Time for the pendulum to come to a stop
  • Thread starter Thread starter Aristarchus_
    Pendulum Time
To approximate the time it takes for a pendulum to come to a stop, one must consider factors such as damping, mass, and the characteristics of the harmonic oscillator. The discussion highlights the importance of understanding the damped harmonic oscillator model, which provides insights into how energy loss affects motion. Relevant equations that describe the system's behavior are essential for accurate calculations. The role of friction and air resistance in the damping process is also crucial. Overall, a comprehensive analysis of these factors is necessary to determine the stopping time of the pendulum.
Aristarchus_
How would one approximate the time it takes for the pendulum to come to a final stop? Including all the factors...
e
e
Aristarchus_ said:
Homework Statement:: How would one approximate the time it takes for the pendulum to come to a final stop? Including all the factors...
Relevant Equations:: e
e
What else do you know about the pendulum other than it comes to a stop?
Nothing other than mass
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
