What are the biggest misconceptions about black holes?
In summary: What the term 'singularity' actually means is that our current best theories are inapplicable for the centre of a black hole.So basically, it's a theory that we don't have any real evidence for and may never be able to prove. Another is that there is a contradiction that since nothing can escape a black hole, it can't have any gravitational effect since gravity could not escape it. Can you elaborate? Why does an event horizon take an infinite amount of time to form?
  • #71
Droidriven said:
The quantum superposition theory doesn't necessarily state that a particle can be in two places at once, the theory goes as far as to say that a particle can be in an infinite number of positions or any given point at any given time. There is no proof of this though. Only experiments that seem to provide evidence, still theory.
But even that is based on the conditions involved in observing the particle or even the observer themselves. In other words, what is observed by an individual under a certain set of circumstances at a given time, may not be what is observed by another individual in the same circumstances at the same time. No consistency, no measurability, only the observance of the event, which can change from moment to moment or observer to observer.
At least, that is my understanding of it.
A lot of our understanding on black holes are theory. Hawkins Radiation theorises that particles can escape. Does anyone find it interesting that a BH will evaporate over a large scale of time yet time stands still within a BH, so if time stands still within a BH how can a BH evaporate. The maths needed to prove any of it still needs to be done. I like to keep an open mind on theories unless, proven wrong beyond a doubt. An open mind let's in knowledge as opposed to a closed mind.
Astronomy news on Phys.org
  • #72
Intresting said:
...if time stands still within a BH...
Does it?
  • #74
Intresting said:
That article only confirmed what I was going to say.
It states that time "in effect" stands still, not that it actually stands still. Note that it states that nothing in Kerr spacetime changes "over time", it is stationary, nothing moves, nothing changes but time keeps on. If it didn't, then there wouldn't be such a thing as "over time" in Kerr spacetime, time continues, it is just different somehow. And then only when the Black Hole has reached Kerr state.
Likes 1oldman2
  • #75
Thats a given that not all BH's are super massive like BH's at the center of galaxies or mature BH's. As micro BH's disappear as instantaneously as it appears, in theory at least. I should have worded my opinion more carefully and assumed that you would get the gist off it.
"It states that time "in effect" stands still" can be viewed as semantics to suit an ideology. . http://hubblesite.org/explore_astronomy/black_holes/encyc_mod3_q15.html the link is one way of looking at it. If you where at point B it would seem to be at a normal time but from point A, point B has in effect stopped. so from point A, point B should not evaporate overtime as in effect it is stationery, since we do not have physics to describe the inside of black holes, the official answer is “we don’t know” and can only speculate.
Likes 1oldman2
  • #76
Intresting said:
If you where at point B it would seem to be at a normal time but from point A, point B has in effect stopped. so from point A, point B should not evaporate overtime ...
This is not correct. Just because A sees what he knows is an illusion, that doesn't mean the evaporation doesn't happen.
  • #77
So a super massive black hole distorting space time to breaking point is also an illusion?
  • #78
No, and I can't imagine why you conflate the two.
  • #79
Droidriven said:
It isn't their density that gives them their massive gravity, it is their mass, they can be any size(in theory) but they are not as dense as commonly believed, immense density is another misconception. There "may" be areas such as the EH or the proposed singularity that are extremely dense but that density is not consistent through the entire mass. Regions of density with emptiness between the dense regions.
With density comes mass . . .
Likes 1oldman2
  • #80
Of course, and with mass, comes gravity.
But that is relative as well. Two objects of equal mass with one being denser would from a distance equally pull on each other, but surface gravity acceleration would cause the denser object to have a higher gravity at its surface, a difference in in local gravity only, not its gravity as a whole(so to speak).
Likes ProfuselyQuarky
  • #81
The Black Hole isn't an illusion but what you observe of said Black Hole in undistorted spacetime is an illusion because what you see and what is happening are relatively different.
  • #82
Tell me about it. My gut is now attracting items from around the room. I've GOT to cut down on that coke.
Likes Nemika, Flyx and ProfuselyQuarky
  • #83
So maybe you should go to a different room where, rather than Coke, the veggies+plain water are the ones that gravitate towards you.
Likes 1oldman2
  • #84
Yeah, but "should" and "will" are, sadly, different.
  • #85
You should be aware that there are classical GR solutions describing formation, then shrinkage of a BH with true horizon that forms and ultimately vanishes. These are not exactly equivalent to Hawking radiation; they are a classical analog. For example, glue the Oppenheimer-Sneider collapse some time past horizon formation to a matched outgoing Vaidya solution. The result is as I described. A somewhat different approach is presented in: https://arxiv.org/abs/gr-qc/0506126, which can readily be taken as a clasical model of a forming, then evaporating BH (where, in some sense, the final evaporation prevents singularity formation). The classically unconventional feature is the that outgoing vaidya metric violates all the 'energy condition', but it is well known that Hawkging radiation must, as well - so this is good feature of classical analog model.
Likes Intresting
  • #86
While this link deals with gravitational waves as much as BH's I found the merger simulation fascinating, Hope this doesn't stray from the topic too much.
  • #87
Under the classical theory of general relativity, once a black hole is created, it will last forever since nothing can escape it. However, if quantum mechanics is also considered, it turns out that all black holes will eventually evaporate as they slowly leak Hawking radiation. We just don't know.
A fun doco to watch
  • #88
A fun doco to watch
It partly depends on what you mean by classical general relativity. If you choose this to include energy conditions (e.g. the dominant energy condition), this is true (and I often consider this a definition of 'truly classical GR'). However, if there were such a thing as classical scalar fields, the energy conditions are violated, and you could have purely classical evaporation of BH as I indicated in my prior post.
Likes Intresting
  • #89
One misconception I have seen in movies is that event horizon is some actual surface or membrane, usually one-way. And when you are inside the hole, you can no longer feel gravity, as if you were trapped in a bubble. And it's the horizon that prevents you from escaping, like a solid wall. And that the "horizon" may be eventually broken given enough power or determination and you can escape through the crack in the horizon.
Likes Flyx
  • #90
I've never heard this before?
  • #91
Flyx said:
I think the biggest misconception is 'How can black holes not let light escape when photons have no mass?'
Kinda surprised nobody refuted this. Though the mass of a photon is zero, it nevertheless carries energy and momentum. Enough for a BH to trap.
I have a niggling feeling I may have misread your statement. It's like a double entendre without the innuendo or a double negative. Grammar isn't my strong point. If I have misread you're statement, I apologise.
  • #92
I am not sure if I should dignify this with a response. Yet I have. Let's say Earth (A) has a influence on time due to its mass (which it has) That's why satellites (B) have to adjust its time in orbit due to Earths gravity, even though it is a fraction not mentioning but yet it still affects satnav or GPS relating to Earths gravity, but there is still time dilation. Now magnify that with a super massive black hole. It is not an illusion. I conflated the two too signify time and space time to try and convey a thought.
  • #93
I was saying how many people say that, and it is a misconception.
  • #94
IMO, the term Black Hole itself is a misnomer.
In all of the previous posts I have not seen one mention that a BH is not a *hole* at all. It is a massive singularity surrounded by a gravitational sphere. So instead of a hole a BH is really a *black sphere*, which has actually separated itself from external spacetime and is not visible to us. Hence the appearance of a *hole*.
But the inside the Black Spere may be very bright in the 3D spherical space between the gravitational event horizon and the central singularity. It's just that this brightness curves into itself and becomes *invisible*, giving the appearance of a hole.
A separate universe within a galaxy?
The gravitational sphere of the sun (an average, if not small singularity), may be as large as
The Sun's gravitational field is estimated to dominate the gravitational forces of surrounding objects out to about two light years (125,000 AU).
Now visualize a BH singularity some few million times more massive than our sun, we may get a scope and gravitational influence of a BH singularity.
This image shows the disk galaxy NGC 1277, as seen by the Hubble Space Telescope. The small, flattened galaxy has one of the biggest central super-massive black holes ever found in its center, the equivalent of 17 billion suns. Credit: NASA / ESA / Andrew C. Fabian / Remco C. E. van den Bosch (MPIA)
- See more at: http://www.space.com/18668-biggest-black-hole-discovery.html#sthash.DKGcTRKP.dpuf
Obviously we can see the surrounding galaxy, but in the center of this galaxy resides a Black Sphere which is invisible to us because it cannot emit radiation from inside its event horizon.
  • #95
It is not the massiveness of a black hole that makes it a black hole; it is its density. In theory, there are black holes at the centers of galaxies, billions of times the mass of our sun. Yet, our sun could become a black hole if it were sufficiently compressed. Every mass, regardless of size, has a Schwarzschild radius (correct me if I'm wrong about that). In fact, there is no amount of matter so small that it cannot become a black hole if it is sufficiently dense. That being said, and considering the huge amount of energy within every perceptible piece of matter, isn't it possible that all sub-atomic particles are black holes? I think the greatest misconception about black holes is that they are all extremely massive objects that exist mainly at the centers of galaxies.
  • #96
That's correct, although I do believe that there is a lower limit, in that an atom, for example, cannot become a black hole and certainly an electron cannot.
Now you're off in la-la land and you want to watch yourself on stuff like this. Personal theories are not permitted here.
Not sure if this is a misconception or not, but there may be some laymen who think they are only at the center of galaxies because they mis-interpreted a pop-science article or TV show.
  • #97
Intresting said:
... so from point A, point B should not evaporate overtime
Yes, but you conflated two very different things. The fact that point A does not see point B evaporate does NOT follow from the correct facts in your subsequent post. What you are missing is that over time the black hole DOES evaporate and if point A is around long enough it WILL see point B evaporate. SO ... it's good that you did "dignify" it with a response since perhaps now you have learned something that you didn't realize.
  • #98
Another misconception: An in-falling person will not experience anything abnormal at the exact moment she is crossing the event horizon. Truth: It is a popular hypothesis, but not a fact (and continues to be challenged as in firewall etc).
In fact, any statement on what happens at or within the horizon is only a hypothesis (as of now?).
  • #99
I think everyone sufficiently imaginative has entertained that idea at some point. It just doesn't work though. Consider neutron decay. A neutron that was a black hole would have nothing ever come out of it. One black hole would never split into two black holes. Yet a free neutron will split into electron, proton, and neutrino. A neutron that was a "mini-black-hole" seems like it would quickly hoover up the nearest neutron to it in a nucleus. Somewhere a photon would hit an electron and not escape ... that would just be annoying, as the photon could be any size, so electrons could be arbitrary mass after a while.
I'm not a physicist, so these objections are also just imagination at work ... I'm sure there are more substantive reasons. There is currently a thread as to why this gets out of hand quickly:
https://www.physicsforums.com/threads/why-wont-you-look-at-my-new-theory-comments.866043/
  • #100
I assume (since I find it confusing) that most people don't have a clear conception of why a black hole does not defy the universal requirement for increasing entropy. That is not a misconception, just a thing that is difficult.
Evaporation would have to be another thing that is often not a clear concept in general understanding.
I'm stretching the definition of misconception ... but if you (OP) want to consider beyond the general idea that a black hole is just the big thing with all the gravity that light cannot escape ... in that simple thing, entropy and evaporation don't fit.
  • #101
It removes confusion to talk in terms of what model of BH you are using. That nothing unusual happens at horizon crossing is mathematical fact of the classical GR black holes. Firewalls are a feature of a semi-classical treatment of quantum gravity, under commonly held assumptions (there treatments in this realm, with less accepted assumptions that don't involve firewalls; such eminent physicists as Juan Maldacena think the firewall hypothesis will ultimately be rejected). There is no full, consistent treatment in quantum gravity because there is no complete theory. Apart from all this, you are clearly correct that we don't, and may never, have a way to verify this feature of real world BH. The best we can do is choose to believe the predictions of a complete QG theory that is verified elsewhere (whenever that is achieved).
  • #102
If I may be permitted a set of analogies.
In context of a *multiverse*, perhaps BHs are the *eggs* of new *baby galaxies*, or *tunnels* to new *baby universes*, invisible to us?
  • #103
Sorry I joined the party late - a comment about colour and black holes
wavelengths in the vis spectrum are colour not beyond, you would not refer to microwaves as colour
  • #104
What is the evidence for this?, as far as I know there is none.
On that basis, one might equally well argue that black holes are portals to the holy kingdom of the flying spaghetti monster.
  • #105
I don't think one can apply a theory beyond its domains of validity and call it factual. It would have been ok before the limitations of classical theory came up, by virtue of it being an 'unknown unknown' problem, but not anymore since it is a 'known unknown'.
On firewalls etc, sure they are hotly debated, with eminent names on either side, and I don't have the expertise to pick a side on this. Mentioned it merely to exemplify my case.
