Total energy of a wave on a string
The discussion centers on the calculation of the total energy of a wave on a string, where the user derived an expression yielding a coefficient of 2, while the book's answer key states it should be 4. The user initially overlooked the importance of the length of the wave train, which is crucial for calculating total energy. It was clarified that the total energy depends on the number of cycles in the wave train, which was indicated in the problem statement but not initially considered. The user acknowledged this oversight and recognized the need to account for the complete problem context. Understanding the relationship between wave cycles and total energy is essential for accurate calculations.
Brian_D
Consider a wave train propagating as a sine wave along a string. Obtain an expression for the total energy in this wave train, in terms of the string tension F, the wave amplitude A and the wavelength lambda.
##\mathit{total} \mathit{energy} \mathit{of} a \mathit{wave}= 0.5 \mu A^{2} \omega^{2} \lambda##
##\mu =\frac{F}{V^{2}}##
##\omega =\frac{2 \pi\mathrm{V}}{\lambda}##
P.S. I tried to clean up this post, but the program does not seem to be working correctly. When I click on "preview" I get one thing, but when I go back to my original text, it does not match the preview.
I plugged the expressions for mu and omega into the equation for total energy and simplified. I got ##\textit{total\_}\mathit{energy}=\frac{2 \pi^{2} A^{2} F}{\lambda}##. However, the book answer key says, ##\textit{total\_}\mathit{energy}=\frac{4 \pi^{2} A^{2} F}{\lambda}##. (The book gives 4 as the coefficient, not 2). Is the answer key wrong? If not, where was my mistake.I talenergyofawave=0.5μA2ω2
ω=2πVλ
Brian_D said:
Relevant Equations: total energy of a wave ## = 0.5 \mu A^{2} \omega^{2} \lambda##
This expression does not give the total energy of a wavetrain. It provides the energy of a specific length of the wavetrain. See your textbook to determine this length.
The question asks for the total energy in the wave train. This will depend on the overall length of the wavetrain, but this length is not given in the problem statement. Check to make sure that you have provided the complete problem statement.
Thank you, TSny, you have clarified the whole thing. The problem statement indicated two cycles and included a diagram showing two cycles; I modified the problem statement because I didn't want to have to reproduce the diagram. I didn't think the number of cycles mattered, and that was my mistake.
Likes WWGD and TSny
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
