I Walter Lewin Demo/Paradox: Electromagnetic Induction Lecture 16
The discussion centers on the accuracy of Professor Walter Lewin's demonstration of electromagnetic induction in Lecture 16, with participants generally agreeing that his information is mostly correct but noting some complexities. Key points include the role of induced electric fields and how voltmeters measure voltage within circuits, emphasizing that voltmeters become part of the circuit and can be influenced by external magnetic fields. The conversation highlights the distinction between electrostatic fields and induced electric fields, suggesting that both contribute to the overall measurements in a circuit. Participants express a need for further clarification on the implications of these findings for understanding electromagnetic induction. Overall, the thread underscores the importance of accurately interpreting voltmeter readings in the context of electromagnetic phenomena.
mabilde
Right answer for the Walter Lewin demo/paradox about electromagnetic induction in Lecture 16 ?
Likes Averagesupernova, DaveE, alan123hk and 2 others
For the Professor Lewin video that I previously saw on the subject, I think professor Lewin had most of the information correct. In any case, the additional measurements that are made in this video are very interesting. See post 52 of this thread for the Professor Lewin video that I saw: https://www.physicsforums.com/threa...asure-a-voltage-across-inductor.880100/page-3 And yes, he does call that one "Lecture 16".## \\ ## Edit: To the OP @mabilde I see you chose the same name as the author of this video. Are you the author? ## \\ ## Additional editing: In a conductor, even though there is an EMF, where EMF ## \mathcal{E}=\int \vec{E}_{induced} \cdot d \vec{s} ##, a reverse electrostatic field will necessarily develop=otherwise the current would necessarily be very large by the equation ## \vec{J}=\sigma \, \vec{E} ## where ## \sigma ## is very large for a conductor. In that sense, I don't know that obtaining a voltage measurement inside the coil necessarily proves anything. In any case, an interesting set of experiments, but I think further discussion is in order. ## \\ ## And my input on this: A voltmeter and/or an oscilloscope consists of connecting wires plus some resistance and measures the current in the resistor circuit. It becomes part of the circuit loop, and there is nothing magical about it. It really can't measure the electric field or an EMF between two points in the circuit. It becomes part of the circuit, and if the resistance is chosen properly and the leads are connected properly, ideally it doesn't disrupt the circuit being studied, but that does not mean that (changing) external magnetic fields won't effect the results that are obtained. The EMF that is used to analyze the circuit containing the voltmeter can usually be obtained by Faraday's law. IMO, there is no need to try to localize the source of the EMF's as is done in this video by Professor Cyriel Mabilde.
I often find this sort of thing confusing but it seems that it works like this. Every elemental length of wire will have an elemental emf induced in it.
Your measurement leads have an emf induced in them which will depend on their path through the field from the primary and this adds (vectorially) to the PDs across the two resistors and the emfs induced in the two sides of the secondary.
Trivial situation: If the measurement leads are short enough and connected straight across each resistor then the emfs will be the 'share' of 1V that each resistor gets - as a normal potential divider. This is because there are no other emfs involved and you could think of the circuit as a 1V (AC) battery (or a 0.5V battery in each leg of the loop.
More complicated situation: Connect the voltmeter diametrically across the mid points of the two semicircles. In my diagram, I have split the induced emf into four 0.25V contributions. The dashed line splits the circuit into two symmetrical parts and, treating it as a simple DC circuit, the total PD measured will be 0.4 X 2 = 0.8V, because you have, effectively a potential divider. (I hope I have my + signs right in the diagram)
Even more complicated: Move the measurement leads off centre or make them longer and tilt them. They will have their own emf induced into them, which can vary from 0.5V to -0.5V so the measured value can be anything between 0.1V and 0.9V, depending.
Walking clockwise through the loop, then the emf's have the right polarity, but the resistor drops are opposed to this direction. The sum will be ZERO
Using two voltmeters (in series) as in your "split" circuit, will give 0.2 Volts on each voltmeter.
For example, considering the upper left : 0.25 Vemf -0.05 Vdrop = 0.2V
and for upper right: - 0.25Vemf +0.45 Vdrop = 0.2 V etc...So the sum of both voltmeters will be 0.4 Volts and not 0.8 Volts!
Note that in the first (left) case your voltmeter Hi is connected to the positive side of the emf, but in the right case the voltmeter Hi is pointing to the negative side of the emf.
Hope this will help to understand also the rest of my video and thanks for watching it.
Best greetings from Belgium
Cyriel Mabilde
Likes Charles Link
Now here is how I would solve this voltmeter problem: Let the EMF from the changing magnetic field be clockwise and 1.0 volt. Let the resistor on the left be ## R_1=100 \, \Omega ## and the resistor on the right be ## R_2=900 \, \Omega ##. Let the voltmeter across the middle be ## R_3= 1 \, M \Omega ## . Let the clockwise current through ## R_1 ## be ## i_1 ##, and the clockwise current through ## R_2 ## be ## i_2 ##. The downward current through ## R_3 ## is ## i_3 ##. ## \\ ## The 3 loop equations are: ## \\ ## 1) ## .5=i_1R_1+i_3 R_3 ## ## \\ ## 2) ## .5=i_2 R_2-i_3 R_3 ## ## \\ ## 3) ## i_1=i_2+i_3 ##. ## \\ ## A little algebra gives (eliminating ## i_2 ##) ## \\ ## ## 1.0=i_1R_1+(i_1-i_3)R_2 ## ## \\ ## and ## \\ ## ## 0=i_1(R_1-R_2)+i_3(R_2+2R_3)##. ## \\ ## The ## i_3 R_2 ## term can be considered small in two places, so that ## i_1=\frac{1.0}{R_1+R_2} ## and ## \\ ## the voltmeter reading is ## i_3 R_3=-\frac{1}{2}\frac{(1.0)(R_1-R_2)}{R_1+R_2}=+.4 \, volts ##. ## \\ ## @mabilde Thank you very much for your video. It was very interesting and instructive.
Likes sophiecentaur
Cyriel Mabilde
And greetings to you from sunny Essex UK.
Thanks for your comment. (The demo on the video is great, btw) I obviously got the signs in my calculation wrong and, because I am familiar with Potential Dividers, I can do it in an easy way . Take the top left corner as reference zero for the first half of the calculation. The two resistors are a potential divider with 10:1 ratio. The upper voltmeter should be showing the unbalanced volts between the two nodes of 0.2V (= 0.25-(0.5/10)) Likewise the other voltmeter will see -0.2V, giving 0.4V overall.
It's been a long time since I did this stuff and I'v looked at the problem again. I should have written some reference letters on the diagram and it would be easier to discuss but @Charles Link has solved the problem in yet another way (with Kirchoff 1) - and got the same answer!.
@mabilde I am very glad you posted this video. The experimental apparatus and results is very interesting. I am also very glad that it showed the results that confirms a combination of Faraday's law, and Kirchhoff's voltage law.
This is a cool experiment, which demonstrates that the induced electric field ## (E_i) ## is evenly distributed over every elemental length of the single-loop circuit. Thank you very much for your efforts and sharing.
Of course, in this case, we can define a scalar potential as ## (V_{ab} = IR - E_i L) ## in the circuit analysis.
However, it is worth mentioning that the scalar potential should have the operational meaning only when the leads of the voltmeter connected to these two points do not receive additional net induced EMF. In this case, the voltmeter will display the value predicted by the equation, as shown in the video. But in any case, of course this scalar potential is real, and we only need to use it correctly, an example of this is the output of the transformer secondary.
I think that, generally speaking, two electric fields are superimposed in an electromagnetic induction circuit, one is the electrostatic field ## (E_c) ## corresponding to the scalar potential, and the other is the induced electric field ## (E_i) ## , and ##~ E_{total} = E_c + E_i~ ## . In a zero-resistance wire, ## (E_c) ## and ## (E_i) ## cancel each other in the direction of the wire. In the resistor, ##~ E_c~ ## may be larger or smaller than ## ~E_i ~##, or equal to each other, depending on the circuit.
In any case, the closed-loop line integral of the circuit's ##~ \oint \vec E \cdot d \vec L ~## is equal to the ##~ total ~~EMF = -\frac {dΦ} {dt} ~##, which is not conservative and different from the zero value of the closed-loop line integral in the DC circuit (assuming the battery has an internal electric field, which points from positive terminal to the negative terminal). I believe this is the key point that the professor wants to explain. What he said does not contradict or deny the existence of the above-mentioned scalar potential and electrostatic field.
Likes Charles Link
Hi @alan123hk,
good commentary, thank you.
My overall intention in the blog was to call attention to the existence of two E fields of separate provenance which, somewhat incredibly, many incl. Dr. Lewin seemed unaware of, and that that view provided an alternative explanation of the phenomena..
My criticism of Dr. Lewin's lecture was in essence his comment that "Kirchhoff was wrong". Kirchhoff's voltage law as applied to electric fields rather than potentials applies to what you call the ## E_c ## field only. Lewin implicitly defined voltage as ## \int (\bf {E_c + E_i}) \cdot \bf dl ##. He thus seemed unaware of what exactly "voltage" is, mistaking it for ## \int \bf E \cdot \bf dl ## where ## \bf E = \bf E_i + \bf E_c ##.
As you point out, the voltmeter readings nolens volens include the emf set up by the Faraday setup he has. He never explained that those readings are not actual voltages. Had he held up the voltmeter leads directly above the ring he would have read the correct voltage which is 0.4V and which would have canceled the emf of the ring itself with the emf induced by the flux cutting the voltmeter loop. But he didn't, alas.
Failure to identify the two electric fields of differing sources (## E_c ## from charges only and ## E_i ## from induction is I feel a serious omission. For one thing, had he been asked if & where charges are produced he would have had no answer, or so I believe.
What he did succeed in doing is that if your only goal is to analytically determine voltmeter readings for the different lead positions by considering the total E field alone then yes he did that. What he did not do was to point out that those readings are not the voltages between the two lead connections to the ring except if the leads are held directly across the resistors.
You might look at the references I provide, especially MacDonald's. He too addresses the Lewin "conundrum" & properly defines scalar potential aka voltage.
Also, did you see the infamous C. Mabilde video? That got me started on this whole odyssey. His data were correct but what he really showed was a simulation of the voltages around the ring (by equating the flux rate of his voltmeter lead setup to the actual voltage). He also, by not explicitly identifying the sepate but coincident E fields, came up with some hocus-pocus transformer-like coupling mechanism for the voltmeter readings. Still, he was spot-on redressing Lewin for his Kirchhoff remark, synthesizing the actual voltages around the ring, and although I never checked into it, Lewin's self-contradictory statements about the fields in the wire. Taken with that grain of salt the video is a real eye-opener.
As for my analysis of the battery circuit, that has generated enough controversy that I recommend ignoring it. What is certain is that the sum of line-integrated ## E_c ## fields around the circuit including the battery = 0 a la Kirchhoff.
Lovely video.
I'll just add that this isn't just an academic exercise. If you ever find yourself in an EE lab trying to make measurements, for example of a high current power supply switching transistor, you will absolutely have to deal with these effects. Oscilloscopes are one of the more difficult instruments to use well, if you need accuracy. It's all about the probes, which novice EEs tend to ignore. That long ground lead that seems so convenient at first is a huge problem in high frequency circuits.
This is a great example of why you have to do "sanity checks". Don't just make a measurement once, with one setup. Move stuff around and see if the data changes unexpectedly.
Yes! I'll spare y'all the diatribe I wrote in a related post a while ago. But just point out that Kirchhoff's voltage and current laws are for LUMPED ELEMENT CIRCUITS. If you want to use them in the presence of induced emf, you must put some inductors in your schematic. This, of course, is why lumped element models don't work sometimes.
Why does Lewin say most physicists get this wrong? It's because he is asking a ill-formed question. I, for one, don't think of Maxwell's equations if you show me a schematic diagram. That format is so highly stylized that it lacks the required context for EM problems.
rude man said:
Failure to identify the two electric fields of differing sources (Ec from charges only and Ei from induction is I feel a serious omission. For one thing, had he been asked if & where charges are produced...
Let's take a look at how the distinguished Professor Lewin explained the build up of charges in the circuit and the role of these charges in the overall electric field. I think this is a good explanation. :smile:
This video is relatively long, maybe we can watch it from 34 minutes.
Likes Charles Link
Thank you for that! I am happy to agree that with this video Dr Lewin has fully and correctly explained split E fields and the necessary buildup of charge in a resistively asymmetrical ring. I am in total agreement (except see below).
He's given several lectures on this topic (Faraday induction). It appears that the one I saw and responded to in my blog (my 1st blog btw; I discuss this theme in more detail and perhaps a bit better in the next blog, "How to Recognize Split E Fields" (link below). I think everything I said about that video (lecture 16 I guess) in my 1st blog is correct. He never mentioned split fields or charge buildup in that lecture and in fact admitted as much in this video.
OK, it's a bit advanced but telling students that the voltage between A and B depends on how the meter is hooked up is just plain wrong. As Mabilde correctly said, there is one and only voltage between A and B and that is 0.4V (in lecture 16). It's not advanced physics to define potential difference correctly IMO.
My problem with him then remains defining potential difference as the line integral of the electric field. This is in general incorrect. "Potential" eo ipso implies a conservative E field: . For his integral to signify potential difference, the E must be replaced by what you called ## E_c ##. This was really my only criticism of his lecture 16 (along with his corollary "Kirchhoff was wrong").
Anyway, watching Lewin is pure pleasure. I haven't laughed so hard in years! And I wondered then and do now: where are all those dummies who don't understand, or even believe in, his lectures? Omitting charge buildup is one thing but disbelieving his voltmeter readings is ludicrous. Hope they aren't MIT students!
https://www.physicsforums.com/threads/how-to-recognize-split-electric-fields-comments.984872/
Again I suggest ignoring the battery part. Too controversial! Also, you may be amused or bemused by all the comments, or you might just ignore them.
https://www.physicsforums.com/insig...ectric-vector-potential-and-its-applications/
(this may be of interest as proof that the Em field is invariant with whatever is placed in it, like a ring or chunk of metal or anything else. The Em field is solely defined by the magnetic field.)
Likes Charles Link
Or read them and try to understand what was the criticism.
Just my two cents: In all of this I think @rude man has presented some reasonably good physics. I am glad to see that in this thread it is starting to see a much better reception. :)
rude man said:
Hi @alan123hk,
I'm late to the party on this, but I've been obsessed with this problem recently and all the misconceptions surrounding it.
It seems that you accept that Lewin's voltmeters measure the Int(E.dl) along different paths, and give different measurements. Your issue seems to be a different meaning of 'voltage' as the sum of ONLY the electrostatic E-field, as McDonald does in his paper. The sum of these static produced fields indeed is zero around any loop, but what use does it serve? The consequence is that you can define different 'potentials' at different points in the same conducting wire. This leaves you with potentials that 1) are not measurable by a voltmeter, 2) vary in a region with ZERO net E- field , and 3) have no connection to the work done on a test charge as it moves from one point to another.
In what possible way does such a measurement correlate to what we usually think of potential? This is like moving an object horizontally in a gravitational field, which requires no work, and saying its potential energy has changed. It's a mathematical abstraction, nothing more, and has no physical basis.
I found it interesting that you picked out C. Mabildes' mistake in interpreting his results. He thinks he's measuring McDonald's 'scalar potential', when he's actually just measuring the flux through the pie-slice shaped area in his leads, which is proportional to the angle. You obviously see the problem, but generously say that he is 'simulating' measurement of the scalar potential, rather than saying that he's completely misinterpreting his results.
While I agree that it is instructive to consider both the induced E-field (Ei) and the electrostatic E-field (Ec) to analyze the problem, the fact is that it is only the combined field that does work on a test charge, and that field is non-conservative. Hence different measurements for different paths. Neither measurement is wrong, they're measuring different things. There is no 'true' potential difference between the two points, because you can not define potential for a non-conservative field.
Likes weirdoguy and TSny
I've never understood the controversy with Lewin's paradox. Why is it accepted that the conductors used in a measurement are somehow not supposed to behave as conductors of the circuit? It's ALL about knowing what introduces errors in what is trying to be measured.
Think of it this way: Set your voltmeter to AC, short the probes together and make a single loop around a solenoid setup similar to and driven as the one in the @mabilde video. The fact that a voltage will be read on the voltmeter should give a clue that a significant error will be introduced considering the voltmeter leads very much resemble the setup. There are many ways to 'blow your mind' with this but it always comes back to the same thing.
Not sure exactly what your take is, but... I totally agree with you that voltmeter leads form a circuit when connected and should be analyzed as such. And I agree with you that 'shorted' voltmeter leads around a solenoid will read the emf produced - it has to, by Faraday's law. If there's flux penetrating the measurement loop, it will show up in the reading.
But by the same token, if there is no flux in the measurement loop, then there is is no error - you read exactly what you intend to measure, again by Faraday's law. If I want to measure the voltage across a section of wire with a resistor, and I put my voltmeter leads on either side of the resistor, as long as there's no flux in the new loop (like the voltmeters on either side of Lewin's circuit), it's accurate.
Part of the 'bad thinking' around this topic is that people assume that a solenoid will affect any nearby wire regardless of placement. That's not really true - all that matter whether flux penetrates the surface bounded by the loop formed by the voltmeter leads and what you're trying to measure. In the @mabilde video, he most definitely has wide open measurement loops with flux passing through them. He thinks he's measuring 'scalar potential', but all he really did was create a very precise flux meter. Bottom line - emf affects a loop. You can't discuss the 'emf' in a section of a wire without considering what the loop is.
Somehow, I'm reminded of a comment about legislators speaking on the floor; 'everything's been said, but not everyone has said it yet'. You can read, or you can type, but you probably won't do both in this thread.
Likes berkeman and hutchphd
I read this whole thread - there are several points that seem to have reached a consensus but are just plain wrong or misleading.
In an electromagnetic induction system, when current flows through a impedance, a voltage and corresponding electric field is generated. As for this voltage, or the approximate potential difference when the frequency is very low and tends to zero, it is difficult to say whether it can be measured with a voltmeter. I think it depends on the situation. In some cases, it can also be said that everyone's point of view may be different.
For example, when using a voltmeter to measure the voltage at the output load of an actual common transformer, one would think that it is measuring the transformer's EMF output, which is of course true. But some people may assumed that this is the voltage drop in the load impedance, because the measured voltage value is constant regardless of the position of the voltmeter itself and its leads, so this voltage is due to the electric field without curl, and this electric field should be generated by the electric charge of the system.
Another example, in real life the power company will say what is the voltage of the electricity it is supplying to the customer, not what the EMF is because from the consumer's point of view it is just a voltage. Regarding the work done when a charge is moved, of course all the energy comes from electromagnetic induction. But for consumers, I think it's acceptable in the context of their application to think of energy transfer as a voltage mechanism or even roughly a potential difference, since the difference is so small that it can be ignored.
I am curious about which consensus you think that would be. I'm also wondering if you are saying that it is impossible to position voltmeter leads in a way to obtain a measurement without having the emf affect the reading.
The consensus I was referring to was the existence of a measurable, scalar potential that exists in a conducting wire. While you can certainly separate the static E-field (Ec) and electrically induced E-field (Ei), as McDonald does in his paper, this potential is just a mathematical abstraction. It's not physical, because a change in this potential does no work on a charge. It's not measurable, because a voltmeter only measures the integral of total E-field along a path. @mabilde believes he's measuring this potential, but as pointed out by both myself and @rude man, he's simply measuring the changing flux through passing through the loop formed by his leads (if you watch his video, it's really easy to see the pie-slice shaped loops the flux is passing through). This scalar voltage doesn't even conform to Ohm's law for any resistors whose length is not negligible when subjected to and induced field. So this definition of voltage forces you to bend over backwards just in order to have something that always sums up to zero around a loop.
If you define voltage as E.dl, which does agree with Ohm's law and measures the work done on a test charge, it does not sum to zero around a loop when you have a changing magnetic flux, in accordance with Faraday's law, and gives rise to path dependence (hence the two voltmeter measurements).
Regarding the voltmeter measurements, voltmeter leads can certainly be positioned without being affected by the emf. There's a very very simple test to determine whether your measurement is being affected by an emf of not. Look at the circuit loop formed by the voltmeter, the leads, and the portion of the circuit you are intending to measure. If there is a changing magnetic flux passing through this loop (i.e. the imaginary surface that your loop bounds), then that total flux term , -d(phi)/dt, will be included in your measurement - per Faraday's law - and you must account for it. If there is no magnetic flux passing through this loop, then your voltmeter is exactly in parallel with whatever you are measuring, and will show the intended voltage. This is still in keeping with Faraday's law, but as the flux is zero, you can think of it as Kirchoff's law.
The tendency by many to talk about the induced emf in a 'section' of a wire is very misleading. Emf doesn't act on a wire, it acts on a loop. You can certainly talk about the induced electric field in a wire, but that E-field adds vectorially with any other E-fields present (like Ec), and they sum to zero in a conductor.
There is a simple resolution to whether or not a transformer has a 'voltage' across it. Let's just assume it's a coil of wire (solenoid) with an external B-field changing through it. If you want to measure the voltage between the terminals, there are two different paths you can consider. One path extends between the terminals on the outside of the solenoid, through free space. If you attach a voltmeter to these points, the outside path your are measuring IS the path of the voltmeter leads. There is definitely an electric field along this path, and the integral of this path is non-zero. Indeed, it is equal to the induced emf. But as it is a real electric field, it counts as a voltage ALONG that path. This is exactly how Feynman defines the voltage of an inductor in his E/M lectures.
The second path lies between the terminals and follows the wiring. It corkscrews along the solenoid. This is cumbersome to measure as you would have to attach voltmeter leads at nearby points, and add up the readings as you move the voltmeter leads around the solenoid one section at time, working your way around from one end to the other in a corkscrew pattern. If you did, you would find that this sum is zero, which is keeping with the fact that the solenoid wire as negligible resistance - it's a conductor. In the same lecture, Feynman explicitly states that Int(E.dl) around this path is zero.
The discrepancy is no mystery. The electric field formed by the changing flux is non-conservative, a fact that comes directly from the Maxwell version of Faraday's law: curl E = -d(phi)/dt. There for the int(E.dl) between two points is path dependent. In a circuit, any loop containing the outside path will be conservative, the emf is counted as a voltage. In a loop containing the path through the wires, the path integral will be non-zero as there is no voltage along the wire. BUT there is a changing flux through this loop, so that has to be accounted for via direct application of Faraday's law. Now the emf is on the other side of the equation, as it's not part of the loop integral. You get the same equation, but the emf term is just that, an induced emf.
Usually we don't think about the path difference due to the difficulties of measuring the corkscrew voltage. But if you have a single turn loop, the circuit is now planar. You can easily attach a voltmeter to either side of the loop (the open side connecting the terminals one one side, the loop section on the other side). When you analyze the voltmeter circuit loops, one will contain the flux, one will not. The loop that that contains the flux is just measuring the electric field on the outside path, or the flux it self, however you want to count it. This is the 'voltage' of the inductor as Feynman defines it. The other voltmeter loop does not contain a flux. There is not electrical field to measure, so it reads zero. This is equivalent to Lewin's two volmeters. He just has another resistor, and has opened up the loop so it is formed by the whole circuit.
There is no magnetic flux passing through the pie shaped conductors that radiate out from the center of the solenoid and make contact with the single loop conductor in the @mabilde video. The flux lines cut lengthwise along those conductors.
Lewin demo/paradox and general ordinary transformers are electromagnetic induction systems, so the working principle is basically the same.
Haven't the common transformers we use every day already shown that a voltmeter can be used to measure scalar potential in such systems?
Even though it is difficult to measure with a voltmeter in some cases like the Lewin demo/paradox, is there really no other way?
I guess you mean that the electric field inside a perfect wire is 0. If the electric field in a region is zero, then of course there is no change in potential in that region. But note that this scale potential still acts on the wire surface and outer space
So isn't the voltage output by the transformer doing work on the load resistance?
I completely disagree. The pie-wedge shaped surface of the voltmeter loops are parallel to the ground. The magnetic field of the solenoid points straight up, at least in the interior of the cylinder he is measuring. The magnetic field therefore penetrates this surface at a perfect 90 degree angle, straight through. All he's measuring is the rate-of-change of this flux on his voltmeter.
Even though it is difficult to measure with a voltmeter in some cases like the Lewin demo/paradox, is there really no other way?I guess you mean that the electric field inside a perfect wire is 0. If the electric field in a region is zero, then of course there is no change in potential in that region. But note that this scale potential still acts on the wire surface and outer spaceSo isn't the voltage output by the transformer doing work on the load resistance?
When you measure the output voltage of a transformer (taking a voltmeter as the load that completes the circuit), you can analyze it two ways. If you draw a loop that passes through the interior of the conducting wire in the solenoid, The only voltage drop is across the load. The emf is provided by the changing magnetic field which penetrates the 'loop'. The loop is a bit hard to visualize as it consists of a corkscrew, but imagine a piece of rotini pasta. The field lines penetrate this surface once every turn, giving the net emf. In this analysis, there is no voltage across the transformer, just an induced emf, using Faraday's law to analyze the loop.
The other analysis loop consists of the voltmeter and a path that connects the terminals of the solenoid OUTSIDE the windings (hence outside the circuit). There is no flux which penetrates this surface, but there is an electric field that runs outside the solenoid, whose integral is equivalent to the induced emf. Using this loop, you could fairly refer to that electric field integral as a voltage, and use Kirchoff's law to analyze the loop.
Either way, on the load side you measure a voltage. You can think of this as the induced emf from the magnetic field, or a voltage between points directly outside the solenoid. The former is more physically correct I would say as it is the fundamental principle involved.
The scalar potential ignores the induced emf completely. It bases it's definition of potential solely on the electric field generated by the electrostatic distribution of charge at the ends of the resistor. So if the voltmeter is the only load, it has charge build up on the ends of it's internal resistor. This charge distribution creates a static field that cancels out the induced field in the wire, but concentrates in the resistor itself. The sum of this field ONLY adds up to zero around the loop, and as such you can assign a number, or 'potential' , to any point in the loop. But as this 'potential' ignores the induced emf completely, it has no relation to work on a test charge as it moves around in the solenoid windings. It costs nothing to move a charge from higher to lower 'potential' or vice versa along the solenoid path, and thus renders the concept of potential meaningless (mot to mention, this definition of potential or voltage does not agree with Ohm's law unless the resistor in question has zero length - in a circular loop for instance, if a resistor took up a quarter of the circles length, the static or scalar potential across it would differ from I*R significantly).
However, it DOES require to work to move a test charge through the load resistor. Hence it takes different amounts of work to move a test charge from one terminal of the solenoid to the other depending on which path you take. So if you define voltage between two points in the traditional way, as the amount of work-per-unit-charge required to move a test charge between the points - or equivalently Int(E.dl)- you find the voltage depends on the path taken, i.e. path dependence. This is what a voltmeter measures and why Lewin gets different readings on his voltmeters.
Compare this to a regular DC circuit with a battery and a resistor. Moving a test charge from one terminal of the battery takes the same amount of work whether you move around the circuit through the resistor, or on the other path directly through the battery - i.e. path independence.
The bottom line is that a charge only 'feels' electric field. It doesn't care whether a field is induced or electrostatic. Our standard definitions of voltage are based on force and work, and should therefore depend only on how a charge is affected, not on mathematical abstractions that have no physical meaning.
@tedward
Thanks to #29 for the informative and valuable reply, a great comment. I agree with most of the points. But there are still some points that I don't fully agree with.
We are now dealing with an electromagnetic induction system, and we assume that its total electric field is the result of the superposition of the induced electric field and the scalar electric field produced by the distributed charge. But the total E field of this system is actually a non-conservative field with no potential difference. Since every part of the overall system is interrelated and affects each other, I don't think that "The scalar potential ignores the induced emf completely".
I think no matter anywhere in the system, including in the solenoid winding or in the external load circuit, whenever there is current passing through the resistor, there will be a relative scalar potential difference and corresponding energy loss, so this scalar potential difference provides energy for the resistor (The scalar potential around the solenoid winding wire is more complicated, it may not be equal to the current times the resistance of the wire due to the induced electric field), which is one of its meanings in the system. It works even if the net electric field in the solenoid zero resistance winding is zero. when current flows through the solenoid winding, the actual work of this scalar field is to accept the energy provided by the induced electric field, how can it be said that its existence is meaningless?
Please note that the output port of the solenoid is defined by ourselves. In fact, any two endpoints on any wire segment can define an output, and even though the solenoid has a zero-resistance winding, there is a corresponding scalar potential.
Transformer with multi-tap output on secondary winding​
I don't understand why you say that the definition of this scalar potential does not conform to Ohm's law.
Please refer to the link below #6,
https://www.physicsforums.com/threa...erms-of-current-density.1048001/#post-6830095
  • #31
Relative to the ground is not relevant. Coil relative to the pie shaped is relevant.
Yes the flux lines are precisely parallel with bore of the solenoid, or as you call them, straight up. But, as the field grows and shrinks with the current in the solenoid the vertical flux lines move in and out from the exact center of the bore. This does NOT cause the flux lines to cut across the short wires that make up the pie shape at an angle that is non parallel to the to those short pie shaped conductors. The flux lines simply travel parallel with those conductors. This does NOT cause a current to flow.
Think of the flux lines as actual strings or wires. The only way current is induced is if the flux 'strings' are to move in such a way as to tangle with the wire. Sliding parallel like a violin bow along the strings is a good example to compare to. The bow moving across the strings or the strings sliding across the bow will get a sound out of a violin but the same comparison with induction will not yield a current.
Well, naturally that is reflected by the voltage generated but I'm not sure this is how you meant it.
  • #32
I would like to introduce the relevant situation further. Does not violate Ohm's law. It is precisely because the definition of the scalar potential must be obeyed, and Ohm's law must be obeyed at the same time, so the calculation equation of the scalar potential must be ## V_1-V_2=IR_{12}-\varepsilon _{12}~~~\Rightarrow ~V_1-V_2=IR_{12}-\int_1^2~dl\cdot E^{'}~~~~~~##:smile:
  • #33
What I meant by saying the scalar potential ignores the induced emf, is that this definition of voltage focuses on the scalar potential and disregards the induced emf as a voltage, even though yes, the scalar potential is influenced by the induced field. Let's imagine this experiment: A good diagram would be to think of a circuit as a clock, with single resistor in a circular loop with a magnetic flux at the center, so the loop IS the transformer secondary, similar to the Lewin circuit. We place the tiny resistor at the top of the loop, at the 12 o'clock position. Say the emf is 12V, and the resistor is 12 ohms, giving a current of 1A. You draw the net E-field (induced plus electrostatic) along the circuit. It's zero everywhere except for inside the resistor (which is negligible length for now), and it points to the right. This field is large, and when multiplied by the length of the resistor gives 12V (same as the emf).
You then separate the diagram into two components - one for the induced field only, one for the electrostatic field. From symmetry, the induced field diagram is uniform around the clock, pointing clockwise, just as if it would be in free space, from 0 (midnight) to 12 noon. Now the static field diagram must cancel out the induced field diagram everywhere but in the resistor, so this diagram is also uniformly spread in the COUNTER-clockwise direction - starting at 12 noon and going back to 0, or midnight. The other difference about the static field is that it now just in the resistor, it points to the right, or clockwise.
Now since the static field sums up to zero around the clock, we can define a number that we'll call scalar potential. We disregard the induced field diagram and only focus on the potentials on the static field diagram. Taking midnight to be ground (0V), the scalar potential increases in the clockwise direction, against the static field. One hour is one volt, so going clockwise to noon gives you your 12V. But in the tiny space between noon and midnight (say this is one-second on the clock), the potential suddenly drops back down to zero.
Now overlay the actual clock circuit over the diagram, and write down the potential values around the diagram (same as the clock numbers in volts). Pick any two points, say 3:00 and 5:00. The scalar potential predicts a difference of 2V. Hook up a voltmeter to these points, and you measure zero. This is because the voltmeter only measures integral of NET E-field, it has no way of discerning static from induced. Now, pick up a small test charge and place it in the loop (this part is just a thought experiment of course). As you move this charge between 3:00 and 5:00, you will find it takes no work to move it in either direction, no matter the size of the charge, even though the scalar potential difference is 2V.
Now move the test charge from one side of the resistor to the other, through the resistor. If you go left from just after midnight to noon, it will take you 12V times your charge worth of work, as the scalar potential predicts. (If you go the other direction, the field pushes your charge for you and the work you do is -12V * q.) But now push your charge from say 2:00 to 10:00 through the resistor. The scalar potential difference is 8V. But the work you do is still 12V*q, just as when you moved it from midnight to noon.
What we're seeing is that you cannot do work calculations using the scalar potential only. This is what I mean when I say that scalar potential is unrelated to the work done on a charge. Without including the induced field, the notion of potential difference as work - something that is foundational for thinking about voltage - no longer holds. The best you can say, as you mentioned, is that the TOTAL of the scalar potential in the solenoid is equal to the amount of work done on the load. The individual values along the path are meaningless. (Edit: see below)
What about Ohm's Law? As long as the resistor is negligible length, there's no problem. But now say our 12 ohm resistor extends uniformly from 6:00 to 12 noon clockwise, so on the left side of the clock. Emf and current are still the same, 12V and 1A respectively. So by Ohm's law, the Int(E.dl) voltage (I'll call this path voltage) across this resistor is 12V. But considering the induced emf ONLY, by symmetry, this must be 6V, spread uniformly. Therefore, the electrostatic potential across the resistor is also 6V, as they add up to 12V. But the scalar potential, 6V, doesn't give you IR which is 12v. This is what I mean when I say scalar potential doesn't conform to Ohm's law. You can still apply Ohm's law, but not without including the induced field, per the equation you linked to.
It seems to me that using this definition of voltage is bending over backwards to satisfy a single requirement: "Sum of voltage around a loop is always zero." But what are we giving up? You have to redefine Ohm's law to include a separate term, the integral of the induced field. You give up the notion of potential difference as work, unless you include that same term. You can't measure it with a voltmeter. And it does nothing to change the physics - the fact that the net E-field is still non-conservative and therefore path dependent.
On top of that, imagine a circuit that has no symmetry, just a messy loop with an irregular field. Trying to calculate the static potential at every point means you have to somehow integrate the induced field up to any point. It's a damn near impossible task except for the most symmetric circuit. And the minute you do work out all the scalar potentials, as soon you move wires around everything is different. The net E-field voltage doesn't have this problem.
It's far more useful to define 'path voltage' as the integral of E.dl, as it is the same voltage that V=IR uses, is measurable by a voltmeter, and naturally corresponds to work done on a test-charge along a given path. Yes, you now have to give up path independence and the idea of a fixed potential, but that's a direct consequence of the Maxwell-Faraday equation, and should not be surprising.
(In your transformer diagram, all choosing different taps does is change the amount of emf in your circuit, equivalent to increasing the number of windings or strength of d(phi)/dt.) EDIT: Ok I understand why you included this diagram, the scalar potential markings indicate the amount of emf you'll get. But that still only applies if you use a path between the terminal points that flux penetrates. If you add up the E.dl voltages along the wire itself, between ANY two points, or as in my clock circuit above, you get zero.
  • #34
Right - this is the new definition of Ohm's law that accommodates scalar potential. But the good old V = IR that everyone actually uses and is measured by a voltmeter is the path voltage, Int(E.dl).
  • #35
The only law that must be obeyed in physics territory is Maxwell. Period.
(And tax Law)
Likes DaveE
  • #36
(And tax Law)
All laws must be obeyed within the constraints of their definitions. This is of course drifting into territory that is a different thread than this one here on PF by (some) different posters. But the point still stands.
  • #37
(And tax Law)
Not necessarily the case, tax laws are often violated, so you know from the news, if it is not legal tax avoidance, those people will be convicted and punished.
  • #38
(And tax Law)
Your description of the changing flux tells me that you have don't have a solid understanding of Stoke's theorem and/or Faraday's law, and probably have a bad mental picture of the magnetic flux itself. The magnetic field, B, generated by the current in a solenoid, whether constant or changing, points along the axis of the solenoid (vertically in this case), and is spread uniformly throughout the interior, just like the velocity field of water flowing through a pipe. If the current oscillates, so will the strength of the B-field, but the field lines themselves don't move - they just oscillate their direction, positive or negative, or in this case up and down. The B-field does not point radially outward until you leave the solenoid (the end of the pipe so to speak), where it bends outward around the top and completes the loop outside and back through the bottom, though it's much weaker here.
Check out @mabilde's field diagram at 7:19 in the video for a picture, or google image search magnetic field of a solenoid. That uniform field in the center changes strength and sign only, not location. Since the field is perpendicular to the circular area of the single loop, the net magnetic flux through it just the the field strength times the area, and the emf is the rate-of-change of this quantity.
Stokes' Theorem says that the line integral of a field along the boundary of a surface is mathematically equal to the integral of the curl of the field over the area of the surface. Maxwell's equations says the curl of the electric field is -dB/dt. Put them together and you have Faraday's law - the circulation of electric field along a loop is equal to the rate of change of the magnetic flux through the surface bounded by the loop. The magnetic field doesn't even have to touch the loop at any point - the E-field created by the changing flux spreads through out space, circling the solenoid. The emf is the line integral of this e-field.
Mabilde's voltmeter leads, together with the particular section of the single loop he's measuring, forms a sector - an imaginary pie-wedge shaped surface, just like in a pie chart. When a changing magnetic flux penetrates this surface, it creates an E-field along the this measurement loop itself, and the integral of this e-field around the loop is the induced emf. This quantity is the only thing he's measuring apart from the drops in the resistors. There is no 'voltage drop' in the wire section of the loop he's measuring as it's a conductor. When there's no resistor in his measurement loop, all he has is a flux measuring device. He gets great results too (his setup is marvelous) - very clean numbers predicted exactly by Faraday's law. He just completely misinterprets what he's reading.
  • #39
I've thought of this many times and it's intuitive for there not to be. Take a look at a thermocouple. There is a voltage based on the temperature differential between the open and closed ends and it is most certainly a conductor. I know it seems like I'm trying to cloud the issue. All I want to point out with this is that just because something is a conductor doesn't mean it cannot have a voltage across it.
  • #40
So I had to review thermocouples, but if I understand the basic principle, the Seebeck effect describes how a temperature difference provides an emf in some conducting material. Connect two different materials that have a different material properties (voltage to temperature gradient), and you get a measurable voltage at the ends. The idea (I believe) is similar to an induced emf, but now it's temperature differences that create the emf. But the response of free charge is the same - charges respond to the temperature-induced emf by creating a very brief current, until they pile up at the two ends - positive charge on one end and negative on the other.
Once the system has reached equilibrium (on extremely small timescales), current stops flowing. The charge distribution creates its own static field in the opposing direction, which cancels out the temperature-induced field. So now you have a potential difference /voltage between the ends, and zero net field inside the conductor. This has to be the case - if there was any lingering NET E-field, free charge would flow until was canceled out, that's just how conductors work. The same thing happens in conductors where there is an induced emf - charge piles up at the resistors, or at the ends of an open circuit, creating a static potential that cancels out the induced field. This is just like two unconnected wires sticking out the ends of the terminals of a DC battery. You can measure the potential difference between the ends, but there's no NET e-field in the wires themselves.
Now, there ARE exceptions to this rule. Commonly cited are induced fields with very high frequencies (like terahertz) or extremely large circuits like transmission lines, where the emf changes too fast for the charge to keep and you can have temporary fields that don't equalize. But a better exception which illustrates the point is this: Take a conducting wire, - not a circuit, just a rod of copper say. Position the rod perpendicular to a magnetic field. Say the field is pointing vertically upward, and the rod is horizontal. Now move the rod perpendicular to its length and to the field at some velocity. The magnetic force (the qv x B component of the Lorentz force) pushes positive charge to one side and negative to the other. Again, the charge builds up at the ends until an equilibrium is reached, with a measurable voltage at the ends, and an opposing electrostatic field is created by the charges. But the here's the cool part - the magnetic force is just that, a force.
It's not from an electric field (at least in the stationary frame of the original magnetic field we're moving in). So the electrostatic field from the charges exists, and acts to cancel out the net FORCE on any free charge. Basically the electric force on a charge and the magnetic force cancel eachother out, but the net field is still present. So you have a conductor with a sustained non-zero electric field, but the net force on any free charge is zero. This can only happen if a conductor is moving in a B-field, which isn't happening in any of our examples. But it does hammer in the point that you can't have net FORCE on a charge in a conductor once it's reached equilibrium. And for stationary circuits, this means you cannot have a net FIELD in the conductor. (Feynman discusses this in his E/M lectures).
  • #41
You then separate the diagram into two components - one for the induced field only, one for the electrostatic field. From symmetry, the induced field diagram is uniform around the clock, pointing clockwise, just as if it would be in free space, from 0 (midnight) to 12 noon. Now the static field diagram must cancel out the induced field diagram everywhere but in the resistor, so this diagram is also uniformly spread in the COUNTER-clockwise direction - starting at 12 noon and going back to 0, or midnight. The other difference about the static field is that it now just in the resistor, it points to the right, or clockwise. Now since the static field sums up to zero around the clock, we can define a number that we'll call scalar potential. We disregard the induced field diagram and only focus on the potentials on the static field diagram. Taking midnight to be ground (0V), the scalar potential increases in the clockwise direction, against the static field. One hour is one volt, so going clockwise to noon gives you your 12V. But in the tiny space between noon and midnight (say this is one-second on the clock), the potential suddenly drops back down to zero.
Now overlay the actual clock circuit over the diagram, and write down the potential values around the diagram (same as the clock numbers in volts). Pick any two points, say 3:00 and 5:00. The scalar potential predicts a difference of 2V. Hook up a voltmeter to these points, and you measure zero. This is because the voltmeter only measures integral of NET E-field, it has no way of discerning static from induced. Now, pick up a small test charge and place it in the loop (this part is just a thought experiment of course). As you move this charge between 3:00 and 5:00, you will find it takes no work to move it in either direction, no matter the size of the charge, even though the scalar potential difference is 2V. Now move the test charge from one side of the resistor to the other, through the resistor. If you go left from just after midnight to noon, it will take you 12V times your charge worth of work, as the scalar potential predicts. (If you go the other direction, the field pushes your charge for you and the work you do is -12V * q.) But now push your charge from say 2:00 to 10:00 through the resistor. The scalar potential difference is 8V. But the work you do is still 12V*q, just as when you moved it from midnight to noon. What we're seeing is that you cannot do work calculations using the scalar potential only. This is what I mean when I say that scalar potential is unrelated to the work done on a charge. Without including the induced field, the notion of potential difference as work - something that is foundational for thinking about voltage - no longer holds. The best you can say, as you mentioned, is that the TOTAL of the scalar potential in the solenoid is equal to the amount of work done on the load. The individual values along the path are meaningless. (Edit: see below)
It seems to me that using this definition of voltage is bending over backwards to satisfy a single requirement: "Sum of voltage around a loop is always zero." But what are we giving up? You have to redefine Ohm's law to include a separate term, the integral of the induced field. You give up the notion of potential difference as work, unless you include that same term. You can't measure it with a voltmeter. And it does nothing to change the physics - the fact that the net E-field is still non-conservative and therefore path dependent. On top of that, imagine a circuit that has no symmetry, just a messy loop with an irregular field. Trying to calculate the static potential at every point means you have to somehow integrate the induced field up to any point. It's a damn near impossible task except for the most symmetric circuit. And the minute you do work out all the scalar potentials, as soon you move wires around everything is different. The net E-field voltage doesn't have this problem.
I think I see exactly what you mean. I really admire your insight. You now ask the most central and interesting question about this discussion. I actually started thinking about these things that confuse me a long time ago. I hope I can reply soon but I'm out shopping and lunch right now and when I get back I'll share some of my thoughts on these issues although I'm not too sure if I'm thinking right.
  • #42
Thanks - for sure, I'm enjoying the conversation. Glad I joined this, it's good to be able to bounce ideas off people who know what they're talking about rather than arguing in YouTube comments haha.
  • #43
You seem to describe the problem in a complicated way. I try to understand it simply. It is to divide a whole into two parts, the first part is the scalar potential and the scalar field, and the second part is the induction field. For example, when a positive test charge moves in the scalar field from a place of low potential to a place of high potential, it increases the energy of the scalar potential. You can do the calculations independently, since you already know that the induced electric field energizes this positive test charge.
Then you can imagine that the test charge actually moves in the induced electric field at the same time and in the same path. The magnitude of the induced electric field is the same as that of the scalar field, but in the opposite direction, so the net field in the conductor is zero. The direction of motion of the test charge is the same as that of the induced electric field, so we can deduce that the energy provided by the induced electric field is exactly equal to the energy added by the scalar potential energy.
I think the key here is whether you can convince yourself that when a test charge moves in a conductor with a net electric field of zero, it actually corresponds to the energy conversion process described above. If you are not satisfied or agree with the above reasoning process, you can try to analyze it with Poynting vector, then you will get a complete energy flow diagram.
  • #44
I believe you. But what you do not seem to understand is:
  1. This is not the ordinary and customary description
  2. I believe most physicists find this "dual field" complication unnecessary and fraught
The pictures you carry around in your head are entirely up to you, but please realiize there may be a reason why they are not mainstream physics.
I must admit to being completely mystified by the negative response to Prof Lewin's lecture. I recall my perhaps incorrect inference from him that the most vehement attacks on the lecture demonstration were from outside the physics department. These included charges that he had used sleight of hand somehow!
So I guess I will remain mystified and give it up. Seems obvious to me.
Likes DaveE
  • #45
What's funny, is that when you hear people's reasons for assuming Kirchoff to always be true, they almost never mention scalar potential. Check out RSD Academy on youtube, who's done multiple videos on this problem arguing against Lewin. (Mabilde does the same analysis in one of his videos). He never (iirc) mentions scalar potential, or identifies two opposing electric fields, or conflicting conventions for defining voltage. If he did, he would recognize that this is just a difference in conventions rather than saying Lewin was just flat out wrong. If you follow his analysis, he treats voltage the way we usually think about it - the total drop across a resistor or IR, integral of net electric field, etc.
He simply inserts the emf in the circuit, attributing it to different sections of the wire, without calling it a field. Then he shows that emf - sum(IR) = 0. Which is of course true as a conservation of energy equation, but not as a loop equation: sum(IR) = emf. So he's not considering scalar potential, he just gets the physics wrong. Then he points to McDonald's paper and says, "see, I'm right, there's a potential difference in the wire that you just can't measure". It's laughable.
Likes hutchphd
  • #46
Sigh...
There is no doubt that Walter Lewin is an excellent teacher. As I said in my first post in this thread, I don't understand the controversy.
It seems to me a number of folks are not following rules. Firstly is Walter Lewin. Kirchoff holds. The resistors form a series circuit as far as the test setup is concerned. Where the broken rule comes in is that Lewin is not accounting for the fact that the connecting wires are forming the secondary winding of a transformer. Actually two secondaries. One is the node A and the other node D. Or I should say the wires between the resistors where said nodes are. So technically, the schematic form of this setup is not matching the real world setup. It doesn't matter that "they're just wires", how they are functioning needs to be accounted for.
There is disagreement, in this thread as well as others, whether these voltages of the secondary winding(s) each consisting of a half a turn of wire can be measured. This is a completely new rabbit hole. My view is the Mr. @mabilde did it right in his video.
All that being said, the @mabilde setup somewhat resembles a directional coupler. Yes, that stance is a bit of a stretch. But instead of using a primary solenoid and the single loop as a secondary, we could replace one resistor with a signal generator and watch the scope in the @mabilde setup while flipping the test leads from one side to the other and notice the change. Directional couplers for RF are often laid out on a circuit board with very few if any components soldered to the board. They may not look like it but they essentially combine a voltage signal with a signal from a current transformer.
There is nothing magical about this. Some folks are just misinterpreting the results or are not seeing the setup and schematic for what they are. So, in a way, Lewin did perform a sleight of hand. But I don't think he intended to, and a lot of folks have fallen for it. Truly a perfect storm. If the lecture had been presented in a different manner I wonder where things would be today.
  • #47
Sigh...
There is nothing magical about this. Some folks are just misinterpreting the results or are not seeing the setup and schematic for they are. So, in a way, Lewin did perform a sleight of hand. But I don't think he intended to, and a lot of folks have fallen for it. Truly a perfect storm. If the lecture had been presented in a different manner I wonder where things would be today.
So I've thought about the "just model the wires as a transformer" argument a lot. Understanding exactly what this means gets to the heart of the debate, and no one seems to talk about it, though it's now quite clear to me. It depends on what we mean by the 'voltage' of a secondary, or in general an inductor. It all comes down to path difference.
In an transformer, you can measure the electric field along two paths - Path 1 is THROUGH the coiled wire itself, which we almost never do. Path 2 is the the nearly straight path connecting the terminals OUTSIDE the coil (as we usually do with a voltmeter). .For the first path, imagine taking a voltmeter and measuring points on the coil very close together, and add up the measurements as you reposition the voltmeter point by point: Vab + Vbc + Vcd... etc. all the way down, following the coil in a corkscrew manner.
These path measurements are different - why? Imagine the loop formed by these two paths - coiling down the wire (1), and straight up outside (2). This loop has a changing magnetic flux passing through the surface it bounds. As I mentioned in an earlier post, the surface is complicated, but it looks like a rotini pasta or a the film formed when a corkscrew is dipped in soapy water. You absolutely need to understand Stoke's theorem to follow this, but basically the rate of change of magnetic flux that penetrates this surface equals the integral of electric field along this whole loop (Faraday's law).
If there's a changing flux passing through, the total loop voltage is NON-ZERO. In fact the loop voltage is equal to the emf, -d(phi)/dt. If the loop sum is non-zero, then these two paths have to have different 'voltages'. The outside path measures the electric field on the outside, and therefore is a true voltage. It equals the emf of the transformer. The coiled path measures zero, as there is zero-field in the conductor. The total sum of the loop is the emf. This is path dependence, a consequence of the non-conservative induced field. If you put this transformer in a circuit with a single resistor, you can consider two loops - resistor + coil (Loop 1), or resistor + outside straight path (Loop 2). Loop 2 is how we usually analyze the circuit with Kirchoff's law. If we use Loop 1, we have to use Faraday's law, including the emf as a separate term.
We almost never observe this path dependence because who would ever bother taking those cumbersome voltmeter measurements on a tight coil? So how do we investigate it? We unwrap the transformer. We make it a single loop, and strengthen the flux to get a good emf. Now we can show the circuit in a plane. We can even put the flux in the center of the circuit, so the entire loop is the transformer. But we still have two paths/loops we can consider. Loop 1 is the resistor plus the (uncoiled) wire - it is essentially the path of the circuit itself under consideration. Loop 2 has the resistor, but leaves the wire, goes around the flux at the center to avoid it (through free space), and returns to the wire at some point.
You can analyze Loop 2 with Kirchoff's laws as there is no flux passing through it. This loop treats the circuit itself as a transformer and gives it a 'voltage', so the loop sums to zero. It's the part of the path through free space that has the electric field associated with the emf, NOT the conducting wire. That's 'modeling the wires as a transformer'. But Loop 1 does not sum up to zero, it only has a resistor. It DOES have the flux passing through it, which is accounted for with Faraday's law. Two DIFFERENT loops, two DIFFERENT loop measurements, SAME final accounting:
Vr = emf (Loop 1, Faraday's law)
or
Vr - emf = 0 (Loop 2, Kirchoff's law)Now attach voltmeters to either side - one across the single resistor on the left, one between two points of the wire on the right. But connect them at the same two points on the circuit, just along different paths. The first one will measure the emf, as an IR drop across the resistor. The second will record zero, as there is no drop in a conducting wire. How do the meters know which path they're measuring? From which side of the flux they're on. Take the left meter, lift it up over the flux (over the top of the solenoid) to the other side, and you will see the number gradually change as the voltmeter lead crosses over the flux area, as we are changing the flux through the measurement path, until it becomes Path 1. This is exactly what @mabilde shows in his video, rather beautifully.
So we see that "modeling the loop as a transformer" really means "change the path of analysis so it doesn't include the flux". That defeats the purpose of understanding the underlying physics of non-conservative fields. Lewin has deliberately, intentionally deconstructed the transformer to understand what is really going on. Wrapping it up again and modeling it as a coil avoids the ambiguity but simply hides the physics. As you said, there is nothing magical about this.
(I have some diagrams for this, I'll put them in another post. My intention is to make some videos on this as well that makes this really clear).
  • #48
I have to mention again that this treatment of describing the electric fields generated by the charges on the surface of conductors in an electromagnetic induction system, and further analyzing the interaction of the electric fields generated by these charges with the induced electric fields, is certainly not my own idea or invention. I found a lot of this material on the Internet, Dr. Lewin's lectures on his circuit paradoxes were also one of my study objects.
Note that Ei is the induced electric field and Ech is the electric field generated by the surface charge, Q+ Q- are positive and negative charges respectively
  • #49
What's the timestamp on this video? I want to understand your thinking here.
  • #50
@tedward all this talk of electric fields seems to cloud what's really at hand. You might question how the subject can be discussed by ignoring this. I'll tell you how. The same way we do basic circuit analysis without ever worrying about the lowly electron. It simply isn't needed.
The turns ratio of primary to secondary in a transformer does not fail, ever, as long as copper losses and loading is accounted for. So, yes, there is X number of volts dropped across each turn and to delve farther into that, X volts per unit of length within a turn. And yes, it's measurable. There is nothing to say there needs to be more than one turn total. I've gotten mixed signals from you concerning this. It's been my perception that your opinion is that turn per turn will never add up in a coil to the total voltage.
In the Lewin and @mabilde setup, all we really need to worry about is that we have a secondary coil with two discrete resistances wired across it. We need not worry about fields until we start trying to measure voltages on portions of the coil so as to not introduce errors into the measurements. How this is done I've already covered.
One last exercise for our brains:
Suppose we have a transformer that has two secondary coils wound in such a way so they supply the same voltage. Many transformers are configured like this. Hook them in series so they are additive. For sake of discussion let's say each secondary is putting out 10 volts. We don't know how many turns there are and we don't care. Put in series they would together put out 20 volts. Now take and put a resistor across the 20 volts output of the two secondaries in series. Next break the connection made between the two secondaries and insert another resistor. We now have the same setup as the Lewin experiment only we have more turns. Somehow all the readings in this setup are accepted and I assume it is because it is easy for people to visualize that there is a transformer. The way of thinking changes. Also people can be sloppy with voltmeter lead placement with no consequences in the measurements.
