- #106
martinbn
- 1,918
What you wrote in your post.Demystifier said:WHAT is also true for the local ones?
So you are saying that ##O(f)## is a local operator?martinbn said:What you wrote in your post.
Do we have to define all well-known terminology on PF? It all started with "reference frame". Now we get lost in discussions about standard terminology in quantum (field) theory. It's getting somewhat annoying!Demystifier said:Since this thread turns out to be about nitpicking on sloppy (physicist's?) and precise (mathematician's?) definitions, it should be mentioned that in mathematics direct product and tensor product are different things, but physicists often say "direct" product when in fact they mean tensor product. In the example above, I think it was really the direct (not the tensor) product.
The paper says: "... for any local quantum field operator ##{\cal O}(\vec{x}) = e^{-i{\vec P}\cdot{\vec x}}{\cal O}e^{i{\vec P}\cdot{\vec x}}## ..." How could the word "any" be interpreted as an example?martinbn said:That is not how i read it. Where is that definition? To me this looked like an example of a local operator. Similar to saying that a polynomial is a continuous function. That is not what the definition of a continuous function.
For @martinbn , yes we do.vanhees71 said:Do we have to define all well-known terminology on PF.
No, I said that local operators are also of that type, they evaluate on test function. Are you saying they are not?Demystifier said:So you are saying that ##O(f)## is a local operator?
Because it means any of these. And they have a definition for the general case early on, which I already quoted. How would you understand the statement "For any polynomial ##a_nx^n+\cdots+a_1x+a_0##, we have..."? As a definition of polynomial? That all polynomials are of that form? Then is ##x^2+y^2## a polynomial?Demystifier said:The paper says: "... for any local quantum field operator ##{\cal O}(\vec{x}) = e^{-i{\vec P}\cdot{\vec x}}{\cal O}e^{i{\vec P}\cdot{\vec x}}## ..." How could the word "any" be interpreted as an example?
You don't have to do anything, but if asked, why would you argue about nonrelevant things for two pages instead of give the definition? Have you never asked about a definition here? Is it not allowed to ask about definitions here?vanhees71 said:Do we have to define all well-known terminology on PF?
The latter is a polynomial in ##x## with ##a_0=y^2##.martinbn said:Because it means any of these. And they have a definition for the general case early on, which I already quoted. How would you understand the statement "For any polynomial ##a_nx^n+\cdots+a_1x+a_0##, we have..."? As a definition of polynomial? That all polynomials are of that form? Then is ##x^2+y^2## a polynomial?
Local operator ##O(x)## in QFT does not evaluate on test function. For instance, for the free Klein-Gordon field operator ##\phi(x)## you can calculate ##\phi(x)|0\rangle## without using any test function. If you smear the local operator ##O(x)## with a test function ##f(x)##, the resulting operator ##O(f)=\int dx \, O(x)f(x)## is no longer a local operator.martinbn said:No, I said that local operators are also of that type, they evaluate on test function. Are you saying they are not?
Good example! Yes, it is a local operator.Nullstein said:What if I define ##O(0) := \int \phi(x) f(x) dx## and ##O(x) := e^{-i P x} O(0) e^{i P x}##? Is ##O(x)## a local operator then, because it agrees with the definition?
I think in the integral it should be ##e^{-iPx}\phi(y)f(y)e^{iPx}=\phi(x+y)f(x+y)##, am I wrong here?Nullstein said:But if we expand it, we get ##O(x) = e^{-i P x} \int \phi(y) f(y) dy e^{i P x} = \int e^{-i P x} \phi(y) e^{i P x} f(y) dy = \int \phi(y + x) f(y) dy = \int \phi(y) f(y - x) dy##, so ##O(x) = \int \phi(y) g_x(y) dy## with the new function ##g_x(y) := f(y-x)## and so ##O(x)## is again just ##\phi(x)## smeared with some non-local function ##g_x## and should really be a non-local operator according to your earlier post? I don't see what I'm missing.
Notice that ##O## should satisfy also: ##\langle \Omega , O\Omega \rangle =0## for ##\Omega## a vacuum vector.Nullstein said:For the translation operator, ##f(x)## is just a constant real number and can be pulled out. But even if it were true, we would just get ##O(x) = \phi[f]## instead of ##O(x) = \phi[g_x]##, which would still not solve the problem.
Yes, because ##<\Omega, \phi[f]\Omega> = 0##. But even if not, we can just shift ##\phi[f]## by the constant value ##<\Omega, \phi[f]\Omega>## to make its expectation value 0, so that doesn't help a lot.MathematicalPhysicist said:Notice that ##O## should satisfy also: ##\langle \Omega , O\Omega \rangle =0## for ##\Omega## a vacuum vector.
Does you example satisfy this condition?
That's not a part of the definition of local operator. The paper discusses local operators that satisfy this condition as an additional condition.MathematicalPhysicist said:Notice that ##O## should satisfy also: ##\langle \Omega , O\Omega \rangle =0## for ##\Omega## a vacuum vector.
Smearing with ##f(x)## is not the same as smearing with ##f(x,y)##. For the latter kind of smearing, see post #4.Nullstein said:But if we expand it, we get ##O(x) = e^{-i P x} \int \phi(y) f(y) dy e^{i P x} = \int e^{-i P x} \phi(y) e^{i P x} f(y) dy = \int \phi(y + x) f(y) dy = \int \phi(y) f(y - x) dy##, so ##O(x) = \int \phi(y) g_x(y) dy## with the new function ##g_x(y) := f(y-x)## and so ##O(x)## is again just ##\phi(x)## smeared with some non-local function ##g_x## and should really be a non-local operator according to your earlier post? I don't see what I'm missing.
It really means that you can construct a local operator (local in ##x##) from any constant (##x##-independent) operator. But this, of course, does not mean that the initial constant operator was local. So there is nothing wrong with that.Nullstein said:In fact, it seems like we can make any operator ##O## a local operator according to the definition. Just define ##O' := e^{i P x} O e^{-i P x}##. Then ##O## can be written as ##O = e^{-i P x}O' e^{i P x}## and satisfies the definition. Something must be wrong.
But that seems very strange. The operator ##\phi[g_x]## depends on values of ##\phi(x)## at many points, much like ##\phi(x)\phi(7)##, yet it is supposed to be local. What about ##\phi[g_7]## then? Now it's just ##\phi(x)## smeared with a shifted version of ##f##.Demystifier said:Smearing with ##f(x)## is not the same as smearing with ##f(x,y)##. For the latter kind of smearing, see post #4.
No, it's confusing, because nobody writes the hats on the operators, but here you have in the integrand ##\hat{\phi}(y)f(y)##, i.e., ##f(y) \in \mathbb{C}## and thus ##\hat{T}(x) \hat{\phi}(y) f(y) \hat{T}(x) = f(y) \hat{\phi}(y+x)## with ##\hat{T}(x)=\exp(\mathrm{i} \hat{P} \cdot x)##.MathematicalPhysicist said:I think in the integral it should be ##e^{-iPx}\phi(y)f(y)e^{iPx}=\phi(x+y)f(x+y)##, am I wrong here?
But what's wrong with the following argument then: Any constant operator ##O## is local (according to the definition), because it takes the form ##O=e^{-i P x} O' e^{i P x}## for some operator ##O'##. ##O=e^{-i P x} (e^{i P x} O e^{-i P x}) e^{i P x}##.Demystifier said:It really means that you can construct a local operator (local in ##x##) from any constant (##x##-independent) operator. But this, of course, does not mean that the initial constant operator was local. So there is nothing wrong with that.
The primed operator has to be constant.Nullstein said:I don't see where a translational invariance condition suddenly comes in. The definition just says that an operator ##O## is local if and only if there is a second operator ##O'## such that ##O=U(t) O' U(-t)##. I showed that there is such an ##O'## for any operator ##O##, so any operator satisfies the definition and hence is local. The definition doesn't require me to check for translational invariance.
I think the problem is only in the sloppy language. To understand it, let me further simplify the problem. Let ##\phi(x)## be a local operator in one dimension, ##x\in\mathbb{R}##. I claim that then ##\phi(7)## is not a local operator. But ##\phi(7)## is just a special case of ##\phi(x)##. So how can a special case of local operator fail to be a local operator?Nullstein said:But that seems very strange. The operator ##\phi[g_x]## depends on values of ##\phi(x)## at many points, much like ##\phi(x)\phi(7)##, yet it is supposed to be local. What about ##\phi[g_7]## then? Now it's just ##\phi(x)## smeared with a shifted version of ##f##.
I think it's in fact quite physical that a field at one point depends on other fields at other points. For instance, static electric field at one point depends on static charge distribution at all other points.Nullstein said:Okay, I agree that the locality criterion only makes sense if applied to sets of operators, rather than a single operator. However, the question remains why this is a meaningful definition. Apparently the set ##\{\phi(x)\}## is just as local as the set ##\{\eta(x)\}## where ##\eta(x) = U(x)\phi[f]U(-x)##. But we would like to think of a local (set of) operator(s) as something that captures only local physics, e.g. like ##\phi(x)##. However, ##\eta(x)## can easily depend on the physics of the whole galaxy if we choose ##f## accordingly and yet, it still qualifies as a local (set of) operator(s).
