Electrical TV capacitor instead of motor capacitor
  • Thread starter Thread starter John1397
    Capacitor Motor
Using an old TV-style capacitor as a replacement for a failed motor capacitor in a 1 hp farm motor running on 220 AC is not advisable. Motor capacitors are bi-polar AC types, while TV capacitors are typically DC, making them incompatible. The appropriate replacement for a motor capacitor should fall within a range of 30 uF to 60 uF, depending on whether it is a start or run capacitor. New motor capacitors are relatively inexpensive, typically under $20, and using the correct part is crucial to avoid future failures and potential hazards, such as explosions or fires from incorrect capacitor use. It is emphasized that attempting to use a DC capacitor in an AC application is dangerous and should not be pursued.
John1397
TL;DR Summary
Have farm motor 1 hp 600 mf capacitor failed can one slip old tv style capacitor in old can as this motor runs on 220 ac?
Probably not.
A new cap shouldn't be more than $20 US, although that is a pretty large mfd.
NO. The motor capacitors are Bi-polar AC, not DC like those used in electronics.
How many capacitors does it have?
Is the AC capacitor rated at 250 VAC for starting, or 450 VAC as a run capacitor ?
If it has only one, a start capacitor, then it needs a value somewhere between 30 uF and 60 uF.
Motor start caps are available from electrical providers and on teh web.
The unit uF = 1x10-6, once used to be called mmF, = 1x10-3 * 1x10-3 = 1x10-6 = uF.
Likes DaveE
Get the correct replacement part. The cost of future failures and repeated repairs is more significant than the cost of the correct part. You'll probably end up buying it eventually anyway.
Likes Rive, Twigg and hutchphd
Instead the bottom of the capacitors please add some pictures about the text on the sides.
Also, something about the motor so we can identify it.
If it remains a guesswork as it is right now, then the general answer is - no.
Motor starting capacitors really can't be replaced with anything else. Why are you wanting to take this shortcut? Are you concerned the motor is defective and don't want to waste the money on the correct part?
Likes Vanadium 50 and DaveE
Only difference I see and don't understand is motor capacitor is AC and tv capacitor is DC, see no reason to not try either motor will start or not.
It is all to do with the chemistry at the surface of the aluminium foil.
From: https://en.wikipedia.org/wiki/Electrolytic_capacitor
"Electrolytic capacitors are polarized components due to their asymmetrical construction and must be operated with a higher voltage (ie, more positive) on the anode than on the cathode at all times. For this reason the anode terminal is marked with a plus sign and the cathode with a minus sign. Applying a reverse polarity voltage, or a voltage exceeding the maximum rated working voltage of as little as 1 or 1.5 volts, can destroy the dielectric and thus the capacitor. The failure of electrolytic capacitors can be hazardous, resulting in an explosion or fire. Bipolar electrolytic capacitors which may be operated with either polarity are also made, using special constructions with two anodes connected in series. A Bipolar electrolytic capacitor can also be made by connecting two normal electrolytic capacitors anode to anode or cathode to cathode."
Likes Spinnor
DC caps cannot handle AC. It'll just explode.
And it'll be quite violent too. Just don't do do this.
Likes berkeman
@John1397 is apparently not listening to our good advice, and is intent on trying dangerous (and stupid, IMO) stuff. This thread is closed.
Likes phinds
