- #71
billschnieder
- 808
- 10
Huh?DrChinese said:Great example, pretty much demonstrates everything I have been saying all along:
a) There is a dataset which is realistic, i.e. you can create a dataset which presents data for properties not actually observed;
Look at Bell's equation (15), he writesb) The sample is NOT representative of the full universe, something which is not a problem with Bell since it assumes the full universe in its thinking; i.e. your example is irrelevant
1 + P(b,c) >= | P(a,b) - P(a,c)|
Do you see the cyclicity I mentioned in my previous post? Bell Assumes that the b in P(b,c) is the same b in P(a,b), and the a in P(a,b) is the same a in P(a,c) and the c in P(a,c) is the same c in P(b,c). The inequalities will fail if these assumptions do not hold. One way to avoid these would have been to start the equations using P(AB|H) = P(A|H)P(B|AH), the term P(B|AH) reminds us not to confuse P(B|AH) and P(B|CH).
Now fast forward to Aspect type experiments, each pair of photons is analysed under different circumstances, therefore for each iteration, you need to index the data according to at least factors such as, time of measurement, local hidden variables of measuring instrument, local hidden variables specific to each photon of the pair, NOT just the angles as Bell did. Adding just one of these parameters breaks the cyclicity. So it is very clear to anyone , that Bell's inequalities as derived only works for data that has been indexed to preserve the cyclicity. Sure this proves that the fair sampling assumption is not valid unless steps have been taken to ensure a fair sampling. But it is impossible to do that, as it will require knowledge of all hidden variables at play in order to design the experiment. The failure of the fair sampling assumption is just a symptom of a more serious issue with Bell's ansatz.
I assume you know about the Bell-type Leggett-Garg inequality (LGI). The doctors and patients example violates the LGI and so does QM. Remember that violation of LGI is supposed to prove that realism is false even at the macro realm. Using the LGI, which is a Bell-type inequality in this example is proper and relevant to illustrate the problem with Bell's inequalities.c) By way of comparison to Bell, it does not agree with the predictions of QM; i.e. obviously QM does not say anything about doctors and patients in your example.
