Verifying properties of Van der Waals Gas
The discussion focuses on verifying properties of the Van der Waals gas, specifically transitioning from the Van der Waals equation to the Helmholtz free energy expression. The user successfully rewrites the Van der Waals equation and applies a Taylor approximation, leading to an expression for the Helmholtz free energy in terms of temperature and volume. The challenge arises when attempting to express the Helmholtz free energy in terms of temperature and pressure, with suggestions provided for substituting volume in terms of pressure. Ultimately, the user confirms that the suggested substitution works, resolving their issue.
baseballfan_ny
(a) Show that the entropy of the VDW gas is ##\sigma = N \{ \ln \left [ \frac { n_Q(V - Nb) } {N} \right] + \frac 5 2 \}##
(b) Show that the energy of the VDW gas is ##U = \frac 3 2 N \tau - \frac {N^2 a} {V} ##
(c) Show that ## H(\tau, V) = \frac 5 2 N \tau + \frac {N^2 b \tau} {V} - \frac {2N^2 a} {V} ##
and ## H(\tau, P) = \frac 5 2 N \tau + Nbp - \frac {2Nap} {\tau} ## where ## H = U + pV##
All results arc given to first order in the van der Waals correction terms a, b.
Van der waals equation: ## \left( p + \frac {N^2 a} {V^2} \right) \left( V - Nb \right) = N \tau ##
So a and b were pretty straightforward. Got stuck on part c.
The question says they approximated Van der Waals in first order in a and b. So I started with that by rewriting Van der Waals eqn as ## p = \frac { N \tau } { V - Nb } - \frac {N^2a} {V^2} ## and I then Taylor approximated ## \frac {1} {V - Nb} \approx \frac 1 V + \frac {N} {V^2} b ##.
Then p becomes
$$ p = N\tau \left( \frac 1 V + \frac {N} {V^2} b \right) - \frac {N^2a} {V^2} $$
and subbing this into ## H = U + pV## gave me ## H(\tau, V) = \frac 5 2 N \tau + \frac {N^2 b \tau} {V} - \frac {2N^2 a} {V} ##.
Now I'm stuck on getting ## H(\tau, P) ##. I'm pretty sure all I need to do is rewrite V in terms of P, but I'm not able to do that. Just trying to write V from the 1st order approximation I got above of Van der Waals equation gives:
$$ \frac {p} {N \tau} = \frac 1 V + \frac {Nb} {V^2} - \frac {Na} {V^2 \tau} $$
And that's still first order in a and b but I'm not sure how to solve it. Is there some approximation I'm missing?
Suggestion: ## PV=N \tau ## to zeroth order. Substitute ## V=N \tau/P ## in the denominator of the ## a N^2/V^2 ## term, (Edit: and/or the denominator of the ## H(\tau, V ) ## terms=it's very simple), and you then can get ## V ## in terms of ## P ## to first order in ## a ## and ## b ##.
Likes BvU and baseballfan_ny
Works! Thank you!
Likes Charles Link
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
