Two forces acting on an object given in vectors - SOLVED
The discussion focuses on applying Newton's second law to analyze two forces acting on an object. The user splits the forces into F1 and F2, using the equation F1 + F2 = ma. They derive F2 by rearranging the equation and substituting the mass and acceleration terms. Another participant suggests considering the forces as components in the I and J directions to clarify the calculations. This approach emphasizes the importance of breaking down forces into their vector components for accurate analysis.
runningphysics
Two forces act on a 3.4 kg mass and undergoes an acceleration a= .87i - .32j m/s^2. One force is F= -.7i - 3.0j N. What is the other in terms of i + j?
F=ma, F1 + F2= ma
I tried splitting the forces up into F1 and F2 making Newtons second law equation into F1+F2=ma. Then I added over the the first force given. multiply the mass to the acceleration terms to get F2= (m*ai + m*aj) - F1
Have you tried to look at it as components I and J as:
##F1_i + F2_i = m a_i## and similarly for j
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
