Understanding Photon Velocity: Impact on Mass and Life Span Explained
  • Thread starter Thread starter YoungDreamer
    Photons
Photon velocity is a crucial factor in understanding their properties, as they travel only at the speed of light (C) and possess no rest mass. Since photons cannot be at rest, they do not experience time, which means they do not have a life span in the traditional sense. Observations of photons do not indicate time dilation as they can be destroyed in extremely short time frames, contradicting the idea of an infinite life span. The unique nature of photons, existing solely at C, distinguishes them from other particles in physics. Overall, photons challenge conventional concepts of mass and time in relativity.
YoungDreamer
I am posting this under the belief that velocity affects mass and time, if my understanding is incorrect please correct it.
If a photon is traveling at C then theoretically does it have an increased mass compared to a photon that is "at rest"?
And if a photon is moving at C then does it have an infinite "life span"?
Science news on Phys.org
It is obvious that a photon does not have a "sense" of time. But thanks for the link.
I guess you're asking if a photon, observed by external 'stationary' (which will always be stationary to light's velocity of c) system appears to suffer time dilation, in this case infinite. Obviously no, because they can be destroyed in a matter of attoseconds and less.
But photons are massless and not party to the whole relativity time, length, mass thing anyway.
Pengwuino said:
Photons do not have a rest frame and cannot be at rest...
I agree. Photons exist only at c or not at all.
This curious phenomenon is not seen elsewhere in nature(to my understanding that is)
However, that fact that a photon has no "rest mass" helps, somewhat, in our query as to how it can go from 0 to c instantaneously.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
