- 20,710
- 28,093
What do you expect? Shall I read it for you? I gave a proper link and the page.DrStupid said:Provide a proper reference.
The rocket is the issue. We have low energy photons and high energy electrons and protons in that collision.DrStupid said:Just do the math. With
##\beta = 1 - \varepsilon##
blueshift is
##f' = f \cdot \sqrt {\frac{{1 + \beta }}{{1 - \beta }}} = f \cdot \sqrt {\frac{2}{\varepsilon } - 1} \approx f \cdot \sqrt {\frac{2}{\varepsilon }}##
The maximum of the CMB is at 282 GHz and 0.8 c corresponds to ##\varepsilon = 0.2##. That results in 846 GHz for the maximum of the blueshifted CMB. That means we are talking about IR radiation corresponding to a temperature of 8.6 K. How is that relevant for a rocket?
fresh_42 said:5 Joule are necessary to scatter CMB.
Yes. And protons. How fast do they have to be to pass 5J?PeterDonis said:5 Joules per particle. Not 5 Joules total. Big difference.
fresh_42 said:The rocket is the issue. We have low energy photons and high energy electrons and protons in that collision.
See:fresh_42 said:Yes. And protons. How fast do they have to be to pass 5J?
fresh_42 said:And protons. How fast do they have to be to pass 5J?
Inverse Compton was my guess. Lesch argued that we had observed particle scattering at CMB. Given that, the only question remaining is: at which rocket speed? The point is that the energy we have to invest in acceleration grows dramatically, too, and thus there will not be enough energy available once particles are created.PeterDonis said:Proton rest mass 936 MeV, or about ##10^9## eV. 5 J = about ##10^{19}## eV. So gamma factor of about ##10^{10}##.
Yes, but as has been repeatedly pointed out, this doesn't stop you getting to Andromeda in about 28 years, for example.fresh_42 said:Inverse Compton was my guess. Lesch argued that we had observed particle scattering at CMB. Given that, the only question remaining is: at which rocket speed? The point is that the energy we have to invest in acceleration grows dramatically, too, and thus there will not be enough energy available once particles are created.
fresh_42 said:What do you expect? Shall I read it for you? I gave a proper link and the page.
fresh_42 said:Given that, the only question remaining is: at which rocket speed?
How much energy is necessary to accelerate, say 1 ton of mass from 0.8c to .81c? O.k. I can do the math, but let's assume for a moment, that this is enough to create particles. If there is a possibility of such a creation, then it will take place. As said from the beginning, inverse Compton was a guess of mine which looked plausible. So assumed that this amount of energy is produced somewhere in the ship, then there will be a particle creation, which in return means it cannot be used for acceleration anymore.PeterDonis said:Exactly. And other people have been trying to calculate that. I don't see any justification for you simply dismissing their calculations.
Just to give you an idea of the company you are in here:fresh_42 said:How much energy is necessary to accelerate, say 1 ton of mass from 0.8c to .81c? O.k. I can do the math, but let's assume for a moment, that this is enough to create particles. If there is a possibility of such a creation, then it will take place. As said from the beginning, inverse Compton was a guess of mine which looked plausible. So assumed that this amount of energy is produced somewhere in the ship, then there will be a particle creation, which in return means it cannot be used for acceleration anymore.
fresh_42 said:Still better than some guys on the internet.
Yes, Compton seems to be off the table. But I still do not see, that Lesch was wrong. The fact that it was on youtube does not make it wrong per se. He is yet an active ordinary professor in theoretical physics at an ordinary German university. Sorry, but it is in the nature of the question here that sound calculations on this topic are hard to find. If we travel at 0.8c and have a interaction surface of 1 sq.mtr. then we will collide with 96,000,000,000,000,000 photons per second at 0.8c, and this shouldn't create resistance?weirdoguy said:You're one of those guys, and I think it's very disrespectfull to treat every single person here that way. Especially ones that showed numerous times that they know what they are talking about.
fresh_42 said:I still do not see, that Lesch was wrong
fresh_42 said:If we travel at 0.8c and have a interaction surface of 1 sq.mtr. then we will collide with 96,000,000,000,000,000 photons per second at 0.8c, and this shouldn't create resistance?
fresh_42 said:But I still do not see, that Lesch was wrong.
This is what I actually said:PeterDonis said:I don't think anyone is arguing that Lesch was wrong in what he said. I think people are saying that what he said does not support what you are saying.
which is what Lesch said, and my post here was:fresh_42 said:Reason why it won't work either way: CMB will work as resistor and additional energy meant for acceleration will be turned into particle production instead and arbitrarily close to c will be physically impossible, regardless which engine we constructed.
fresh_42 said:It was on a tv show, so no valid reference. At least it was an astronomer who said it. The photons of the CMB are everywhere, so there will be no way to escape them. They make space a fluid with viscosity. Thus depending on mass and surface area we will get a thermodynamic effect. I don't know at which temperature particle production begins, and whether it is pair production, or radioactivity due to collisions with the ship's material, or due to the existing matter in space.
My suspicion: inverse Compton effect.
Comments: | 12 pages, 4 figures, in press |
Subjects: | Astrophysics (astro-ph) |
Journal reference: | Astropart.Phys. 17 (2002) 347-354 |
DOI: | 10.1016/S0927-6505(01)00156-6 |
Cite as: | arXiv:astro-ph/0106530 |
fresh_42 said:This is what I actually said
See Lesch's paper in post # 70 on extragalactic jets.PeterDonis said:Which is what other people have been pointing out, but you don't seem to be agreeing with them.
fresh_42 said:there are no scientific papers of rockets at near c speed
fresh_42 said:See Lesch's paper in post # 70 on extra gallactic jets.
I can only assume that Lesch generalized the results of this paper to rockets near the speed of light. This makes a barrier of 0.99995c according to Wikipedia. So it is higher than I thought, but it is an upper bound below c.PeterDonis said:So, again, you are getting pushback because none of the references you give seem to be saying anything that is relevant to interstellar trips.
fresh_42 said:This makes a barrier of 0.99995c according to Wikipedia.
That was a quick search for the speed of extragalactis jets. It is probably too high. The paper saysPeterDonis said:What Wikipedia reference are you talking about here? The only Wikipedia references I see in this thread are to the article on UHECRs, which gives energies like ##10^{18}## eV and above, which correspond (for protons) to gamma factors of ##10^9## and above, which correspond to relative velocities much closer to 1 than 0.99995c.
So I looked up whether those jets are comparably fast to that of an hadronic spacecraft .The hadronic jet constituents can efficiently be accelerated in such fields all along the jets. To estimate the maximum energy the accelerated jet hadrons can achieve we consider energy loss processes as photon-pion and pair production as well as synchrotron and inverse Compton radiation.
fresh_42 said:It is probably too high.
PeroK said:PS I think the 28 years is an acceleration and deceleration trip to Andromeda. If you have a proper acceleration of ##g##, then you may reach the pair production gamma factor after 28 years. I haven't got time to check the calculation now.
a) In SR, as opposed to Newtonian physics, total energy of a particle in a given frame of reference is $$E = \gamma mc^2$$ where $$\gamma = \frac 1 {\sqrt{1 - v^2/c^2}}$$ And, if you draw the graph of energy as a function of speed (##v##), then you'll find a vertical asymptote at ##v = c##.JerryF said:Hi, thanks hugely for all posts. Great reading and they’ve given me much to think about and investigate.
2 things I don’t understand (amongst many others) are;
a) why we need an increasing amount of energy input when accelerating?, and,
b) Deep space viscosity at at nearly c. I interpret the comments like this:
blue shift will accelerate approaching photons real* energy to such high levels as to obliterate the ship.
If so, would there be a real corresponding depletion of energy density behind the ship?
*I use real in the sense that these effects could interact with the ship
Thanks again
JerryF said:why we need an increasing amount of energy input when accelerating?
