What are the best resources for learning about E&M as a beginner?
  • Thread starter Thread starter Branden
    Coil Copper Core
The discussion centers on the effects of an insulated copper coil wound around a copper pipe, noting that there is no difference in electrical flow or magnetic strength in a stationary DC field. It clarifies that copper is not ferrous and charges are not "picked up" by a magnetic field; rather, they are influenced by the Lorentz force, which depends on the magnetic and electric fields and the charge's velocity. Participants inquire about the individual's current level of physics study to suggest appropriate resources for learning about electromagnetism (E&M). The individual identifies as a beginner with a hobbyist interest in low voltages. Recommendations for foundational reading materials in E&M are sought to enhance understanding.
Branden
For research purposes, what would be the result of Electrical flow or magnetic strength if an Insulated copper Coil were wound around a pice of copper pipe?
No difference for a stationary (DC) field.
Is a charge picked up on the pipe because of the present magnetic field?
No, copper is not ferrous, AFAIK. And charges are not "picked up" because of a magnetic field. Charges are influenced by the Lorentz force, which depends on the magnetic and electric fields and the velocity vector of the charge.
What level are you studying physics at right now? We should be able to suggest some reading that will help you build your fundamentals in E&M. :smile:
No level at the moment, I'm just discovering Curiosities as I dabble around with low voltages. May
this is a hobby for me.
I would say I am a beginner with some general knowledge, and that this is more of a hobby for me right now but. If you could Recommend some Sources that would be awesome.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
