- #106
Dale
Mentor
- 35,556
- 13,883
Exactly. Note that this does not imply that the rate of either clock has changed, simply that they are measuring the length of different paths through spacetime (aka worldlines).DTThom said:I can easily deduce that the two odometers in your example traveled actual different distances, due to the actual difference showing up in the number of odometer ticks at the same place-moment in New York. I can identically deduce that the two reunited clocks I spoke of ticked an actual different number of times while they were apart.
Similarly, a clock is bound to read true to the spacetime interval of its worldline.DTThom said:I don't care what distance the clocks traveled. You provided a distance problem. An odometer is bound to read true to the distance of the road.
I agree completely. I find the geometric approach by far the easiest and most intuitive.DTThom said:You can do relativity the easy way, or you can make it hard for yourself
A worldline is simply a path through spacetime. It is every bit as physical as a path through space.DTThom said:A world line is a spacetime construct, not something physical.
