- #106
AdVen
- 71
JesseM said:I think the point is that if you are starting from the assumption that you start out knowing the separation in the S' frame dx'=0, then it makes more sense if you also assume you start out knowing the time interval in the S' frame and are using it to find the time interval in the S frame, rather than starting from the time interval in the S frame and using it to find the time interval in the S' frame (usually in a basic SR problem, you'll be given all the information about coordinates in one frame and then you have to find the coordinates in the other frame, rather than initially being given the distance in the S' frame but the time in the S frame). In other words it would make more sense for your final equation to give dt as a function of dt', not dt' as a function of dt, so the final equation should be dt = dt'*gamma rather than dt' = dt/gamma.
In my opinion I think you are quite right, if you are aiming at a conclusion such as:
The time between two events on the clock's worldline is longer for an observer moving relative to the clock (to the clock's rest frame) than the time between those same two events in a frame that is at rest relative to the clock.
However, a conclusion which is consistent with this conclusion is:
The time between two events on the clock's worldline is shorter for an observer at rest relative to the clock (to the clock's rest frame) than the time between those same two events in a frame that's moving relative to the clock.
It seems to me, that, if you do not have any preference for either of these two conclusions, and why should you, it does not matter what approach you choose.
Anyway, you have to specify what exactly you mean with:
JesseM said:then it makes more sense.
