Total Internal Energy of an Ideal Gas
The discussion revolves around calculating various properties of argon gas stored in a container, including its absolute temperature, number of atoms, total mass, and total internal energy. The temperature was calculated using the ideal gas law, resulting in 364.4 K, although there was an initial error regarding the pressure value. The number of atoms was correctly determined to be approximately 1.204x10^23 by multiplying the number of moles by Avogadro's constant. The total mass of the gas was confirmed to be 8 grams, based on the atomic mass of argon. Finally, the total internal energy was calculated using the formula U = nCvT, yielding a result of 911 J.
daleklama
Argon is stored in a container of volume 2L and a pressure of 5 atmospheres. The amount of gas present is 0.2 moles. Find:
(i) The absolute temperature of the gas
(ii) The number of atoms of gas in the container
(iii) The total mass of the gas
(iv) The total internal energy of the gas.
You may assume argon behaves as an ideal gas, the atomic mass of argon is 40 g/mol.
PV = nRT
dU = Uf – Ui = Q – W (First Law of Thermodynamics)
(i) I used PV = nRT, made all the relevant conversions and got 364.4 K. Think it's right.
(ii) I multiplied 0.2 (number of moles) by Avegadro's constant (6.02x10^23) and got 1.204x10^23 atoms. Think it's right.
(iii) I'm not sure if this is right... To find the total mass of the gas, knowing that the atomic mass is 40g/mol, I just multiplied 40 by 0.2 and got 8g?
(iv) I haven't a clue. :( The only equation I can find for total internal energy is the First Law of Thermodynamics above, but as far as I know, I don't have any of those things or know how to find them.
Thanks very much for any help!
I get a different number. P = 5 x 101,325 Pa; V = .002 m^3; n = .2 mol; R = 8.314 J/K mol
Ok.
Right. This is correct because Argon is a noble gas so it is a monatomic gas.
Use U = nCvT
AM
Aw, brilliant, I think I have it, thanks!
(apologies about the temperature calculation, the question is actually 3 atmospheres and that's what I used, I accidentally typed 5 on here, sorry!)
U = n Cv T
where n = 0.2
T = 364.4 K
and Cv = 3/2 R = 12.47
when I put them all into the equation I get 911 J.
Thanks a million for your help, very much appreciated :)
  • · Replies 33 ·
