as .00018 m/m-°C and later used as .000018 m/m-°C. The correct calculation method was confirmed, but the user needs to verify the correct coefficient value. The thread also briefly touches on how to insert special symbols into forum posts.
Jim_Earle
Hey everyone I am wondering if someone can just double check my work and formulas to see if I did this correctly. Thanks!
A 1.0-m rigid horizontal support is hung by two cables as shown. One cable is brass and the other is high density polyethylene plastic. At room temperature (21° C) the cables measure 3.50 m vertically. When the temperature drops to -15°C find the following.
The change in length in each cable.
Per my table I found Copper has a thermal expansion of coefficient α that equals .00018 m/m-C°
My L₀ = 3.50 m
∆T = TFinal – T orginal = -15°C – (21°C) = -36°C
∆ Lthermal = α L₀(∆T) = (.000018 m/m-C°)(3.50m)(-36°) = -.002268 m
Am I correct with the way I did this?
how do you get all the special symbols to insert into the forums also?
Your method is correct.
But you said the value of α is .00018/°C and then used .000018/°C, so check which value is the right one! :confused:
9K
