Two wavelengths, find time between successive beats
  • Thread starter Thread starter phys62
    Time Wavelengths
Two pianos playing the same note produce different wavelengths, resulting in a frequency difference that causes beats. The speed of sound is 348 m/s, with piano A having a wavelength of 0.765 m and piano B a wavelength of 0.772 m, leading to frequencies of 454.9 Hz and 450.7 Hz, respectively. The frequency difference between the two pianos is 4.2 Hz. Beats occur when the sound waves' maxima coincide, so the time between successive beats is calculated as the inverse of the frequency difference. Therefore, the time between beats is approximately 0.238 seconds.
phys62
Two pianos each sound the same note simultaneously, but they are both out of tune. On a day when the speed of sound is 348 m/s, piano A produces a wavelength of 0.765 m, while piano B produces a wavelength of 0.772 m. How much time separates successive beats?
So I know:
v=348 m/s
wavelength of A=0.765 m
wavelength of B=0.772 m
f=v/wavelength
so I was able to find the frequency of A=454.9 and frequency of B=450.7
I'm just not really sure what I should be doing... seems like it should be just a one or two step problem.. :/
OK what is the difference in frequency?
Isn't a beat going to be counted when ever their maxima coincide? So say the difference between 2 tones Δf is 1/2 hz, then won't the time T between maxima be 1/Δf = 2 ?
Yes, you're right! Thanks so much!
9K
