- #141
DTThom
- 9
To JesseM and DaleSpam et al.
I don't know whether you ever agree to acknowledge a clock "rate",
even a purely relative one.
People in all inertial frames will agree that there *exists* an
interval *during* which two departed-then-reunited clocks tick a
different number of times.
And they all agree as to what the numerical difference is in
ticks.
It is during that interval, that a clock at rest with the
universe will tick the maximum number of times, due to the
fact that no vector component of motion has been added to the
clock, which is constrained in its functioning by light speed.
(Photons cannot possibly acquire greater speed when
a vector component of motion has been added to a clock which
contains the photons. Therefore the photons will produce fewer
ticks of the clock as they maintain their constant speed).
Atomic, chemical, mechanical, biological -- doesn't matter.
Mixing up the concept of clock ticks with the flow of time
(time in the history sense) can certainly create a communication
problem. I believe relativity (and physics in general for now) is
concerned only with clock ticks, not the flow of time.
"all there at once" vs. "has always all been there"
Would could you be driving at here.
What world lines in the higher dimension. Did I say
there are world lines there? I don't know anything
about the nature of a higher dimension, save my
notion of light having a finite speed in our dimensions,
and the notion that such movement of light can
be charted out in a "frozen" form on a "map" to be
percieved by the higher dimension without the
delay of light speed affecting such perception.
I don't even care if there is no such higher dimension.
It is still an analytical tool I can use to chart out
the effects of relativity as we know them, with an
arbitrary assignment of a line segment to represent
the distance of one light second, and with
speeds less than light speed to be defined in accordance with
the speed of light as established by the distance
of one light second.
I'm headed off to work. Try to manage without me, as
I have no computer available during that interval
by which to help you out. (chuckle)
ticks.
bobc2 said:[How does the universe "evolve" if it is all there at once ("...universe
can be viewed as a whole from the vantage point of a higher dimension")?
bobc2 said:[If the universe is 4-D and static (including 4-D structure of observer bodies),
how do the observers move along the world lines?
