V/I: Power from Potential Difference & Current
The discussion centers around the equations related to power, potential difference, and current, specifically the formula P=VI. Initial confusion arose regarding the algebraic manipulation of the equations, particularly in deriving power from potential difference and current. Participants emphasized the importance of checking dimensions and using Ohm's law for clarity. The original poster acknowledged their mistake in algebra and confirmed that the correct formula for power is indeed P=VI. Overall, the conversation highlights the significance of accurate calculations and understanding fundamental electrical concepts.
kara123
(a) Derive an expression for power in terms of potential difference and current.
(b) Use the result from part (a) and Ohm’s law to derive an expression for power in terms of current and resistance.
p= E/T
V=E/Q
I=Q/T
e=QxV
t=Q/I
p=(QxV)/(Q/I)
=V/I
The expression I came up with for a) is the potential difference divided by current to get power but I have no idea if that is even right if someone could just prompt me in the right direction that would be greatly appreciated
What is "e"? You mean" E"? And the algebra is incorrect in final step. But I like your approach.
yes i ment E
Hi,
Whatever you do, check the dimensions. Do you know how to do that ?
Basically your relevant equations:
[power] = [energy] per [time]
##\ \ ##[voltage] = [energy] per [charge]
[current] = [charge] per [time]​
For part b) you also need Ohm's law as a relevant equation :wink: !
Check your algebra.
(QxV)/(Q/I) ≠ V/I
thankyou all for the help figured it out I must have been really tired while doing that algebra because I'm not sure what I was thinking the answer is P=VI
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
