- #176
cos
- 212
RandallB said:You potential explanations here are incomplete and IMO get at the root of your confusion.
First option 2 should be rejected as unrealistic as no change can occur to B since it remains stationary in a single frame. SR certainly will not support the #2 option.
You apparently did not see my original posting in which I argued that option 2 is unrealistic!
But #1 is much to incomplete an explanation;
it has three different possibilities you have not detailed (or considered) since in the travel of A it must use two different Frames; one outbound and one inbound;
this gives four possibilities for the rate of clock A wrt B:
a) both A outbound and A inbound run FAST wrt B
b) both A outbound and A inbound run SLOW wrt B
c) A outbound runs SLOW and A inbound run FAST wrt B
d) A outbound runs FAST and A inbound run SLOW wrt B
SR only rejects option “a”
but based on the given information of the problem “b” “c” or “d” could be true.
Options “c” & “d” work as long as the amount of time A spends at the slow rate is long enough when summed with the time built up by A at the fast rate nets to a total time less than experienced by B for the duration of the round trip.
Perhaps you might care to read my comment to which you refer but to save you having to locate same I herewith reproduce it:-
"In paragraph 1, chapter 4, OEMB Albert Einstein wrote:-
"If at the points A and B of K there are stationary clocks which, viewed in the stationary system, are synchronous; and if the clock at A is moved with the velocity v along the line AB to B, then on its arrival at B the two clocks no longer synchronize, but the clock moved from A to B lags behind the other one..."
There is, as far as I can tell, only two explanations as to why A is found to lag behind B:
1. During that trip A ticks over at a slower rate than it did before it started moving OR -
2. The rate of operation of clock B increases whilst A is moving.
Where, in that comment is there any application that 'in the travel of A it must use two different Frames; one outbound and one inbound.'?
You wrote:-
Neither of these ideas comply with Einstein's chapter 4 depiction which indicates that A inbound (as per your reference c)) runs slow wrt to B and if A had initially been at rest alongside and synchronous with B and had moved the same distance as Einstein's A to B and at the same velocity it, too, would lag behind B by the same amount as does A's clock in Einstein's depiction.
It would not, as you suggest in d), run FAST!
One of the three conditions will be observed by any random observer C moving at any fixed speed wrt B and will always give the same net change from start to finish for both A & B (B always less than A by the same amount) no matter what speed you use for observer C.
There is no random observer C either in Einstein's chapter 4 depictions or in the astronaut's out-and-return journey but even if there was then his observations have absolutely nothing whatsoever to do with the observations made by A or B.
His observations will have no physical affect whatsoever on A's or B's clocks!
His observations are of no interest whatsoever to A or B.
