MHB What Are the Time Complexities of These Functions?
  • Thread starter Thread starter shamieh
    Time
The discussion focuses on the time complexities of various functions, with participants analyzing and justifying their findings using Big O, Omega, and Theta notations. Several functions are evaluated, including comparisons between linear, logarithmic, and polynomial complexities, with specific examples provided for clarification. Participants emphasize the importance of correct exponentiation in logarithmic functions and the need for precise definitions when establishing relationships between functions. The conversation highlights common misconceptions and the necessity of rigorous justification in complexity analysis. Overall, the thread serves as a resource for understanding time complexity evaluations in algorithm analysis.
shamieh
Can someone tell me if I'm even doing this correctly? I haven't dealt with TCs in while.
So I got:
$a) h_1(n) = O(n) \implies n$ , $h_2(n) = \Omega (n\log n) \implies n\log n$
$b) h_1(n) = \Omega(\log n) \implies \log n$, $h_2(n) = O(n^{2/5}) \implies n^{2/5}$
(Justification $h_1(n)$: Let $n = 1000 \implies 12(1000)^{2/3} = 524$ and Let $x = 1000 \implies 7 \log(1000) = 48$ so $n^{2/5} > \log(n)$)
(Justification $h_2(n)$: Let $n = 1000 \implies (5(100000000))^{2/5} = 3017.08..$ so $n^{2/5} > O(1)$ (or 1000) )
$c) h_1(n) = O(n^2) \implies n^2$, $h_2(n) = \Omega(n \log^4 n) \implies n \log^4 n$
$d) h_1(n) = O(\log(n)) \implies \log(n)$, $h_2(n) = \Omega (\log(n^5)) \implies \log(n^5)$
$e) h_1(n) = O(n) \implies n$, $h_2(n) = O(n) \implies n$
(Justification $h_1(n)$: let $n = 1000 \implies 1000^{1.02} = 1148.15 > \log(1000)^{1.02} = 7.17..$)
(Justification $h_2(n)$: let $n = 1000$ to find $1000(1000)log^3 1000 = 3.296.. < 2(1000) = 2000$)
$f) h_1(n) = O(n^2) \implies n^2$, $h_2(n) = \Omega(\log n) \implies \log n$
(Justification $h_1(n)$: Well $O(n^2) = n^2$ ?)
(Justification $h_2(n)$: $O(\log n) = \log n$) ?
$h) h_1(n) = O(n) \implies n$, $h_2(n) =$ exponential?
You want to format these the way the problem is asking: $h_1(n)=n$, because $1000n-1000=O(n)$. And $h_2(n)=n \, \log(n)$ because $2n \, \log(n)+6n=O(n \, \log(n))$.
$n^{2/3}$ beats $\log(n)$, so you need to have $h_1(n)=n^{2/3}$.
Don't forget the logarithm rule here: $\log(n^5)=5 \, \log(n)$.
This isn't going to work, I'm afraid. On the first one, you need $h_1(n)=n^{1.02}$. Inside the parentheses, the $n$ beats the $\log(n)$, but without the correct exponent, it will not grow fast enough. For $h_2(n)$, you have to have $n \, \log^3(n)$. Exponentiating the logarithm does not have the nice identity that $\log(n^m)=m \, \log(n)$ does.
For $h_2(n)$, you're going to need
$$5^{\log(n)}=\left(10^{\log(5)}\right)^{\log(n)}=10^{\log(5)\cdot\log(n)}=10^{\log\left(n^{\log(5)}\right)}=n^{\log(5)}.$$
You can see here that I've assumed you're using $\log(x)=\log_{10}(x)$. What follows is more general, in case you're using a different base:
$$a^{\log_b(x)}=\left(b^{\log_b(a)}\right)^{\log_b(x)}=b^{\log_b(a) \cdot \log_b(x)}=b^{\log_b\left(x^{\log_b(a)}\right)}=x^{\log_b(a)}.$$
So, in general, $a^{\log_b(x)}=x^{\log_b(a)}.$ I did not know that before now!
I think you're going to need more of something like this:
$$n^{\sqrt{n}}=n^{n^{1/2}}=\left(10^{\log(n)}\right)^{n^{1/2}}=10^{n^{1/2}\log(n)}.$$
That's in the format you need for $h_1$. You can do a similar trick for $h_2$.
Wow thanks so much.. So now I'm on the second part.. (NOTE: I left out $h$ for the time being)
But I'm not sure if I'm doing it right. Here is what I have so far:
a) $f_1 = O(f_2)$
b) Not Equal
c) Not Equal
Justification: $n^2 = 1000^2 =$ 1 million while $(1000)\log^4 (1000) = 2.27..$ so we know that $f(x) \notin O(g(x))$
d) $f_1 = O(f_2)$
Justification: $ \log(n) = \log(1000) = 6.907..$ and $ \log(n^5) = 34.538..$ so we know that $f(x)=O(g(x))$ iff $∃$ positive constants $C$ and $n_0 |0≤f(n)≤c∗g(n)$, $∀$ $ n≥n_0| $ $\therefore f_1 = O(f_2)$
e) $f_1 = O(f_2)$
f) Not Equal
a) $f_1 = O(f_2)$
b) $f_1 = O(f_2)$
c)
According to the definition I know that: $f(x)=O(g(x))$ iff $∃$ positive constants $C$ and $n_0 |0≤f(n)≤c∗g(n), ∀ n≥n_0|$
So letting $n = 10$, $c = 5$ for:
$0 \le f_1(n) \le c * f_2(n) \implies (10)^2 + (10)\log(10) \le (5)((10)\log^4 (10) + \sqrt{10})$
= $0 \le 123 \le 1405 \implies f_1 = O(f_2)$
Using the fact that:
Then we know that $\lim_{n\rightarrow\infty}$ $\frac{n^2 + n \log n}{n \log ^4 n + \sqrt{n}} = \infty$
$\therefore f_1 = \Omega(f_2) \implies f_1 = \Theta(f_2)$
d)
$ 0 \le f_1(n) \le c * f_2(n) \implies 3\log(10) + 3 \le (5)(\log (10^4) + 2)$
= $0 \le 9.9077 \le 56.05 \implies f_1 = O(f_2)$
Then we know that $\lim_{n\rightarrow\infty}$ $\frac{3\log(n) + 3}{\log(n^5) + 2} = \frac{3}{5}$
$\therefore f_1 = \Theta(f_2)$
e)
$f_1 = O(f_2)$
f)
$f_1 = O(f_2)$
h) According to the definition I know that: $f(x)=O(g(x))$ iff $∃$ positive constants $C$ and $n_0 |0≤f(n)≤c∗g(n), ∀ n≥n_0|$
So letting $n = 10$, $c = 1$ for:
$ 0 \le f_1(n) \le c * f_2(n) \implies 10^{\sqrt{10}} + 3 \le (1)(sqrt{10}^{10})$
= $0 \le 1453 \le 100,000 \implies f_1 = O(f_2)$
Then we know that $\lim_{n\rightarrow\infty}$ $\frac{n^{\sqrt{n}}}{\sqrt{n}^{n}} = 0$
$\therefore f_1 \in O(f_2)$ but $f_1 \ne \Omega(f_2), f_1 \ne \Theta(f_2)$
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
