Thin film appears red, thickness of this part?
The discussion centers on calculating the thickness of a thin oil film that appears red due to constructive interference. The phase shift occurs because the oil's refractive index is greater than that of air, leading to the equation mlambda = 2d + lambda/2 for constructive interference. Participants note that the problem lacks clarity regarding whether to find the minimum thickness, as multiple thicknesses can produce the same color. It is emphasized that the wavelength used in calculations must be adjusted for the oil's refractive index, which shortens the wavelength compared to air. Choosing m = 1 is suggested as a viable option to determine the smallest non-negative thickness.
Cocoleia
A thin film of oil (n=1.5) is floating on top of water. When looking directly at this film, a large portion appears red (700nm). What is the thickness of the red part of the layer?
Since n for oil > n for air, there will be a phase shift of lambda/2
There will be no phase shift for the next reflection, but it travels 2x the thickness of the film (2d)
Since it appears red, i said it was constructive interference. So we get mlambda = 2d + lambda/2
If they asked for minimum i would set m=0 and use the 700nm to solve for d, but they don't specify. What should i do?
You are right, there are different thicknesses (corresponding to different integer values of m) that would give constructive interference. I think they should have stated minimum thickness if that's what they wanted. The phrase "large portion of red" suggests that the thickness is very small, because with larger thicknesses the regions of interference maxima and minima tend to crowd together. But this still does not necessarily mean that you must pick the smallest thickness. So, I'm with you. The statement of the problem should have been clearer.
Note that if you choose m = 0 you will get a negative value for d. So, if you want the smallest thickness you would want to choose the smallest value of m for which you get a non-negative thickness.
Also, remember that lambda in the formula represents the wavelength of the light inside the film. So, you would not use 700 nm.
Not quite. You are forgetting that in the oil the wavelength is shorter than in air (or vacuum). Your expression does not take into account this fact.
How would I find the correct wavelength?
Can I choose m = 1 then? or will this no longer respect the conditions
In your equation mλf = 2d +λf/2, any positive integer value of m would correspond to constructive interference. m = 1 seems like the most natural choice. It will give the smallest thickness.
