Thermodyanmics, thermal properties of matter
The discussion revolves around calculating the minimum energy required to freeze 200mL of ethyl alcohol at 20 degrees Celsius. The melting point was initially misidentified as 114 degrees, but it was clarified to be -114 degrees. The calculations for energy removal included both the specific heat and the latent heat of fusion, but the temperature change was incorrectly calculated. The correct temperature change should be from 20 to -114 degrees, significantly affecting the total energy calculation. The final consensus is that the initial calculations were incorrect due to the misunderstanding of the temperature range.
Jennifer001
a beaker contains 200mL of ethyl alcohol at 20degrees. what is the minumum amount of energy that must be removed to produce solid ethyl alcohol..
the melting/freezing pt is 114degrees Lf=1.09x10^5
density is 790kg/m^3
specific heat cap = 2400J/kgK
Q=mcdT
Q=ML
m=pv
m=pv=(2.00*10^-4m^3)(790)=0.158kg
Q1=mcdT
=0.158(2400)(94)
=35644.8J
Q2=ML
=0.158(1.09*10^5)
=17222J
Qtotal=Q1+Q2
=52866.8J
i think i did somethign wrong because in the book it says the answer is 68000J can someone help me out i don't know what i did wrong?
That 114 degrees must be wrong. If it were true, it would already be a solid at 20 degrees.
Lf=1.09x10^5
Q=mcdT
Q=ML
m=pv
Q1=mcdT
=0.158(2400)(94)
=35644.8J
Q2=ML
=0.158(1.09*10^5)
=17222J
Qtotal=Q1+Q2
=52866.8J
oooh sorry that 114 is suppose to be -114
Okay, then do you see the error here:
Jennifer001 said:
Q1=mcdT
=0.158(2400)(94)
=35644.8J
oo i added it wrong for dT its suppose to be -114-20 instead of 114-20
ok thank you
