Engineering Use Circuit reduction, voltage and current divider to find i
The discussion revolves around the confusion regarding the equivalent resistance calculation in a circuit involving resistors of 18k, 9k, and 6k ohms. One participant questions why the solution sheet combines the 18k and 9k resistors in parallel instead of the 18k and 6k. Clarifications reveal that the 18k resistor is not in parallel with the 6k resistor, and the correct approach involves calculating the equivalent resistance of the 18k and 9k resistors first. Participants emphasize the importance of understanding series and parallel configurations to correctly analyze the circuit. The conversation highlights the need for clear diagrams and proper posting formats in technical discussions.
Neon32
< Mentor Note -- thread moved to HH from the technical physics forums, so no HH Template is shown >[/color]
in the solution sheet, He took the 18 ohms parallel with the 9 ohms and not the 6 ohms. I don't understand why he took this approach. I was going to take 18 ohms parallel with the 6 ohms and find their equivalent resistance then I'll take the result in series with the 9 ohms and find the total resistance of the whole circuit.
https://imgur.com/a/b9UPe
This looks like homework
more background on the problem would be helpful ... diagrams etc
Yes I'm uploading it. give me one minute
OK and you should be posting in the homework section and use the correct template
it isn't a homework though.
it's much preferable to post images in the thread
so they can be referred to easily :smile:
I don't see those on the diagram
if you take a close look, you would see he took 18 parallel with 9 ohms and found their equivalent resistance.
I assume you are referring to the 3rd diagram ?
also' you are misreading
18k = 18,000 Ohms not 18 Ohms
and
9k = 9,000 Ohms not 9 Ohms
OK now that we have that sorted out :smile:
yes that's correct and the resulting value will be in series with the 6k Ohms resistor
but the 18k isn't in parallel with the 6k so your reasoning is incorrect
can you see why it isn't ?Dave
and
no i don't know why it isn't.
Are the voltages across 18k, 9k and 6k equal?
do you know the difference between series and parallel ?
which do you think it is and why ?
