- #36
Dale
Mentor
- 35,545
- 13,871
You could heat them and see how they change, or compress them, or accelerate them, or expose them to an EM field, or to vibrations. You perform experiments to find out why they disagree. You learn how your measuring devices work.Killtech said:If you accept neither one as a valid measure of length, what kind of further experimentation would Peter be doing then?
No, that is not correct. You can also compare rods to others of the same type. If I heat 3 rods of type A and don’t heat 3 rods of type A and see that the heated ones differ from the unheated ones then we are completely wise that rods of type A are sensitive to temperature. This is standard metrology.Killtech said:But to be more precise, we can only find that the ratio of those two physical measurements is sensitive to something else. From that you are non the wiser which one is affected or if both are.
This is simply not true.Killtech said:And since the rods will always yield consistent results among rods of the same type, there is nothing able to resolve it.
