Thermodynamics: Two gases in a container
In thermodynamics, when considering two gases in a container, the total entropy for different types of ideal gases is simply the sum of their individual entropies, S = S1 + S2, and remains unchanged if they are of the same type. For real gases, intermolecular forces may cause clustering, potentially lowering entropy, but if interactions are hypothetically turned off before mixing, the entropy cannot decrease once they are mixed and reach equilibrium. The concept of entropy of mixing is crucial in understanding these processes. Additionally, the body exemplifies gas interaction by retaining oxygen while exhaling carbon dioxide. Overall, the discussion emphasizes the complexities of entropy in both ideal and real gas scenarios.
heyhey281
Consider
a) two gases, each in a container with volume V
b) two gases in a container with volume V
Which system is more disordered, where is the entropy higher?
Ideal gas equation
(Van der Waals equation)
Ideal gas:
If the gases are of different type, I would say the entropy stays the same. The total entropy is in both cases just the sum S = S1 + S2, where S1 is the entropy of the first gas and S2 the entropy of the second gas.
If the gases are of the same type, I think the entropy change is also 0.
(I am not too sure if you can even distinguish ideal gases / call them different types?)
Real gas:
Due to the intermolecular forces, I think the molecules might "cluster" a little bit more which would lower the entropy? But on the other hand, I could first put both gases into the common volume V and hypothetically assume that there is absolutely no interaction between them ("switch off" the interaction between them before I mix them). Then I could “switch on” the interaction and wait until an equilibrium is reached. Since the system is isolated, the entropy cannot have possibly decreased?
heyhey281 said:
I am not too sure if you can even distinguish ideal gases - - -
In what sense? Your body does it all the time. You keep some of the oxygen that you breathe in and you breathe out carbon dioxide.
More to the point, I think you need to consider entropy of mixing.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
