JD_PM
- 1,131
- 158
- TL;DR Summary
- I want to understand the derivation of the relativistic-relative velocity
$$v_{\text{rel}}=\frac{1}{1-\vec{\beta}_1 \cdot \vec{\beta}_2} |\vec{\beta}_1-\vec{\beta}_2|.$$
I was studying how to derive the cross-section formula in the CoM frame from Mandl & Shaw QFT's book, and they state the following formula for the relative velocity (I'm going to use Vanhees71's notation though)
$$\omega_1 \omega_2 v_{rel} = [(p_1 p_2)^2 - m_1^2 m_2^2]^{1/2} \ \ \ \ (2)$$
Then the relative velocity in the CoM system follows:
$$v_{rel}=\frac{|\vec p_1|}{\omega_1}+\frac{|\vec p_2|}{\omega_2}=|\vec p_1|\frac{\omega_1+\omega_2}{\omega_1\omega_2} \ \ \ \ (3)$$
Then Vanhees71 pointed out that (2) is wrong.
At #9 Vanhees71 stated:
'Your Eq. (2) is wrong. It's an invariant and thus you have the Minkowski product p_1 p_2 in the first term under the square root and not ##\vec{p}_1 \cdot \vec{p}_2##.
Eq. (3) cannot be right either, because the relative speed is covariantly defined as
$$v_{\text{rel}}=\frac{I}{p_1 p_2}=\frac{P\omega}{\omega_1 \omega_2+P^2}.$$
Indeed the general formula for the relative velocity, as derived in
https://itp.uni-frankfurt.de/~hees/pf-faq/srt.pdf
Eq. (1.6.5), confirms the above formula since or collinear velocities ##\vec{\beta}_1=\vec{p}_1/E_1=\vec{p}/E_1## and ##\vec{\beta}_2=\vec{p}_2/E_2=-\vec{p}/E_2## the formula simplifies to
In your formula (3) the factor in front of the "naive" formula for the relative velocity. Unfortunately this is wrong in some textbooks. I cannot check Mandl and Shaw, whether it's correct in there, but I guess not, given your Eq. (3).'
I did not really understand why Mandl & Shaw formulas were wrong so I thought the best was going through Vanhees71's derivation first... And here we go! :)
The intention is to go through the whole derivation (Section 1.6, Relative Velocity), so let's start from the very beginning
Two particles have the following four-velocities with respect to an arbitrary inertial frame
$$u_1^{\mu} = \frac{1}{\sqrt{1-\vec \beta_1^2}} \ \begin{pmatrix}
1 \\
\vec \beta_1 \\
\end{pmatrix}, \ \ \ \
u_1^{\mu} = \frac{1}{\sqrt{1-\vec \beta_2^2}} \ \begin{pmatrix}
1 \\
\vec \beta_2 \\
\end{pmatrix}
Then the rotation-free Lorentz boost to the rest frame of particle 1 is given by
$$(\Lambda^{\mu}_{ \ \ \nu}) = \hat B( \vec \beta_1)=
\begin{pmatrix}
\gamma_1 & -\gamma_1 \vec \beta_1^T \\
\vec \beta_2 & 1_3 + (\gamma_1-1) \hat \beta_1 \hat \beta_1^T \\
\end{pmatrix} \ \ \ \ (**)$$
My first questions are:
1) I do not follow ##(*)##
I know what's the definition of proper velocity; it's simply the change of the spacetime coordinate ##x^{\mu}## per unit of proper time:
$$u^{\mu} = \frac{d x^{\mu}}{d \tau}$$
My point is that I'd expect to have the scalar factor multiplied by a ##4 \times 1## matrix instead of a ##2 \times 1## matrix.
2) I do not understand how to write down the rotation-free Lorentz boost as presented
I understand that the rotation-free Lorentz boost can be written in matrix form as follows
$$\begin{pmatrix}
\bar x^0 \\
\bar x^1 \\
\bar x^2 \\
\bar x^3 \\
\end{pmatrix}= \begin{pmatrix}
\gamma & -\gamma \beta & 0 & 0 \\
-\gamma \beta & \gamma & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{pmatrix}
\begin{pmatrix}
x^0 \\
x^1 \\
x^2 \\
x^3 \\
\end{pmatrix}
But how can we go from Eq. (**) to Eq. (***)?
Sources: Introduction to Electrodynamics, Griffiths and Manuscript in Special Relativity Theory, Vanhees71
PS: please note I am not used to modern SRT notation so I may ask too many naive questions. I am also aware that Griffiths' Electrodynamics book is maybe not the best source to study SRT. If you have any book suggestions please feel free to share
Thank you![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
1 \\
\vec \beta_1 \\
1 \\
\vec \beta_2 \\
\end{pmatrix}
\begin{pmatrix}
$$\begin{pmatrix}
\bar x^0 \\
\bar x^1 \\
\bar x^2 \\
\bar x^3 \\
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{pmatrix}
\begin{pmatrix}
x^0 \\
x^1 \\
x^2 \\
x^3 \\
\end{pmatrix}
Thank you
