Universal Generators: Get Clarifications on Electrical Engineering Concepts
Universal motors operate by utilizing both the stator and rotor as electromagnets, allowing them to function efficiently with both AC and DC power sources. When the AC current reverses, it simultaneously reverses the poles of both the stator and rotor, maintaining consistent torque direction. This design is an enhancement of a standard DC motor, which can also run on AC but with reduced efficiency due to eddy currents. Understanding this mechanism clarifies how universal motors achieve their versatility in applications. The discussion highlights the fundamental principles of electromagnetism that govern motor operation.
garybuseyrulz
Hello to anyone out there. I am new to this board and I would like to have clarifications on some electrical engineering concepts that I've been confused about.
The first question i have is in regards to universal motors. I'm confused about how it works?? I realize that if you replace a stationary magnet with an electromagnet and connect either a DC or AC source, it will work. My question is mainly how it works? Maybe I'm just missing something. Thanks.
Imagine two bar magnets mounted, one above the other, on a vertical axle so that they can spin around but remain separated (poles spinning in horizontal circle). At a given angle between magnets there will be a torque due to opposite poles attracting and like poles repelling. Now imagine reversing the poles on *one* of the magnets. The torque will be reversed right? Now imagine reversing poles on both magnets. The torque will remain unchanged. In a universal motor, both the stator and the rotor are electromagnets, and when the AC current reverses it simply reverses both stator and rotor poles leaving the torque in the same direction.
Actually an ordinary DC motor (with stator and rotor electromagnets) will work with AC as well, just not very efficiently (eddy currents and stuff). The universal motor is really just a DC motor that has been enhanced to work efficiently with AC.
Yes! Thank you so much for that.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
