Unclear differential equation from a thermodynamics textbook
NODARman
In the thermodynamics textbook there is written: 𝛿𝐴 = 𝑇𝑑𝑆 βˆ’ π‘‘π‘ˆ = 𝑑(𝑇𝑆) βˆ’ 𝑆𝑑𝑇 βˆ’ π‘‘π‘ˆ = βˆ’π‘‘(π‘ˆ βˆ’ 𝑇𝑆) βˆ’ 𝑆𝑑𝑇 = βˆ’π‘‘πΉ βˆ’ 𝑆𝑑𝑇
How did we get the bolded area from TdS? Is that property of derivative, integral, or something else :/
Product rule
Likes topsquark and NODARman
Sorry for being so terse. I was posting from my phone.
Apply the product rule to ##TS##. ##d(TS) = ?##.
Kindly see the attached pdf. My attempt to solve it, is in it. I'm wondering if my solution is right. My idea is this: At any point of time, the ball may be assumed to be at an incline which is at an angle of ΞΈ(kindly see both the pics in the pdf file). The value of ΞΈ will continuously change and so will the value of friction. I'm not able to figure out, why my solution is wrong, if it is wrong .
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
